POV-Ray : Newsgroups : povray.general : Radial intersection Server Time
10 Jun 2024 15:30:31 EDT (-0400)
  Radial intersection (Message 1 to 4 of 4)
Subject: Radial intersection
Date: 17 Jul 2018 17:32:34
Message: <5b4e6072$1@news.povray.org>
I am trying to create an intersection that spins around the vertical
axis, like this:
https://i.stack.imgur.com/xT5W9.jpg
except extruded along the y axis.
How would I go about creating this? I tried making an intersection of
planes, but it only works between 0 and 180 degrees. Any more than that
and it behaves strangely.
#declare plane_wedge = intersection
	plane {-x, 0}
	plane {+x, 0	rotate y * 270}
	pigment {color srgb <1,2/4,0>}
Thanks.
Mike
Subject: Re: Radial intersection
Date: 17 Jul 2018 18:05:00
Message: <web.5b4e6726bd76eff3458c7afe0@news.povray.org>
Insert menu
Shapes3
Segment of cylinder ring.
Make inner radius 0
Date: 17 Jul 2018 19:26:03
Message: <5b4e7b0b$1@news.povray.org>
On 7/17/2018 6:01 PM, Bald Eagle wrote:
> Insert menu
> Shapes3
> Make inner radius 0
The problem with this shape is that when I set the rotation to zero the
shape should *disappear* completely. Instead, it *appears* completely.
Mike
Date: 17 Jul 2018 20:10:35
Message: <5b4e857b$1@news.povray.org>
Never, mind. The shape can't tell the difference between 0 degrees and
360 degrees, so it's actually better it defaults to *visible*. I can add
additional code to hide the shape when I need it.
Mike
>> Insert menu
>> Shapes3
>> Make inner radius 0
> Mike
