POV-Ray : Newsgroups : povray.general : Light and dark Server Time
18 Aug 2025 09:00:14 EDT (-0400)
  Light and dark (Message 1 to 7 of 7)
Subject: Light and dark
Date: 6 Apr 2018 13:20:48
Message: <5ac7ac70$1@news.povray.org>
I'm trying to capture a shadow of an object that I will later process in
GIMP. I want the shadow to be perfectly black, and the rest of the image
to be perfectly white. (A bit of anti-aliasing is fine.)
How can I accomplish this? I have a white plane, but it ends up slightly
darker than white. Also, the shadow is a bit lighter than black.
Thanks!
Mike
Subject: Re: Light and dark
Date: 6 Apr 2018 13:50:54
Message: <5ac7b37e$1@news.povray.org>
> Thanks!
> Mike
I forgot to add that the light source is at a 60 degree angle to the
ground plane.
Mike
Date: 6 Apr 2018 13:56:32
Message: <5ac7b4d0$1@news.povray.org>
Am 06.04.2018 um 19:20 schrieb Mike Horvath:
There are a couple of factors that may contribute to your white plane
not looking Pearly White(tm):
(1) The pigment may be non-white. Make sure to use `rgb 1`.
(2) The `diffuse` parameter may be set too low. Make sure to use
`diffuse 1` (and while I normally advocate using `diffuse albedo FLOAT`,
in this particular context I deliberately don't).
(3) The light source may not be directly overhead. In that case, make
sure to use `brilliance 0` in the finish.
Alternatively, just crank up the light source brightness to some
insanely high value ;)
As for the shadow not looking pitch black, this is most certainly due to
the `ambient` setting. Make sure to use `ambient 0`. (Also, make sure
you are not using radiosity.)
Date: 6 Apr 2018 13:58:50
Message: <5ac7b55a$1@news.povray.org>
> Thanks!
> Mike
Disregard.
I set the background to 0 and the white plane's diffuse to 2, and I am
getting desired results now.
Mike
Date: 6 Apr 2018 14:15:51
Message: <5ac7b957$1@news.povray.org>
>> in GIMP. I want the shadow to be perfectly black, and the rest of the
>> image to be perfectly white. (A bit of anti-aliasing is fine.)
>> slightly darker than white. Also, the shadow is a bit lighter than black.
>> Thanks!
>> Mike
> Disregard.
> Mike
I discovered a problem with increasing diffuse past 1.
At high diffuse values (for instance `diffuse 200`), the border of the
shadow is no longer "fuzzy" with some gray pixels as a result of
anti-aliasing. Instead, the border is extremely sharp, with black
bordering directly on white.
So I changed the diffuse of the white plane from `2` to `1/sind(60)`,
where `60` is the angle of the light source above the plane.
Not sure if this is the correct workaround, mathematically.
Mike
Date: 6 Apr 2018 14:24:40
Message: <5ac7bb68$1@news.povray.org>
The `ambient` of the plane is 0, and the light source is `rgb 1`.
I did not know about changing `brilliance`. That seems to have fixed the
problem, too.
Thanks!
Mike
Date: 6 Apr 2018 21:43:59
Message: <5ac8225f@news.povray.org>
>>> black.
>>> Thanks!
>>> Mike
>> Disregard.
>> Mike
> Mike
It' beter to use that texture:
texture{
  pigment{rgb 1}
  finish{ambient 0 diffuse 1 brilliance 0}
brilliance 0 make the illumination direction independent.
