POV-Ray : Newsgroups : povray.general : Procedural realistic mountain ranges? Server Time
12 Jul 2025 20:49:36 EDT (-0400)
  Procedural realistic mountain ranges? (Message 16 to 25 of 35)
Subject: Re: Procedural realistic mountain ranges?
Date: 29 Dec 2017 14:30:00
Message: <web.5a4697907060b52089df8d30@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> On 28/12/2017 09:19, clipka wrote:
> > "new WinXP"???
> > Ouch.
> Some people keep things that work.
> Going from Leroy's site. It was new in 2006
I wish I still had mine. :-(  It was ... STABLE. And a workhorse. But the stupid
crummy power supply eventually fried the motherboard. (an Emachines computer,
BTW.)
Date: 29 Dec 2017 20:21:30
Message: <5a46ea1a@news.povray.org>
Hi(gh)!
Am 29.12.2017 um 16:42 schrieb clipka:
> Absolutely. Everything you can use in a pigment, eval_pigment() will
> handle correctly - for technically feasible definitions of "correctly".
Obviously not, at least not with POV-Ray for Windows... I used a 16-bit
PNG generated with Wilbur to be parsed to a spherical mesh2 with this
script:
// beginning of code
#include "functions.inc"
#declare xx=1024;
#declare yy=512;
#declare minrad=22;
#declare maxrad=38;
#declare AsteroidRelief =
pigment
   image_map { tga "asteroid1.tga" }
#declare vertices=2+xx*(yy-2);
#fopen asteroid_mesh_inc "asteroid_mesh.inc" write
#write (asteroid_mesh_inc,
         "#declare asteroid_mesh =\n
         mesh2\n
         {\n
           vertex_vectors\n
           {\n",
             vertices,"\n",
             <0, -35.678431, 0>," // south pole \n") // number of
vertices: 2+b*(a-2) [2+xx*(yy-2)]
#declare a=1;
#while (a<yy-1)
   #declare b=0;
   // #declare rdcum = 0;
   #while (b<xx)
     #declare redval=eval_pigment(AsteroidRelief, <(0.5+b)*(1/xx),
(0.5+a)*(1/yy), 0>).red * (maxrad-minrad);
     #declare greenval=eval_pigment(AsteroidRelief, <(0.5+b)*(1/xx),
(0.5+a)*(1/yy), 0>).green * ((maxrad-minrad)/255);
     #declare rd=minrad+redval+greenval;
     /* #if (a=1 | a=yy-2)
       #declare rdcum=rdcum+rd;
     #end */
(rd*<sin(radians(b*(360/xx)))*cos(radians(-90+a*(180/(yy-2)))),
sin(radians(-90+a*(180/(yy-2)))),
cos(radians(b*(360/xx)))*cos(radians(-90+a*(180/(yy-2))))>)," // ",rd,"\n")
     #declare b=b+1;
   #declare a=a+1;
#write (asteroid_mesh_inc, <0, 35.741176, 0>,"// north pole\n
                         }\n
                         face_indices\n
                         {\n",
                            xx*2+xx*2*(yy-3),"\n") // number of faces:
b*2+b*2*(a-3) [xx*2+xx*2*(yy-3)]
#declare a=0;
#while (a<yy-1)
   #declare b=0;
   #while (b<xx)
     #switch (a)
       #case (0)
         #if (b < xx-1)
           #write (asteroid_mesh_inc, <0, a+1+b, a+1+mod(b+1,xx)>, "\n")
// b faces, all sharing first vertex (#0)
         #else
           #write (asteroid_mesh_inc, <0, a+1+b, 1>, "\n" // last
triangle connecting to first one
       #break
       #range (1, yy-3)
         #if (b < xx-1)
           #write (asteroid_mesh_inc, <1+(a-1)*xx+b,
1+(a-1)*xx+mod(b+1,xx), 1+a*xx+b>,",",<1+a*xx+b, 1+a*xx+mod(b+1,xx),
1+(a-1)*xx+mod(b+1,xx)>, "\n") // b*2*(a-3) faces
         #else
           #write (asteroid_mesh_inc, <1+(a-1)*xx+b, 1+(a-1)*xx,
1+a*xx+b>,",",<1+a*xx+b, 1+(a-1)*xx, 1+a*xx>, "\n") // last pair of
triangles in row connecting to first pair
       #break
       #case (yy-2)
         #if (b < xx-1)
1+(a-1)*xx+mod(b+1,xx), vertices-1>) // b faces, all sharing last vertex
         #else
vertices-1> // last triangle connecting to first one
       #break
     #declare b=b+1;
   #declare a=a+1;
#write (asteroid_mesh_inc, "  }\n}")
#fclose asteroid_mesh_inc
// end of code
It seemed to parse correctly - but POV-Ray crashed immediately
afterwards, regardless how big or small values I used for xx and yy. I
didn't try yet whether it still produced a valid mesh2 - but I don't
think so.
See you in Khyberspace!
Yadgar
Date: 30 Dec 2017 07:35:40
Message: <5a47881c$1@news.povray.org>
Am 30.12.2017 um 02:21 schrieb Jörg 'Yadgar' Bleimann:
> script:
https://youtu.be/tc2tDFPlyWY?t=1h51m5s
/Some/ day I'll teach you folks to specify the version number when
reporting an issue ;)
> think so.
If the scene parses, it's not an issue with `eval_pigment()`, as that's
called during parsing. Rather, the /scene/ created must have some
problematic properties.
Also, that's a TGA file you're using there, not PNG ;)
To further diagnose the issue, I'd probably need a copy of the image.
Date: 30 Dec 2017 11:00:39
Message: <5a47b827$1@news.povray.org>
> reporting an issue;)
That's a bit subtle, for us.
Just say what you mean before we grow beards. ;)
Regards
Date: 30 Dec 2017 20:26:07
Message: <5a483caf@news.povray.org>
If you don't provide the version number, there is no way to know if the
issue is an old one, maybe already fixed in later version, or a new one
accidentally introduced.
Where you using version 3.5, 3.6, 3.7, the latest test build...?
Date: 30 Dec 2017 21:16:01
Message: <5a484861$1@news.povray.org>
Am 30.12.2017 um 17:00 schrieb Stephen:
"Ich verlange ordentliche Meldungen, verdammt nochmal!" is the quote of
the day for Yadgar.
As for you Tommies, ask the folks at Bletchley Park to deciper it :P
https://youtu.be/a5T7LPYVo0Q?t=2h7m34s
https://youtu.be/7pzKyeIex2Y?t=1m5s
Date: 31 Dec 2017 04:29:49
Message: <5a48ae0d$1@news.povray.org>
> the day for Yadgar.
Oh! dear. A year ago we could have asked Dr John. :(
See! I was paying attention.
Regards
Date: 31 Dec 2017 07:50:34
Message: <5a48dd1a$1@news.povray.org>
Am 31.12.2017 um 10:29 schrieb Stephen:
>> the day for Yadgar.
"I demand proper [damage] reports, dammit!"
Date: 31 Dec 2017 14:05:22
Message: <5a4934f2$1@news.povray.org>
>>> the day for Yadgar.
So you have said. But you missed that little word that every good boy
uses. "Please!"
Now is that so hard? :P
Regards
Date: 31 Dec 2017 17:59:09
Message: <5a496bbd$1@news.povray.org>
Am 31.12.2017 um 20:05 schrieb Stephen:
> uses. "Please!"
"I demand you do as I please me, dammit!"
That better? ;)
