POV-Ray : Newsgroups : povray.general : sphere_sweep feature request Server Time
7 Oct 2024 09:25:46 EDT (-0400)
  sphere_sweep feature request (Message 1 to 8 of 8)
Subject: sphere_sweep feature request
Date: 29 Mar 2002 12:56:01
Message: <63a9augte30rmdtn5u79efoohua8o3najg@4ax.com>
I wonder if sphere sweep could be defined (in sdl) similiar to blob - with
spheres as components. If sphere_sweep intersection test can calculate radius
for specified intersection then it means it knows t value between noodes. If it
knows t value then it can average pigments of noodes. Probably best explanation
what I mean could be syntax example. I mean something like:
sphere_sweep{
  linear_spline
  sphere{<0,1,2> .1}
  sphere{<0,1,2> .2 pigment{red 1}}
  sphere{<7,6,6> .3 pigment{green 1}}
  sphere{<0,1,2> .4}
  sphere{<0,1,2> .5}
  pigment{blue 1}
Above example creates 4 segments - first goes from blue to red, second goes from
red to green, third goes from green to blue, fourth is completly blue.
Definetly something to try after source release.
ABX
Subject: Re: sphere_sweep feature request
Date: 29 Mar 2002 13:09:00
Message: <3ca4adbc@news.povray.org>
Not only. It would be great if you could scale each sphere and get the scaling
interpolated (for flat wires).
Jonathan.
Date: 29 Mar 2002 15:24:18
Message: <Xns91E0DA22710EBseed7@povray.org>
Interesting. How about turning it into a blob completely, you could do
stuff like in Softy3D.
http://www.softy3d.com/en/index.htm
Ingo
Date: 1 Apr 2002 15:09:39
Message: <3ca8be83$1@news.povray.org>
I've just spent about 10 minutes trying to find this message. Anyway, see
p.b.i..
 -Shay
JRG <jrg### [at] hotmailcom> wrote in message news:3ca4adbc@news.povray.org...
Date: 2 Apr 2002 01:27:39
Message: <4kjiaucmrev0o19320p906d2f75nq0ukaa@4ax.com>
It could be two implementation of sphere sweeps as for sphere and cylinder - as
separated object and as blob component. Moreover with changed inside definition
as I proposed some day it could be probably possible to add every object type as
blob component - then blob would be something like bridge between unions and
isosurfaces.
ABX
Date: 2 Apr 2002 01:31:00
Message: <qujiau4fm40ter5dhrl63htrl425e350nj@4ax.com>
> p.b.i..
nothing related
ABX
Date: 2 Apr 2002 11:58:16
Message: <3ca9e328$1@news.povray.org>
news:qujiau4fm40ter5dhrl63htrl425e350nj@4ax.com...
> nothing related
> ABX
I should have quoted JRG's message in my reply. I posted an image in p.b.i.
of flat wire. JRG had mentioned it in his reply to your original post.
 -Shay
Date: 14 Jul 2002 16:08:53
Message: <1ffbytr.hd749mg5zssgN%jlippert@mac.com>
> goes from red to green, third goes from green to blue, fourth is completly
> blue.
Should be not much of a problem, because just like the x, y, and z
coordinates and the position along the curve, the color could be
parametrized. One implementation problem may be the current separation
between the geometry (shape) and the surface properties (texture etc.).
If someone is bold enough to figure out the source code... 8)
Jochen Lippert
No smilies were harmed in the making of this message ;)
