POV-Ray : Newsgroups : povray.general : Few tricks Server Time
28 Jul 2026 03:25:49 EDT (-0400)
  Few tricks (Message 1 to 9 of 9)
Subject: Few tricks
Date: 26 Nov 2023 04:46:56
Message: <65631410$1@news.povray.org>
Hello,
In my current project, I'm doing a lot of calculations using macros and
functions. I need macros that return several values and a rounding
function. I'm sharing my solutions here (which may already be known to
the Grand Masters).
*** Tips 1 : Rounding ***
#declare pow10 = function(num_digits) {
  prod(i,1,num_digits,10)
#declare fnRound = function (number, num_digits) {
  ceil(number*pow10(num_digits))/pow10(num_digits)
#declare a = fnRound(pi,6); // round pi to 6 digits
#debug concat(str(a,0,9),"\n")
-> 3.141 593 000 (extra spaces added)
Waring : Be careful with the number of digits required, depending on the
precision of the calculations... especially with large numbers.
*** Tips 2 : Multiple return values from macro directly assigned to
variables ***
#declare MyMacro(p1, p2, p3, p4)
  array { Return1, Return2, Return3}
Used in this way :
#declare { V1, V2, V3 } = MyMacro (a, b, c, d);
I hope this helps.
Critical comments welcome !
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Few tricks
Date: 26 Nov 2023 05:10:00
Message: <web.6563188bc0e3ff73f11225116cde94f1@news.povray.org>
hi,
kurtz le pirate <kur### [at] gmailcom> wrote:
> In my current project, ...
> variables ***
> #end
> Used in this way :
> I hope this helps.
puzzled rather than critical :-)  why an array ?  eg
#macro myMacro(p1,p2,p3,p4)
  (ret1, ret2, ret3)
#declare (v,v2,v3) = myMacro(a,b,c,d);
too works.
regards, jr.
Date: 26 Nov 2023 09:10:00
Message: <web.65635113c0e3ff731f9dae3025979125@news.povray.org>
>   (ret1, ret2, ret3)
> #end
> too works.
I used to use arrays, and sometimes vectors for this type of thing before clipka
implemented the tuple-style assignment.
WFP has been uncovering some interesting issues related to the tuple-style
assignment, and may be responsible for many of my hairs being ripped out in
bewilderment and frustration.
With an array, you have a nice, compact method of storing any number of values,
especially when using a mixed array.
Also, depending upon how the rest of the code is written, one can simply
#declare NewArray = MacroGeneratedArray ();
and be done with it.
Probably the most useful thing I can think of, at the moment, is that one can
cycle incrementally through all of the array elements with an iterator, whereas
you can't do any such thing with the tuple-style assignment.
You can also copy the entire array with a single line of code.
As with anything, it all depends on what you're doing, how far ahead you're
thinking, and just individual coding style.
- BW
Date: 27 Nov 2023 05:20:09
Message: <65646d59$1@news.povray.org>
Hi.
Why array ? Because it's the only method I've found that works with any
type of data. I didn't know that POV could use lists (,,,,).
I couldn't find anything in the docs about array* and/or list(tuple).
It also depends on the number of values to be returned. For 3,4,5
values, the list is acceptable and a good choice. Beyond that, an array
is easier to use.
Thanks for your comment.
* : in the context of macro return values, of course ;)
Kurtz le pirate
Date: 27 Nov 2023 06:10:00
Message: <web.65647807c0e3ff731f9dae3025979125@news.povray.org>
https://wiki.povray.org/content/Reference:Declare_and_Local_Directives
https://news.povray.org/povray.news-submissions/thread/%3C558b4c09%241%40news.povray.org%3E/
- BW
Date: 27 Nov 2023 06:45:00
Message: <web.6564801fc0e3ff73f11225116cde94f1@news.povray.org>
hi,
I hadn't known one can split a returned array like that.  </grin>
(also @BE)
> is easier to use.
agree, good for "a few" return values only.
regards, jr.
Date: 27 Nov 2023 07:55:00
Message: <web.65649144c0e3ff7317bac71e8ffb8ce3@news.povray.org>
The array unpacking works well and it looks clean. I mostly use it within
macro's. As soon I create multiple instances "enumerating a struct" works
better, but is less clean.
// PoVRay 3.8 Scene File "goertzel.pov"
// author:  Ingo Janssen
// date:    2023-11-16
// Oscillator that uses 'inverse' Goertzel
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#declare TAU = 2 * pi;
/*Enumerate elements of Goertzel oscillator data structure*/
#declare _gsoMultiplier = 0;
#declare _gsoCurrent = 1;
#declare _gsoPrevious = 2;
#declare _gsoN = 3;
#macro initGSinOsc(Frequency, Phase, SampleRate)
  #local phaseIncrement = Frequency * TAU / SampleRate;
  #local gsoMultiplier = 2 * cos(phaseIncrement);
  #local gsoCurrent = sin(Phase);
  #local gsoPrevious = sin(Phase - phaseIncrement);
  #local gsoN = 0;
  #local GSO = array {gsoMultiplier, gsoCurrent, gsoPrevious, gsoN};
  GSO
// if 3.7
//#macro initGSinOsc(Frequency, Phase, SampleRate)
//  #local GSO = array[4];
//  #local phaseIncrement = Frequency * TAU / SampleRate;
//  #local GSO[_gsoMultiplier] = 2 * cos(phaseIncrement);
//  #local GSO[_gsoCurrent] = sin(Phase);
//  #local GSO[_gsoPrevious] = sin(Phase - phaseIncrement);
//  #local GSO[_gsoN] = 0;
//  GSO
//#end
#macro Next(GSO)
  #local {gsoMultiplier, gsoCurrent, gsoPrevious, gsoN} = GSO;
  #if (gsoN > 0)
    #local d0 = gsoMultiplier * gsoCurrent - gsoPrevious;
    #local gsoPrevious = gsoCurrent;
    #local gsoCurrent = d0;
  #else
    #local gsoN = gsoN + 1;
//if 3.7
//#macro Next(GSO)
//  #if (GSO[_gsoN] > 0)
//    #local d0 = GSO[_gsoMultiplier] * GSO[_gsoCurrent] - GSO[_gsoPrevious];
//    #local GSO[_gsoPrevious] = GSO[_gsoCurrent];
//    #local GSO[_gsoCurrent] = d0;
//  #else
//    #local GSO[_gsoN] = GSO[_gsoN] + 1;
//  #end
//#end
#declare Duration = 1; //sec
#declare SampleRate = 44100;
#declare Ticks = Duration * SampleRate;
#declare Frequency = 440;
#declare Phase = 0;
#declare T0 = datetime(now, "%S")
#declare GSinOsc = initGSinOsc(Frequency, Phase, SampleRate); // here the
unpacking is not usefull.
#declare Garray = array [Ticks];
#for (Tick, 0, Ticks - 1)
  Next(GSinOsc)
  #declare Garray = GSinOsc[_gsoCurrent];
#declare T1 = datetime(now, "%S")
#declare T2 = datetime(now, "%S")
#declare Sarray = array[Ticks];
#declare phaseIncrement = Frequency * TAU / SampleRate;
  #declare Sarray[Tick] = sin(Tick * phaseIncrement);
#declare T3 = datetime(now, "%S")
#debug T0
#debug "\n"
#debug T1
#debug "\n"
#debug T2
#debug "\n"
#debug T3
#debug "\n"
Date: 27 Nov 2023 10:14:40
Message: <6564b260$1@news.povray.org>
> - BW
*Unbelievable*
You know all the pages of the doc on your fingertips ?
Kurtz le pirate
Date: 27 Nov 2023 14:00:00
Message: <web.6564e71fc0e3ff731f9dae3025979125@news.povray.org>
> > - BW
> *Unbelievable*
lol, no - I just have a fairly good idea of where it might be, and have honed my
search skills.
That is, if the damned search feature actually gives me what I'm looking for.
90% of the time I can't even find my own posts on a topic.
- BW
