POV-Ray : Newsgroups : povray.general : Serializing a dictionary Server Time
13 Jan 2026 17:25:28 EST (-0500)
  Serializing a dictionary (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Serializing a dictionary
Date: 7 Jul 2025 12:45:00
Message: <web.686bf940e086e5d13ecaab5e6cde94f1@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> "Bald Eagle" <cre### [at] netscapenet> wrote:
> > Maybe someone can suggest a command-line script to grep opening and closing
> > parentheses and give a count.
> not totally what you're after, ...(no time to write a script, sorry :-))
no script, but a (simple) re-purposed program (named "brace parenthesis bracket
counts"), attached.  compile with:
  $ gcc -std=c99 -O2 -o bpbcounts bpbcounts.c
(sorry, no spreadsheet importer :-))
enjoy, jr.
Download 'bpbcounts.c.txt' (2 KB)
Date: 8 Jul 2025 04:08:56
Message: <686cd218$1@news.povray.org>
> enjoy, jr.
A long time ago, I started doing the same thing (but in Perl). I stopped
because I got stuck on a problem: even if the number of pairs is
correct, the syntax isn't necessarily right. You could be missing a
brace in one place and have one too many in another. All in all, the
count is good, but the syntax is not.
But indeed, this kind of script already gives good indications.
kurtz le pirate
compagnie de la banquise
Download 'analyser.pl.zip' (3 KB)
Date: 9 Jul 2025 00:41:01
Message: <686df2dd$1@news.povray.org>
On 7/7/2025 7:28 AM, Bald Eagle wrote:
> Josh English <Jos### [at] joshuarenglishcom> wrote:
> So, this is a common problem, with start and end bracketing "directives" or
> whatever we call them
> #if #end
> #while #end
> texture {     }
> function {     }
> etc
> I use large (5-space) TABS to maximize the visual placing of the start and end
> of my code blocks.
Yeah, I should get into that practice. I don't do that in any other
language, though, so I suspect an uphill battle.
I might be able to scribble out some Python to do that, come to think of it.
Uncle Josh
Date: 9 Jul 2025 00:43:09
Message: <686df35d$1@news.povray.org>
On 7/7/2025 8:40 AM, jr wrote:
> very good practice/advice.  fwiw, a suitable editor helps, for instance using
> 'vim' makes jumping between opening and closing brace/parenthesis/bracket a
> single (shifted) key press.
I have tried to use vim, but I have fallen into the convenience of the
Run button in the Windows UI. I have a Linux Mint machine but haven't
found a nice workflow with POV-Ray and Vim.
Uncle Josh
Date: 9 Jul 2025 03:30:00
Message: <web.686e1961e086e5d13ecaab5e6cde94f1@news.povray.org>
hi,
kurtz le pirate <kur### [at] freefr> wrote:
> A long time ago, I started doing the same thing (but in Perl). ...
way more ambitious though, line numbers ! :-).  I don't "speak" perl, and ran
into trouble when i tried the script (for which thanks) on a Debian VM; attached
a screenshot.
regards, jr.
Download 'screenshot 2025-07-09 08.18.58.png' (42 KB)
Preview of image 'screenshot 2025-07-09 08.18.58.png'
Date: 9 Jul 2025 03:40:00
Message: <web.686e1bdce086e5d13ecaab5e6cde94f1@news.povray.org>
hi,
> > ... 'vim' makes jumping ... a single (shifted) key press.
looked but cannot, of course, now find the reference. :-)  LeForgeron (I think)
posted an image / chart depicting his setup.  I use the below in my '~/.vimrc',
which is based on / derived from that "tip".  my "workflow" when writing scene
code is to occasionally do a ":make" to confirm there are no typos etc, ie am at
that point only interested in the parsing; for that I have a dedicated
"one-liner" shell script, "povparse", also below.  workflows are v individual,
but LeForgeron's "method" works for me.
regards, jr.
-----<snip>-----
au Filetype pov setlocal makeprg=povparse\ +i%
au Filetype povini setlocal makeprg=povparse\ %
au BufRead,BufNewFile, *.ini set filetype=povini
-----<snip>-----
#!/bin/sh
/usr/bin/nice -n 19 /usr/local/bin/povray-3.8.0-beta.2 +w32 +h32 -d -f -p -gr
-gs $*
Date: 9 Jul 2025 06:55:00
Message: <web.686e49cee086e5d13ecaab5e6cde94f1@news.povray.org>
> a screenshot.
ignore.  the trouble was the 1st line, all good w/out that comment line.
regards, jr.
Date: 10 Jul 2025 10:45:04
Message: <686fd1f0$1@news.povray.org>
On 09/07/2025 09:25, jr wrote:
> hi,
> a screenshot.
> regards, jr.
A yes, the script uses the "File::Basename" module, which is not present
in your system. I use cpan to install/manage modules. More infos here :
<https://wiki.debian.org/PerlFAQ> :.
cpan
install File::Basename
more ambitious : yes, lines numbers, list of vars and where vars are
used. but it's a wip...
kurtz le pirate
Date: 10 Jul 2025 14:35:00
Message: <web.687006aae086e5d13ecaab5e6cde94f1@news.povray.org>
hi,
> > way more ambitious though, line numbers ! :-). ...
agree, a list of the variables and so on is very useful to have, in particular
when "playing" with unfamiliar (someone else's :-)) code.
I don't know MacOS, do you have/use the 'less' and 'vim' programs ?  both can
use  "tags" files created by 'ctags'.  that program, patched[*], can give you
variables, and usage; for instance below the first few lines output based on one
of your scenes (Oct 31st 2023):
$ ectags --sdl-kinds=v -ux pursuitcurve.pov
displayAxis      variable     33 pursuitcurve.pov #declare displayAxis = false;
displayPlane     variable     34 pursuitcurve.pov #declare displayPlane = false;
AxisLen          variable     37 pursuitcurve.pov #declare AxisLen = 16;
Scale            variable     39 pursuitcurve.pov #declare Scale =
AxisLen/image_width;
C                variable    115 pursuitcurve.pov #local C =
_Brightness*_Saturation;
X                variable    116 pursuitcurve.pov #local X = C - (1 -
abs(mod(_Hue/60,2) - 1));
m                variable    117 pursuitcurve.pov #local m = _Brightness-C;
only requesting variables, the '-ux' selects an unsorted cross-reference format
to console/terminal; when invoked without options, it'll write a "tags" file.
[*] <drive.google.com/file/d/10ikrIHkMopedFPlq6V4YhnnNn3sY59hC/view?usp=sharing>
regards, jr.
Date: 11 Jul 2025 11:39:40
Message: <6871303c@news.povray.org>
On 10/07/2025 20:30, jr wrote:
> hi,
Yes, i have less and vim.
I'm not familiar with this type of tags/ctags
I'll take a look.
> regards, jr.
kurtz le pirate
