POV-Ray : Newsgroups : povray.general : qtpovray-3.80.1 for Linux Server Time
21 May 2024 13:01:33 EDT (-0400)
  qtpovray-3.80.1 for Linux (Message 18 to 27 of 37)
Subject: Re: qtpovray-3.80.1 for Linux
Date: 31 Jul 2018 07:32:29
Message: <5b6048cd$1@news.povray.org>
Am 31.07.2018 um 12:03 schrieb hugo giulietti:
> Hello,
> I installed qtpovray in my lubuntu 16.04 using the ppa for automatic updates.
> After my first test using "optics.pov" i got this parse error from the povray's
output:
> "Parse Error: Macros require #version 3.1 or later but #version 3.00 is set.
> at File: colors.inc Line: 167 Col: 2"
> Very rare message. The colors.inc file is standard; i have not touched in any way. I
don't know how to fix this because the #version directive was not modified at all.
That's seriously odd. Please verify that line 13 of `colors.inc` reads
`#version 3.5;`
If that's not the case, for some obscure reason you have a far outdated
version of the file.
Date: 31 Jul 2018 07:44:04
Message: <5b604b84$1@news.povray.org>
>> Hello,
> `#version 3.5;`
Also check the environment variable POVINI is not pointing at an old
povray.ini file which might itself be pointing to old include libraries.
'echo $POVINI' in an xterm window to check.
Bill P.
Date: 31 Jul 2018 07:49:07
Message: <20180731084906.130890b03b730c9b99252e92@gmail.com>
It reads #version 3.5
xD I installed qtpovray just 2-3 hours ago! It's updated! (i hope so...)
I have not modified anything. Just run a test and the error comes up into the command
output.
Date: 31 Jul 2018 08:03:19
Message: <20180731090319.60adb1878e31282ab5044805@gmail.com>
I think that qtpovray is using the pre-configured default path
/usr/share/qtpovray-3.8/include
Also, the error is indicating the reserved word "Macro" at column 2 requires a version
 >= 3.0 but version in use is 3.7
On Tue, 31 Jul 2018 07:44:04 -0400
> >> Hello,
> > `#version 3.5;`
> Bill P.
Date: 31 Jul 2018 08:38:27
Message: <20180731093826.51d28b24aa8e7f13c7183a15@gmail.com>
On second test, using "cornell.pov" (it is not using "includes") the output says that
i am using
an old version but the actual version is 3.7.
The output result cornell.png is a pure black image.
Here is the output command pane:
chdir:  /home/hugo/source/povray
command:  +Icornell.pov
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.9606898.unofficial
This is an unofficial version compiled by:
 Dick Balaska - qtpovray edition <dic### [at] buckosoftcom>
 The POV-Ray Team is not responsible for supporting this version.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2018 Persistence of Vision Raytracer Pty. Ltd.
Primary Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.9606898.unoffic
ial Architects/Developers: (Alphabetically)
  Chris Cason         Thorsten Froehlich  Christoph Lipka
With Assistance From: (Alphabetically)
  Nicolas Calimet     Jerome Grimbert     James Holsenback    Christoph Hormann
  Nathan Kopp         Juha Nieminen       William F. Pokorny
Past Contributors: (Alphabetically)
  Steve Anger         Eric Barish         Dieter Bayer        David K. Buck
  Nicolas Calimet     Chris Cason         Aaron A. Collins    Chris Dailey
  Steve Demlow        Andreas Dilger      Alexander Enzmann   Dan Farmer
  Thorsten Froehlich  Mark Gordon         Jerome Grimbert     James Holsenback
  Christoph Hormann   Mike Hough          Chris Huff          Kari Kivisalo
  Nathan Kopp         Lutz Kretzschmar    Christoph Lipka     Jochen Lippert
  Pascal Massimino    Jim McElhiney       Douglas Muir        Juha Nieminen
  Ron Parker          William F. Pokorny  Bill Pulver         Eduard Schwan
  Wlodzimierz Skiba   Robert Skinner      Yvo Smellenbergh    Zsolt Szalavari
  Scott Taylor        Massimo Valentini   Timothy Wegner      Drew Wells
  Chris Young
Other contributors are listed in the documentation.
Support libraries used by POV-Ray:
  ZLib 1.2.8, Copyright 1995-2012 Jean-loup Gailly and Mark Adler
  LibPNG 1.2.54, Copyright 1998-2012 Glenn Randers-Pehrson
  LibJPEG 8, Copyright 1991-2016 Thomas G. Lane, Guido Vollbeding
  LibTIFF 4.0.6, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
  Boost 1.58, http://www.boost.org/
  OpenEXR 2.2.0 and IlmBase 2.2.0, Copyright (c) 2002-2011 Industrial Light &
 Magic.
Parser Options
  Input file: cornell.pov
  Remove bounds........On
  Split unions.........Off
  Library paths:
  Clock value:    0,000  (Animation off)
Image Output Options
  Image resolution.....800 by 600 (rows 1 to 600, columns 1 to 800).
  Output file..........cornell.png, 24 bpp PNG
  Dithering............Off
  Graphic display......On  (gamma: sRGB)
  Mosaic preview.......Off
  Continued trace......Off
Information Output Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parse Warning: The scene finished parsing with a language version set to v3.1 or
earlier. Full backward compatibility with scenes requiring support for bugs in POV-Ray
version v3.1 or earlier is not guaranteed. Please use POV-Ray v3.5 or earlier if your
scene depends on rendering defects caused by these bugs.
Parser Statistics
Finite Objects:           31
Infinite Objects:          0
Light Sources:             9
Total:                    40
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.001 seconds)
              using 1 thread(s) with 0.-01 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........Off
Render Statistics
Image Resolution 800 x 600
Pixels:           480000   Samples:               0   Smpls/Pxl: 0,00
Rays:             480000   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                               2031            2031    100,00
Triangle                        832055          443671     53,32
Bounding Box                   7826984         2598210     33,20
Render Time:
  Photon Time:      No photons
  Radiosity Time:   No radiosity
  Trace Time:       0 hours  0 minutes  1 seconds (1.827 seconds)
              using 4 thread(s) with 0.-04 CPU-seconds total
POV-Ray finished
On Tue, 31 Jul 2018 07:03:38 -0300
hugo giulietti <hug### [at] gmailcom> wrote:
> Hello,
output:
Date: 31 Jul 2018 13:23:18
Message: <5b609b06@news.povray.org>
that i am using
> Render Time:
> POV-Ray finished
Very strange. cornel.pov IS a radiosity scene, but it say "No radiosity".
Make sure to add
#version 3.7;
or
#version version;
as the first line of your scene.
Date: 31 Jul 2018 15:45:06
Message: <5b60bc42$1@news.povray.org>
Am 31.07.2018 um 14:03 schrieb hugo giulietti:
version  >= 3.0 but version in use is 3.7
Technically, the `#version` setting at the point in question is (or
should be) 3.5.
Date: 31 Jul 2018 15:49:29
Message: <5b60bd49$1@news.povray.org>
Am 31.07.2018 um 13:49 schrieb hugo giulietti:
Then the error shouldn't be happening. Are you sure that's indeed the
very file that is pulled in?
Please try adding the following line just below the `#version 3.5;` in
`colors.inc`:
    #debug concat("version in colors.inc is ",str(version,0,2),"\n")
Then try again rendering `optics.pov`. You should get a message reading
`version in colors.inc is 3.50`.
If the message doesn't appear, a different `colors.inc` is pulled in.
Date: 31 Jul 2018 17:49:31
Message: <20180731184930.19e44cede92373510b900554@gmail.com>
Confirmed using /usr/share/qtpovray-3.8/include/colors.inc
The message does appear and say :
version in colors.inc is 3,00
Fatal error in parser: Cannot parse input.
Render failed
On Tue, 31 Jul 2018 21:49:29 +0200
Date: 31 Jul 2018 18:04:39
Message: <20180731190438.ca5fd6d46e87734489f09940@gmail.com>
It is my fault, Alain. I did not mention that the scene file was refused to
 render because some radiosity's declarations; so i deleted all the "radios
ity{}" block and reder again just for confirm the "#version" issue
BUT if i re-render the scene file *with* "radiosity{}" block empty,  the th
ings does not changes in any way.
On Tue, 31 Jul 2018 13:25:44 -0400
tput says that i am using
> > Render Time:
> > POV-Ray finished
> Make sure to add
> #version 3.7;
> or
> #version version;
