POV-Ray : Newsgroups : povray.general : Map of Earth Server Time
29 Mar 2026 23:13:41 EDT (-0400)
  Map of Earth (Message 1 to 10 of 10)
Subject: Map of Earth
Date: 17 Jul 2018 12:16:20
Message: <5b4e1654$1@news.povray.org>
Can anyone recommend a good map of Earth that I can wrap around a
sphere? It should not be photorealistic, but rather be a monochromatic
political map like some of these:
https://www.istockphoto.com/illustrations/world-map?excludenudity=true&sort=mostpopular&mediatype=illustration&phrase=world%20map
Thanks.
Subject: Re: Map of Earth
Date: 17 Jul 2018 12:20:28
Message: <5b4e174c$1@news.povray.org>
Here's another nice example:
https://www.jasondavies.com/maps/rotate/
Not sure if a bitmap image can be extracted from it.
Mike
Date: 17 Jul 2018 14:15:32
Message: <5b4e3244$1@news.povray.org>
> Thanks.
Yes, I just recently searched such map.
The projection to use is type 1,
https://commons.wikimedia.org/wiki/File:BlankMap-FlatWorld6.svg
From that page you can download classical bitmap (png) and be happy.
Date: 17 Jul 2018 16:39:12
Message: <5b4e53f0$1@news.povray.org>
Thanks!
The notes on that page say that the Robinson projection was used. Would
equirectangular projection be better?
Mike
>> Thanks.
Date: 17 Jul 2018 17:16:59
Message: <5b4e5ccb$1@news.povray.org>
I went ahead and created this one instead.
https://commons.wikimedia.org/wiki/File:World_map_nations_mono.svg
Mike
On 7/17/2018 4:40 PM, Mike Horvath wrote:
> Thanks!
> Mike
>>> Thanks.
Date: 17 Jul 2018 17:20:14
Message: <5b4e5d8e$1@news.povray.org>
Le 17/07/2018 à 22:40, Mike Horvath a écrit :
> Thanks!
Yes, Let me look at it tomorrow, I have one map that really work, that
one looks like the right one, but I need to check the file on the other
computer.
The map for type 1 is typically platecarrée. (which is equirectangular),
even if the ratio is actually irrelevant, because povray put everything
in 0..1 range for both coordinates. At least it gives the same
resolution at the equator for both direction.
But Robinson is round on the sides, So the comments are suspect.
https://en.wikipedia.org/wiki/Robinson_projection
More about the map I found and use tomorrow.
> Mike
>>> Thanks.
Date: 17 Jul 2018 17:25:42
Message: <5b4e5ed6$1@news.povray.org>
> Mike
I couldn't use it, due to permissions.
Date: 17 Jul 2018 17:28:41
Message: <5b4e5f89$1@news.povray.org>
>> Mike
That's unfortunate, sorry. I am using it for Wikipedia, so the license
is not a problem for me.
Mike
Date: 18 Jul 2018 02:30:49
Message: <5b4ede99$1@news.povray.org>
>>> Mike
> Mike
If you or someone else ever need a public domain world map,
https://commons.wikimedia.org/wiki/File:World_location_map.svg
It's the one I used.
It has the correct ratio (2:1) and is equirectangular.
But is not B&W
Date: 18 Jul 2018 16:11:08
Message: <5b4f9edc$1@news.povray.org>
>>>> Mike
>> Mike
> But is not B&W
Oh wow! I should have seen that one first. Even better!
It's pretty easy to turn it into a monochrome version in Inkscape.
Mike
