POV-Ray : Newsgroups : povray.general : How to? light_source shining through a wall Server Time
25 May 2024 17:20:09 EDT (-0400)
  How to? light_source shining through a wall (Message 21 to 30 of 30)
Subject: Re: How to? light_source shining through a wall
Date: 10 Nov 2017 02:37:16
Message: <5a05572c@news.povray.org>
On 9-11-2017 19:02, Stephen wrote:
> On 09/11/2017 16:39, Kenneth wrote:
>> Hmm, time to protest!! "I demand ladies in black leather!".
> You and me too. ;-)
I agree. This is pure gender discrimination!  ;-)
Date: 10 Nov 2017 02:39:34
Message: <5a0557b6$1@news.povray.org>
On 9-11-2017 15:40, Bald Eagle wrote:
> clipka <ano### [at] anonymousorg> wrote:
>> Uh... and what exactly would "not cast shadows" do, if not make the
>> object "transparent to the light [directly from light sources]"?
> I wasn't gonna say it....   :|
Making my brain cells work a little harder than they normally do, I came
to the same conclusion ;-)
Date: 10 Nov 2017 07:45:01
Message: <web.5a059ef5fad04db2c437ac910@news.povray.org>
dick balaska <dic### [at] buckosoftcom> wrote:
> If they were being shot, or hacked up, that'd be ok.  But just standing
> there looking good? My sensitive eyes!
Maybe it's just me, but I can read that in several ways.
"Maybe if that were a B-rated hack and slash video, I'd be into it - but just
plain old hot chicks in leather?"
:D
Date: 10 Nov 2017 08:25:00
Message: <web.5a05a774fad04db289df8d30@news.povray.org>
> Well, my thoughts did not go into that direction to tell the truth. Just
> no shadows, without implications.
I'm actually with Thomas on this one-- and not just to be argumentative ;-)
In its strictest sense, no_shadow implies only what it says (IMO), because the
object (the wall) is still *visually* OPAGUE. The fact that no_shadow also
allows light to pass *through* the wall-- as if it's invisible to the light--
seems to me to be a 'secondary effect', not necessarily implied by the meaning
of no_shadow-- and might well be an unexpected effect for new users.
When I started my make my test code example, *I* actually didn't realize (or
remember) the 'dual nature' of that keyword, and didn't even try adding it to
the wall as the first step(!). Instead, I went off on a tangent, coming up with
the (unnecessary!) light_group idea first, to figure out a way to get the light
to strike my sphere object through the 'opague' wall! :-0
The documentation says "You may specify the no_shadow keyword in an object to
make that object cast no shadow. This is useful for special effects and for
creating the illusion that a light source actually is visible"-- then it refers
to the looks_light object in a light. The latter part of that sentence might
actually makes little sense to a new user, unless he/she is already familiar
with what a looks_like object is. (But no_shadow is no longer required there
anyway, as a looks_like object already has an implied no_shadow keyword.)
Since both Thomas and I both failed to initially grasp no_shadow's full meaning,
I imagine there may be others as well...
My two cents :-)
Date: 10 Nov 2017 09:30:01
Message: <web.5a05b6ccfad04db289df8d30@news.povray.org>
> Any object in a light_group will always cast shadows for any light in
> the scene. The light in the light_group can also get shadowed by any
> object outside the light_group.
> The light(s) in a light_group can only illuminate objects that are part
> of the same light_group.
> The objects of the group don't receive illumination from lights outside
> of the group unless you add "global_lights on" to the group.
As it turns out, my light_group wasn't needed anyway!
But I was also 'over-thinking' Thomas's original example-- guessing that his
wall was actually part of a much bigger scene, requiring the wall to *cast*
shadows onto other objects (but not onto his single specific object.)
Years ago, I made a REALLY complex scene like that, requiring no_shadow for some
of the objects, and had to figure out a way to get shadows to fall onto the rest
of the scene. If I recall, I had to use multiple (or even nested) light_groups.
In any case, my test code here probably confused things. :-(
Date: 10 Nov 2017 16:35:33
Message: <5a061ba5$1@news.povray.org>
On 11/08/2017 03:29 PM, Alain wrote:
> Le 17-11-08 à 08:27, William F Pokorny a écrit :
> The object in a projected_through is NEVER visible. It never cast
> shadow, is never seen in reflections nor refractions, and don't affect
> radiosity. Ity's just a kind or portail through the light comes.
Good point. Where a projected_through object is not otherwise used in
the scene, it's only a light portal.
Bill P.
Date: 22 Nov 2017 18:40:00
Message: <web.5a1608a0fad04db289df8d30@news.povray.org>
> In its strictest sense, no_shadow implies only what it says (IMO), [blah,blah]
Well, a lightbulb finally went off in my brain, so please forget my silly
argument.
If the wall object (with no_shadow) casts no shadow from a light, then what is
supposed to fill that no-longer-existing 'shadow area'? The light, of course.
Otherwise, there would be an illogical 'void' in that area, filled with...
what??  ;-)
Duh. It took me 'only' ten days to realize this... :-[
Date: 23 Nov 2017 02:53:46
Message: <5a167e8a$1@news.povray.org>
> argument.
> what??  ;-)
LOL
I am still pondering the issue; higher dimension bypasses. :-)
Date: 23 Nov 2017 03:57:29
Message: <5a168d79$1@news.povray.org>
That's the way it is looking to me. ;-)
Regards
Date: 23 Nov 2017 08:40:00
Message: <web.5a16cebffad04db25cafe28e0@news.povray.org>
Well of course.
It's a bypass!  Gotta build bypasses...
https://www.youtube.com/watch?v=HNmIQX_ImgM
