POV-Ray : Newsgroups : povray.general : How does POV handle IORs? Server Time
11 Sep 2025 15:17:14 EDT (-0400)
  How does POV handle IORs? (Message 1 to 10 of 11)
Subject: How does POV handle IORs?
Date: 29 Jan 2002 17:25:13
Message: <MPG.16c13f9478298a549896d4@news.povray.org>
When a ray first enters an object of, say ior 1.5, and then one with ior
1.3 (without leaving the first object), is that IOR than regarded
relative to the containing object, or absolute?
And, when the ray than leaves the second object, does it "remember" that
the outside has ior 1.5?
The reason I ask is, I made a glass with a liqid inside.
The common way to do this, is to scale the "liquid" by, .999.
But this causes the render to become very slow, because of reflections
between the liqid and the glass, because there are now two surfaces where
in reality there should be only one. So I had the idea to clip the glass
by a slightly bigger inverted copy of the liqid.
This is much faster, but I'm not sure if it gives correct results?
Lutz-Peter
Subject: Re: How does POV handle IORs?
Date: 29 Jan 2002 17:32:27
Message: <3c5722fa@news.povray.org>
Lutz-Peter Hooge <lpv### [at] gmxde> wrote:
: When a ray first enters an object of, say ior 1.5, and then one with ior
: 1.3 (without leaving the first object), is that IOR than regarded
: relative to the containing object, or absolute?
: And, when the ray than leaves the second object, does it "remember" that
: the outside has ior 1.5?
  AFAIK povray always remembers what is the current ior of the space the
current ray is travelling.
Date: 29 Jan 2002 17:47:16
Message: <3c572674@news.povray.org>
> ior of the space the current ray is travelling.
But how is the ior of the current space defined?
If object A has ior 1.3 and object B ior 1.5 and a ray goes like this:
enter A
enter B
leave A
leave B
...then what is the ior in the space marked by * ?
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Date: 29 Jan 2002 18:01:30
Message: <3c5729ca@news.povray.org>
In article <MPG.16c13f9478298a549896d4@news.povray.org> , Lutz-Peter Hooge
Not sure if it is anywhere else, but the 4th paragraph of
<http://www.povray.org/working-docs/id000174.html#6_6_1>
explains how and where the ior is used.
    Thorsten
e-mail: tho### [at] trfde
Date: 29 Jan 2002 19:38:51
Message: <slrna5eg4v.l4n.ron.parker@fwi.com>
> enter A
> enter B
> leave A
> leave B
1.5.  The important question, believe it or not, is what is the IOR
between "leave A" and "leave B".  I actually had to look this one up,
and I think the behaviour changed between 3.1 and 3.5.
Here's the map of how it works:
IOR
1.0
    enter A
1.3
    enter B
1.5
    leave A
1.5  (the IOR of the remaining "innermost" object)
    leave B
1.0
Here's what happens when the water is scaled slightly larger than the inside
profile of the glass:
1.0   air (inside: air)
     enter glass
1.5   glass (inside: air glass)
     enter water
1.3   water (inside: air glass water)
     exit glass
1.3   water (inside: air water)
     enter glass
1.5   glass (inside: air water glass)
     exit water
     exit glass
As you can see, this is preferable to the case where the water is slightly
smaller than the inside of the glass:
     enter glass
     exit glass
     enter water
     exit water
     enter glass
     exit glass
This gives extra opportunities for TIR to occur, at the first glass->air
transition and at the water->air transition.  This gives your glass a
silvery sheen like it would have if - surprise! - you had an air bubble
between the glass and the water.
The way it's done means you only have one IOR transition at each interface,
even though you intersect two surfaces.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 29 Jan 2002 19:59:27
Message: <3c57456f@news.povray.org>
So what I understand from this is that with respect to refraction, there's
not much difference between a water scaled a bit larger than the inner surface
of the glass compared to just water inside the glass (which doesn't have an
inner surface).
  The difference appear in other two things: The amount of reflection (two
surfaces reflect more than one) and the rendering speed (two reflecting and
refracting surfaces take much longer to render than just one surface).
Date: 29 Jan 2002 20:29:06
Message: <MPG.16c16aaebba42d599896d5@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
says...
Ah, thanks very much!
I'm currently testing it.
The problem of reflections between the two surfaces than should be
solvable by adding a non-reflective interior-texture to the liquid, I
hope :-)
Lutz-Peter
Date: 29 Jan 2002 20:50:00
Message: <slrna5ekac.shm.ron.parker@fwi.com>
> says...
> hope :-)
You're more likely to have success if you add a non-reflective interior
texture to both the glass and the liquid.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 29 Jan 2002 21:15:11
Message: <MPG.16c1757bc158e54e9896d7@news.povray.org>
says...
No, I want to have reflections inside the glass itself.
But I was wrong with the water, it doesn't need any reflective surface on
either side (only on its "true" surfaces, but thats not a problem because
that is a differenced plane anyway)
Lutz-Peter
Date: 29 Jan 2002 22:29:30
Message: <chrishuff-3BF865.22315029012002@netplex.aussie.org>
Will POV render correctly in the case where the ray exits through a
water/air surface? For example, looking upward through a glass bowl of
water?
