POV-Ray : Newsgroups : povray.general : Transparent PNGs Server Time
18 May 2024 14:38:38 EDT (-0400)
  Transparent PNGs (Message 35 to 44 of 44)
Subject: Re: Transparent PNGs
Date: 11 Oct 2017 16:55:01
Message: <web.59de84e0c5de9ff4c437ac910@news.povray.org>
Decrease the camera angle, and then maybe move it back.
Date: 11 Oct 2017 18:19:56
Message: <59de990c$1@news.povray.org>
Am 11.10.2017 um 21:21 schrieb Sven Littkowski:
> On 11.10.2017 15:07, Bald Eagle wrote:
>>  only ever
> Bald Eagle: FULL HIT!
> You managed to open my eyes. Yes, it was "MyNumber", and when i placed
> it inside the macro, it worked! I think, that is what Clipka had in
> mind, too, but I did not understand him (my fault again)
My eye and programming kung-fu may be sharp, but apparently my tutoring
kung-fu didn't quite cut it this time ;)
Date: 11 Oct 2017 19:13:34
Message: <59dea59e@news.povray.org>
Le 17-10-11 à 15:41, Sven Littkowski a écrit :
> Okay, I am getting there. Almost where I want to reach. Now another
> problem where I need the advise of you experienced users: perspective!
> Currently, the lower ends of the oars spread more towards the left and
> right side (because they are closer to the camera). I don't want to
> switch of that entirely, but i want to reduce the perspective drag
> towards the sides a bit. I know, this must be accomplished inside the
> CAMERA settings. but how exactly?
> I started to experiment already, but have not yet found the path to
> paradise.
> Diese E-Mail wurde von AVG auf Viren geprüft.
> http://www.avg.com
Double the distance between the camera and the oars, and reduce the
angle by half OR double the direction vector length.
Date: 11 Oct 2017 20:49:40
Message: <59debc24@news.povray.org>
Maybe it were my eyes or my mind that were not in best condition. :-)
http://www.avg.com
Date: 11 Oct 2017 22:47:41
Message: <59ded7cd$1@news.povray.org>
Everything is perfect now ... just one more question.   :-D
Is there any trick in POV-Ray, that allows me to make an item invisible
but still to get its shadow onto a wall behind it?
http://www.avg.com
Date: 11 Oct 2017 23:20:00
Message: <web.59dedeacc5de9ff49c5d6c810@news.povray.org>
no_image in the primitive, CSG or object statement, will do that and texture not
needed.
Date: 12 Oct 2017 11:59:57
Message: <59df917d@news.povray.org>
> needed.
BIG THANKS!
"That's one small step for a POVian, one giant leap for reconstructors."
Everything is working 100% now.
---SCENE--------------------------------------------------------------------------
#local Temp_version = version;
#version 3.7;
#declare MyRadiosity = off;   // on
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#declare TotalLength           = 10.0;   // length of oars of the lowest
line
#declare AmountOarsInLine      = 25;
#declare AmountLines           = 1;
#declare MyBladeWidth          = 0.150;  // the width of the oar's blade
#declare LineLeftShift         = 0.25;   // shift towards the left side
for additional lines
#declare LineHeightShift       = 0.25;   // distance to line below
#declare MyVariance            = 1.5;    // human irregularity
#declare MyHeightMore          = 0.50;   // upper lines need longer oars
#declare MyAngleMore           = 01.5;   // upper lines go a bit steeper
into water
#declare GeneralAngle          = 82.5;   // the angle of each oar from
hull towards water - lower angles = more vertical / higher angles = more
horizontal
#declare BladeAngle            = -65.0;  // the angle of the blade when
touching water
#declare ForwardAngle          =  7.3;   // to equalize the ends of each
line to the eye - lower angle = more backwards / higher angle = more
forwards / 7.5 = balanced
#declare MySceneTransitionLeft = -1.0;   // moves the entire object into
view center
#declare MyCameraAngle         = 17.0;
#declare MyShadows             = yes;     // render of "OARS ONLY" (no)
or of "SHADOWS ONLY" (yes)
#declare R1 = seed(1);
#declare R2 = seed(2);
#declare R3 = seed(3);
#if(MyShadows=no)
 camera
  location < 7.0,  0.0, -200.0 >
  look_at  < 7.0,  0.0,   0.0 >
  angle MyCameraAngle
#elseif(MyShadows=yes)
 camera
  location < 7.0, -65.0, -200.0 >
  look_at  < 7.0, -15.0,   0.0 >
  angle MyCameraAngle
light_source
 < -50000.0, 25000.0, -100000.0 >
 rgb < 1.0, 1.0, 1.0 > *1.5
 area_light x*2500,z*2500,5,5 circular orient
 area_illumination
#if(MyShadows=no)
 light_source
  <  50000.0, 25000.0, -100000.0 > //light position
  color rgb < 1.0, 1.0, 1.0 > * 0.5
  parallel
  point_at < 0.0, 0.0, 0.0 >
#include "textures.inc"
#declare UpperOar = texture
 DMFDarkOak
 pigment { color rgb < 0.3686275,  0.4509804,  0.2509804 > }
 normal { wood 0.5 scale 0.3 turbulence 0.1 }
 finish { phong 1 }
 rotate< 90.0, 0.0, 0.0 >
 scale 0.25
#declare LowerOar = texture
 DMFDarkOak
 pigment { color rgb < 0.1372549,  0.1372549,  0.1372549 > }
 finish { phong 1 }
 scale 0.25
#macro MyOar(MyHeightMoreThis)
 union
  union
   cone
    < 0.0, -10.0, 0.0 > 0.025 < 0.0, -9.75, 0.0 > MyBladeWidth   //
Bottom Blade
    scale < 1.0, 1.0, 0.1 >
   cone
    < 0.0, -9.75, 0.0 > MyBladeWidth < 0.0, -6.5, 0.0 > 0.075    // Top
Blade
   cone
    < 0.0, -9.5, 0.0 > 0.020 < 0.0, -6.5, 0.0 > 0.075            //
Shaft Blending into Blade
   cylinder
    < 0.0, -6.5, 0.0 > < 0.0, -6.0, 0.0 > 0.075                  //
Lower Shaft
   texture { LowerOar }
  union
   cylinder
    < 0.0, -6.0, 0.0 > < 0.0, 0.0, 0.0 > 0.075                   //
Upper Shaft
   #if(MyHeightMoreThis>0)
    cylinder
     < 0.0, MyHeightMoreThis, 0.0 > < 0.0, 0.0, 0.0 > 0.075      //
Longer Shaft for Upper Oar Lines
    translate < 0.0, -MyHeightMoreThis, 0.0 >
   texture { UpperOar }
  #if(MyShadows=no)
   no_shadow
#macro MyOarLine(AmountOarsInLine,MyHeightMoreThis,MyAngleMore)
 union
  #declare MyNumber = 0;
  #while(MyNumber<AmountOarsInLine)
   #declare MyAngleWater     = (rand(R1)*MyVariance)+GeneralAngle;
   #declare MyAngleHands     = (rand(R2)*MyVariance)+BladeAngle;
   #declare MyAngleDirection = (rand(R3)*MyVariance)+ForwardAngle;
   object
    rotate < 0.0, MyAngleHands, 0.0 >
    rotate < MyAngleWater-MyAngleMore, 0.0, 0.0 >
    rotate < 0.0, 0.0, MyAngleDirection >
    translate < (MyNumber*0.925), 0.0, 0.0 >
   #declare MyNumber = MyNumber+1;
union
 #declare ThisLine = 0;
 #while(ThisLine<AmountLines)
  object
   MyOarLine(AmountOarsInLine,MyHeightMore*ThisLine,MyAngleMore*ThisLine)
   translate <
-((AmountOarsInLine*0.925)/2)+0.925+(LineLeftShift*ThisLine),
LineHeightShift*ThisLine, 0.0 >
   #if(MyShadows=yes)
    no_image
  #declare ThisLine=ThisLine+1;
 #if(MyShadows=yes)
  box
   < -30.0, -15.0, 0.0 > < 30.0, 15.0, 0.1 >
   pigment { color rgb < 1.0, 1.0, 1.0 > }
 translate < MySceneTransitionLeft, 0.0, 0.0 >
http://www.avg.com
Date: 12 Oct 2017 12:27:52
Message: <59df9808@news.povray.org>
> http://www.avg.com
Yes. Add the no_image attribute to your object.
There is also no_reflection (won't be seen in reflections), no_shadow
(won't cast any shadow) and no_radiosity (ignore this object when
computing radiosity).
Date: 12 Oct 2017 15:20:35
Message: <59dfc083$1@news.povray.org>
Thanks again. The code is perfect now, it dos exactly what I need it to
do. :-)
http://www.avg.com
Date: 11 Nov 2017 16:40:01
Message: <web.5a0769a0c5de9ff489df8d30@news.povray.org>
snip]
>  DMFDarkOak
>  finish { phong 1 }
>  scale 0.25
It looks like you are substituting your own pigment for the pigment 'DMFDarkOak'
(which is actually just a pigment, not a complete texture.) In other words, your
own pigment is 'over-riding' DMFDarkOak; your scene isn't using it at all. The
same is happening in your 'LowerOar' texture.
When using multiple pigments in a texture, the 'final' pigment is the one that's
used; any previous ones are NOT used, or are ignored. So a texture should have
only ONE pigment-- unless you want to use a pigment_map and maybe the 'average'
keyword, to actually blend several pigments togather. Like this, for example...
#declare UpperOar =
texture{
   pigment{
       average
       pigment_map{
              [1 DMFDarkOak]
              [1 color rgb < 0.3686275,  0.4509804,  0.2509804 >]
          } // end of overall pigment statement
   finish { phong 1 }
   scale 0.25
This blends DMFDarkOak and your own color equally (because of the 1 and 1
'weights' of the two, in the pigment_map.) You could instead use 3 and 1 for the
respective weights (for example), which would blend '3 parts DMFDarkOak' to '1
part of your color'
There's also another problem in your scene, here:
#declare DMFDarkOak =
    wood
    turbulence 0.04            // For best results,  keep this low!
    octaves 3
    scale <0.2, 0.2, 1>        // Scaled for a unit object
    color_map {
        [0.1 rgb <0.60, 0.30, 0.18>]
        [0.9 rgb <0.30, 0.15, 0.09>]
Now you have re-#declared DMFDarkOak to be a different pigment entirely, for use
in your 'LowerOar' texture. But again, you are substituting your own pigment
in 'LowerOar' for this 'new' DMFDarkOak.
My suggestion would be to re-write 'UpperOar' and 'LowerOar, to use *either*
DMFDarkOak *or* your own pigment/color, but not both of those. Or use the
pigment_map trick, for a blend.
