POV-Ray : Newsgroups : povray.general : Can POV-Ray model gamma rays instead of visible light? Server Time
1 Feb 2026 18:54:16 EST (-0500)
  Can POV-Ray model gamma rays instead of visible light? (Message 1 to 4 of 4)
Subject: Can POV-Ray model gamma rays instead of visible light?
Date: 12 Mar 2004 18:09:05
Message: <86vfl9br56.fsf@duchess.twilley.org>
Hash: SHA1
I have been wondering how useful POV-Ray would be in tracing gamma
rays instead of visible light.  This could be useful for modeling
gamma ray shielding and gamma ray buildup.  Reflection, refraction,
and dispersion are very similar between the two types of EM radiation,
as far as I can see.  Obviously, I'd have to create my own material
definitions and I'd only be able to test one energy level at a time,
but #ifdef's would help with that.  The biggest obstruction I can see
is how to associate exposure levels with brightnesses, but I imagine
that could be done by creating very simple scenes matching calibrated
environments with accurate tested values.
Any thoughts?
Jack.
Jack Twilley
jmt at twilley dot org
http colon slash slash www dot twilley dot org slash tilde jmt slash
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (FreeBSD)
iD8DBQFAUkLaGPFSfAB/ezgRAgzXAJ9+7sprrA4IM2s1yNYs+s3rkPml4ACfWXgY
fs6i4kBNU7Y5YQrFswcg6C4=
=hyaa
-----END PGP SIGNATURE-----
Subject: Re: Can POV-Ray model gamma rays instead of visible light?
Date: 12 Mar 2004 19:22:03
Message: <l7l450p5lqkio8n5td43jfj73gdrv99o9q@4ax.com>
On Fri, 12 Mar 2004 15:08:05 -0800, Jack Twilley
<jmt+use### [at] twilleyorg> wrote:
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
>Any thoughts?
>Jack.
Straight away I believe the problem is that POV-Ray has no concept of
wavelength when it comes to light. The photon modelling that POV does
is particle based.
As usual, people, please correct me if I'm wrong.
My First Subgenius Picture Book:
http://www.imbjr.com
Date: 13 Mar 2004 05:22:06
Message: <d3p$xHA1wpUAFwLh@econym.demon.co.uk>
Wasn't it Jack Twilley who wrote:
>Hash: SHA1
>Any thoughts?
I was under the impression that there were differences in reflection and
refraction. I guess the underlying principles are the same, but there
aren't any available materials that make useful gamma ray lenses or
conventional mirrors. I thought that gamma ray telescopes used a
different reflection principle to produce grazing mirrors, and that
principle is probably not modelled in POV-Ray (unless it works by
fresnel reflection).
I would have thought that for most gamma ray applications you could
ignore reflection, refraction and dispersion and model all your
materials as partially absorbing media. If you set everything except the
photographic plate to be no_image, then the shadows that POV casts on
that plate should correspond to the photographic image that would be
recorded.
Mike Williams
Gentleman of Leisure
Date: 13 Mar 2004 15:06:12
Message: <405369b4@news.povray.org>
>>Hash: SHA1
>>Any thoughts?
> recorded.
The previous post is correct about using grazing mirrors for gamma rays.
  The physical model of how gamma rays interact with matter s very
different than for visible light.  Gamma rays are pentrating radiation
(for non-grazing angles) and how they react with matter depends on their
energies and the composition of the material.  At low energies, gamma
rays can excite one of the inner electrons of the an atom and then when
that electron is filled the atom releases an x-ray.  At moderate
energies (100s of KeV to a few MeV) they are most likely to experience
Compton scattering where the gamma ray transfers some of its energy to
an electron. That is a probabilistic process (both in where in the
material it occurs and the scattering angle) so where POVRay doing
photon mapping can send out one photon and see what happens to it, for
gamma rays you would probably have to send out thousands to get a
representative sample of the possibilities.  In addition after Compton
scattering, that electron may have enough energy to emit additional
radiation (brehmstrahlung) as it slows down in the material.  At higher
energies the gamma ray can also experience pair production where it
spawns an electron-positron pair where the positron will likely
annihilate with an electron emitting more gamma rays (if the electron
has enough energy it will emit radiation too).
So while you could take the POVRay framework and re-write the photon
mapping code to be a gamma mapping program, it would be an enormous
amount of work.  If you're looking for a master's thesis topic, you're
in luck (it may be more work than I think and you can get a Ph.D. out of
it.)
If you want to look into gamma interactions with matter try "Radiation
Detection and Measurement (Third Edition)" by Glenn F. Knoll.  It covers
all types of radiation and detectors, but spends a lot of time on gamma
rays and has good references if you need more detail.  I'd suggest
checking it out of a library since it costs $120.
Good Luck,
Richard Kline
