POV-Ray : Newsgroups : povray.general : Oblate spheroid cartography Server Time
17 Aug 2025 22:41:41 EDT (-0400)
  Oblate spheroid cartography (Message 1 to 10 of 11)
Subject: Oblate spheroid cartography
Date: 18 Jul 2018 18:00:37
Message: <5b4fb885$1@news.povray.org>
Several types of latitude are described here:
https://en.wikipedia.org/wiki/Latitude
I have a sphere, with a texture of the Earth mapped to it, and
latitude/longitude gridlines overlaid on top.
(See the "Circle of latitude" animation in p.b.a.)
This is easy to do. But what if I want to model the oblateness of the
Earth WRT a true sphere? What if I want to also exaggerate it a great deal?
The naive thing to do would be to simply scale the sphere along the
vertical axes without changing the horizontal axis. This is also pretty
easy to do.
But would it be *more* proper to alter the texture map so that spherical
latitude is converted to geodetic or geographic latitude? I.e. should I
deform the map so that 60 degrees N remains 60 degees N after switching
from a sphere to an oblate spheroid and geodetic latitude?
How do I do this with a texture map? What is the correct way to proceed?
To my eyes, applying the texture map after deforming the sphere looks
the same as applying the texture map before deforming the sphere.
Mike
Subject: Re: Oblate spheroid cartography
Date: 18 Jul 2018 19:05:23
Message: <5b4fc7b3@news.povray.org>
Am 19.07.2018 um 00:02 schrieb Mike Horvath:
Wow. I never imagined latitude was that complex of a topic.
Date: 18 Jul 2018 21:00:00
Message: <web.5b4fe16e32871de6458c7afe0@news.povray.org>
Ah reality.   So many details.
I suppose one should ask if making any corrections is appropriate and necessary,
or overkill for accomplishing the desired goal.
"The difference between the semi-major and semi-minor axes is about 21 km (13
miles) and as fraction of the semi-major axis it equals the flattening; on a
computer monitor the ellipsoid could be sized as 300 by 299 pixels. This would
barely be distinguishable from a 300-by-300-pixel sphere, so illustrations
usually exaggerate the flattening."
"On the reference ellipsoid for WGS84, the centre of the Eiffel Tower has a
define a point on the ground which is 140 metres (460 feet) distant from the
tower.[citation needed] A web search may produce several different values for
the latitude of the tower; the reference ellipsoid is rarely specified."
What's the scale of the scene, and will +/- 460 feet be in any way significant?
Date: 19 Jul 2018 02:46:42
Message: <5b5033d2$1@news.povray.org>
On 19-7-2018 2:55, Bald Eagle wrote:
[snip]
...except as an intellectual exercise? I was going to answer like you
did. I certainly believe that - except for very highly specific and
specialised uses - this would be overkill. Why bother? Because the /true
shape/ of the Earth is not even like that: it looks more like an
(oblate) potato and its generalised, irregular, shape differences are
certainly more than +/- 460 feet.
Date: 19 Jul 2018 16:58:24
Message: <5b50fb70@news.povray.org>
On second appraisal, there is a difference in the texture based on
whether it is applied before or after the sphere is scaled. But it's not
the difference I was expecting...
Mike
Date: 19 Jul 2018 20:40:01
Message: <web.5b512f1132871de6458c7afe0@news.povray.org>
https://www.youtube.com/watch?v=yJZP_-40KVw
You could give one of the authors an email, and see if they have any
suggestions.  They clearly know how to flip around equations for spheres and
geometric inversion like aces.
You might also check out various other fora like Mathematica, stackexchange,
etc. and see if this has been asked and answered there.
Date: 19 Jul 2018 21:12:30
Message: <5b5136fe$1@news.povray.org>
Interesting. Did they use POV-Ray to make the video? It looks very much
like it.
I already mirrored my question to stack exchange. I use that site daily!
Not sure about the mathematica forum. They might be annoyed if I know
nothing about using Mathematica.
Mike
Date: 20 Jul 2018 02:09:55
Message: <5b517cb3$1@news.povray.org>
>> spheres and
> like it.
http://www.dimensions-math.org/Dim_merci_E.htm
Most of the images were created in Povray
Fractal images were created in Ultrafractal
The whole series is worth watching. Even if just for the graphics and
the smoothness of the animations.
IIRC They made an announcement on the newsgroups. When they released the
videos.
>> stackexchange,
You got a really helpful answer from amd
> Mike
Regards
Date: 20 Jul 2018 03:32:38
Message: <5b519016$1@news.povray.org>
>> daily! Not sure about the mathematica forum. They might be annoyed if
>> I know nothing about using Mathematica.
Yeah... I get that a lot. The people on stack exchange don't want to
answer questions that don't garner them lots of points I think. (I'm not
sure what their business model is.) Or they don't explain how to improve
a question before closing/holding it.
Mike
Date: 20 Jul 2018 06:42:37
Message: <5b51bc9d$1@news.povray.org>
They need to grow up and stop thinking of themselves as cleaver. ;)
Regards
