POV-Ray : Newsgroups : povray.general : Is it possible to reduce colour banding for JPG output? Server Time
15 May 2026 09:01:38 EDT (-0400)
  Is it possible to reduce colour banding for JPG output? (Message 1 to 3 of 3)
Subject: Is it possible to reduce colour banding for JPG output?
Date: 5 Aug 2020 22:45:01
Message: <web.5f2b6da22aa83c09ecc0fada0@news.povray.org>
There are two ways to reduce colour banding in POV-RAY
1. 16-bit depth to have a more accurate spectrum of colours.
2. Dither to fake the colour gradient.
Unfortunately, neither of these methods is available if the output format is
JPG.
If we output a PNG file with +TH, and then, convert it to JPG, the colour
banding disappears.
I wonder why can't we directly save the same effect with JPG output.
Subject: Re: Is it possible to reduce colour banding for JPG output?
Date: 6 Aug 2020 05:40:21
Message: <5f2bd005$1@news.povray.org>
> JPG.
> banding disappears.
You could play with the "Compression" in ini file, to change from the
default 85% quality.
http://wiki.povray.org/content/Reference_Talk:File_Output_Options
Try Compression=100 and see.
About colour bands and other jpeg problem, it is an old story:
https://www.povray.org/documentation/view/3.6.1/169/
Date: 6 Aug 2020 17:55:02
Message: <web.5f2c7bcfd464a2e9ecc0fada0@news.povray.org>
> > JPG.
> > banding disappears.
Thanks for the link. I had not seen it before and learnt from it.
I actually use Compression=100, and the output is visually identical to PNG
(generally >90). The only problem is that colour banding, which is non-existent
in PNG output with +TH.
