POV-Ray : Newsgroups : povray.general : ERROR: no matching } in object, object found instead Server Time
29 Sep 2024 02:16:58 EDT (-0400)
  ERROR: no matching } in object, object found instead (Message 1 to 6 of 6)
Subject: ERROR: no matching } in object, object found instead
Date: 29 Jan 2018 05:25:10
Message: <5a6ef686$1@news.povray.org>
Why am I getting an error "no matching } in object, object found instead"?
#version 3.7;
#declare MyRadiosity = on;
#declare MyClouds = off;
#declare MyLight = on;
#declare MySuns = off;
#declare MyForest = off;
#declare MyPlanet = off;
#declare MyAir = off;
#declare MyTowers = off;
#declare MyBubble = on;
#declare MyBubbleTextures = off;
#declare MyNature = pigment { color rgb < 0.16863,  0.32941,  0.070588 > };
global_settings
 assumed_gamma 1.4
 #if(MyRadiosity=on)
  radiosity
   media on
//   pretrace_start 0.08
//   pretrace_end   0.001
   count 400
//   error_bound 0.75
//   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#default
 finish { ambient 0.0 diffuse 1.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
#include "functions.inc"
#include "shapes.inc"
light_source
 < -3000, 1000, -3000 >
 color rgb < 0.7019608,  0.9490196,  0.4509804 >
camera
 location  < -3.0 , 0.0 , -5.0 >
 look_at   < 0.0 , 0.0 , 0.0 >
// Element ---------------------------------------------------------------
#declare Element = union
 union
  torus
   0.425, 0.075
   rotate < 0.0, 0.0, 90.0 >
   scale < 4.5, 1.125, 1.125 >
  torus
   0.425, 0.075
   translate < -0.25, 0.0, 0.0 >
  torus
   0.425, 0.075
   translate < 0.25, 0.0, 0.0 >
  texture
   pigment
    onion
    color_map
     [ 0.0 color rgb 1 ]
     [ 1.0 color rgb < 0.075,  0.0751,  0.075 > ]
    scale 0.6000
   normal
    granite 0.15 scale 1.0
   finish { phong 0.1 }
 union
  cylinder { < -0.323, 0.0, 0.0 > < -0.322, 0.0, 0.0 > 0.425 }
  cylinder { <  0.323, 0.0, 0.0 > <  0.322, 0.0, 0.0 > 0.425 }
  texture
   pigment
    onion
    color_map
     [ 0.0 color rgbt < 0.7764706,  0.8941176,  0.545098, 0.45 > ]
     [ 1.0 color rgbt < 0.075,  0.0755,  0.075, 0.45 > ]
    scale 0.52
   normal
 sphere
  < 0.0, 0.0, 0.0 > 0.315
  scale < 1.0, 1.0, 1.0 >
  texture
   pigment
    onion
    color_map
     [ 0.0 color rgb < 0.5019608,  0.772549,  0.227451 > ]
     [ 1.0 color rgb < 0.5019608,  0.772549,  0.227451 > ]
    scale 0.52
   normal
    granite 0.75 scale 0.5
#macro MyOrbisiana(MyRandomizer)
 #declare MyRandomer = seed (MyRandomizer);
 #declare MyLength   = int(rand(MyRandomer)*200);   // Anzahl der Glieder
 #declare MyNegative = rand(MyRandomer);
 #if(MyNegative<0.5)
  #declare Negative = -1;
 #else
  #declare Negative =  1;
 #declare MyX        = rand(MyRandomer)*04*Negative;
 #declare MyY        = rand(MyRandomer)*01*Negative;
 #declare MyZ        = rand(MyRandomer)*00*Negative;
 #declare MyPosition = 0.00;
 #declare MyElement  = 0;
 #while (MyElement<MyLength)
  object { Element translate < 0.0, 0.0, MyPosition > rotate < MyX, MyY,
MyZ > }
  #if(MyNegative<0.5)
  #else
  #declare MyX        = MyX+rand(MyRandomer)*04*Negative;
  #declare MyY        = MyY+rand(MyRandomer)*01*Negative;
  #declare MyZ        = MyZ+rand(MyRandomer)*00*Negative;
  #declare MyPosition = MyPosition+0.925;
  #declare MyElement  = MyElement+1;
// Water -----------------------------------------------------------------
background { color rgb < 0.1843137,  0.4666667,  0.5490196 > * 0.5 }
#declare ThisRandom   = seed (27053);
#declare ThisNegative = rand(ThisRandom);
#if(ThisNegative<0.5)
 #declare ANegative   = -1;
#else
 #declare ANegative   =  1;
#declare ThisX        = rand(ThisRandom)*02*ANegative;
#declare ThisY        = rand(ThisRandom)*05*ANegative;
#declare ThisZ        = rand(ThisRandom)*02*ANegative;
#declare ThisPX       = rand(ThisRandom)*50*ANegative;
#declare ThisPY       = rand(ThisRandom)*50*ANegative;
#declare ThisPZ       = rand(ThisRandom)*50*ANegative;
#declare ThisLife     = int(rand(ThisRandom)*50);   // Anzahl der
Orbisianas
#declare ALife        = 0;
#while (ALife<ThisLife)
 #declare MyRandom     = int(rand(ThisRandom)*1000);
 object { MyOrbisiana(MyRandom) rotate < MyX, MyY, MyZ > translate <
ThisPX, ThisPY, ThisPZ > }
 #declare ThisX        = ThisX+(rand(ThisRandom)*02*ANegative);
 #declare ThisY        = ThisY+(rand(ThisRandom)*05*ANegative);
 #declare ThisZ        = ThisZ+(rand(ThisRandom)*02*ANegative);
 #declare ThisPX       = ThisPX+(rand(ThisRandom)*50*ANegative);
 #declare ThisPY       = ThisPY+(rand(ThisRandom)*50*ANegative);
 #declare ThisPZ       = ThisPZ+(rand(ThisRandom)*50*ANegative);
 #declare ALife        = ALife+1;
Subject: Re: ERROR: no matching } in object, object found instead
Date: 29 Jan 2018 05:51:09
Message: <5a6efc9d$1@news.povray.org>
Commenting out the line below allows the script to run.
So you can take it from there. I'm not very good with macros. It looks
complicated to me.
// object { MyOrbisiana(MyRandom) rotate < MyX, MyY, MyZ > translate <
Regards
Date: 29 Jan 2018 11:11:40
Message: <5a6f47bc$1@news.povray.org>
Am 29.01.2018 um 11:51 schrieb Stephen:
>> instead"?
> complicated to me.
MyOrbisiana(R) essentially "unrolls"
    object { ... }
    object { ... }
etc., so the above line "unrolls" to
    object {
      object { ... }
      object { ... }
You can't have multiple `object` statements in an `object` block. You
probably want a `union` somewhere.
Date: 31 Jan 2018 17:44:04
Message: <5a7246b4$1@news.povray.org>
>>> instead"?
>> complicated to me.
>     object { ... }
>     object { ... }
>     object {
>       object { ... }
>       object { ... }
Yes, Clipka, you are right, once more. I see what you mean. Great
advise, very helpful, and i really thank you for this advise, highly
appreciated.
I made a change to the scene, and put the macro object inside a union,
with the result that the scene now functions but nothing than the
background appears on the screen. :-D
Here's the updated scene code on which I am breaking and smashing my brain:
#version 3.7;
global_settings
 assumed_gamma 1.4
 #if(MyRadiosity=on)
  radiosity
   media on
   count 400
//   error_bound 0.75
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#default
light_source
camera
 union
  torus
   0.425, 0.075
  torus
   0.425, 0.075
  torus
   0.425, 0.075
  texture
   pigment
    onion
    color_map
     [ 0.0 color rgb 1 ]
    scale 0.6000
   normal
 union
  texture
   pigment
    onion
    color_map
    scale 0.52
   normal
 sphere
  texture
   pigment
    onion
    color_map
    scale 0.52
   normal
 #if(MyNegative<0.5)
 #else
 union
MyY, MyZ > }
   #if(MyNegative<0.5)
   #else
#else
Orbisianas
#declare ALife        = 0;
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 31 Jan 2018 17:51:45
Message: <5a724881$1@news.povray.org>
appreciated.
with the result that the scene now functions. However, I am not getting
wavy lines. This is a problem of the rotate and translate values, I
guess. my aim is to get many differently curved, wavy lines in the
image, of different lengths. At the moment, the individual parts of each
chain don't even touch each other.#version 3.7;
global_settings
 assumed_gamma 1.4
 #if(MyRadiosity=on)
  radiosity
   media on
   count 400
//   error_bound 0.75
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#default
light_source
camera
 union
  torus
   0.425, 0.075
  torus
   0.425, 0.075
  torus
   0.425, 0.075
  texture
   pigment
    onion
    color_map
     [ 0.0 color rgb 1 ]
    scale 0.6000
   normal
 union
  texture
   pigment
    onion
    color_map
    scale 0.52
   normal
 sphere
  texture
   pigment
    onion
    color_map
    scale 0.52
   normal
 #if(MyNegative<0.5)
 #else
 union
MyY, MyZ > }
   #if(MyNegative<0.5)
   #else
#declare ThisRandom   = seed (29053);
#else
#declare ThisPX       = rand(ThisRandom)*5*ANegative;
#declare ThisPY       = rand(ThisRandom)*5*ANegative;
#declare ThisPZ       = rand(ThisRandom)*5*ANegative;
Orbisianas
#declare ALife        = 0;
 #declare ThisPX       = ThisPX+(rand(ThisRandom)*3*ANegative);
 #declare ThisPY       = ThisPY+(rand(ThisRandom)*3*ANegative);
 #declare ThisPZ       = ThisPZ+(rand(ThisRandom)*3*ANegative);
http://www.avg.com
Date: 31 Jan 2018 18:07:38
Message: <5a724c3a$1@news.povray.org>
appreciated.
chain don't even touch each other. But that is another kind of problem,
I will open a new thread for that.
http://www.avg.com
