POV-Ray : Newsgroups : povray.general : Strange parsing error Server Time
16 Mar 2026 09:35:12 EDT (-0400)
  Strange parsing error (Message 1 to 6 of 6)
Subject: Strange parsing error
Date: 30 Sep 2017 11:44:43
Message: <59cfbbeb@news.povray.org>
Hello,
I have an old MegaPov 1.21 code :
  93 : #macro lineEquation (rIndex, lIndex, pA, pB)
  94 :   #local det = pA.x-pB.x;
  95 :   #if(det=0)
  96 :     // #error
  97 :     #local sidesLines[rIndex][lIndex] = <0,0,1>;
  98 :  #else
  99 :    #local det_a = pA.z-pB.z;
100 :    #local det_b = (pA.x*pB.z)-(pA.z*pB.x);
101 :    #declare sidesLines[rIndex][lIndex] = <det_a/det,det_b/det, 0>;
102 :   #end
103 : #end
Parse with PovRay 3.7 i get this error :
	Line 99 : Bad operands for period operator.
For me, line #94 and #99 are similar, and no error for line 94.
I would also like to specify that the parameters of the macro are :
scalar, scalar, point, point.
Going Crazy!
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Strange parsing error
Date: 30 Sep 2017 13:08:44
Message: <59cfcf9c$1@news.povray.org>
On 09/30/2017 11:44 AM, kurtz le pirate wrote:
> Hello,
I think there must be other things going on to get into the parse issue.
I don't see anything amiss(1) in what you posted and several quick tests
here after adding a little boiler plate code around you snippet run OK
for me.
Bill P.
(1) Not a parse issue, but better to use #declare in both if conditions
when setting the external array.
Date: 30 Sep 2017 13:25:05
Message: <web.59cfd2eb923e3e145cafe28e0@news.povray.org>
>   95 :   #if(det=0)
>   96 :     // #error
>   98 :  #else
Well it looks like you should output the actual values to the debug stream or a
file to make sure there's actually a z component being passed to those vector
identifiers.
Aside from that, without the rest of code, it's anybody's guess what's
happening.
Date: 30 Sep 2017 17:10:41
Message: <59d00851@news.povray.org>
Le 17-09-30 à 11:44, kurtz le pirate a écrit :
> Hello,
>   95 :   #if(det=0)
>   96 :     // #error
>   98 :  #else
> 102 :   #end
> 103 : #end
> Going Crazy!
If pA or pB are 2D vectors or scalars, I think that it could cause such
an error.
You can force those to become 3D vectors as folow :
Add
#local pA=<0,0,0>+pA;
#local pB=<0,0,0>+pB;
// Promote to 3D vector if input is a scalar or a 2D vector
// effectively a no operation otherwise (3D, 4D and 5D)
or
#local pA=<1,1,1>*pA;
#local pB=<1,1,1>*pB;
just after line 93.
Date: 30 Sep 2017 19:09:06
Message: <59d02412$1@news.povray.org>
Am 30.09.2017 um 17:44 schrieb kurtz le pirate:
>  95 :   #if(det=0)
>  96 :     // #error
>  98 :  #else
> 102 :   #end
> 103 : #end
I'm with Alain on this one: My guess is that there's nothing wrong with
the macro per se, but rather with its invocation, and that you're
accidently passing a 2D point or scalar as the 3rd or 4th parameter. The
`.x` works fine for either of those (you can interpret a scalar as a 1D
vector if you will), but `.y` requires at least a 2D vector, and `.z`
requires at least a 3D vector.
Date: 14 Oct 2017 12:23:06
Message: <59e239ea$1@news.povray.org>
Bingo ! You're right.
Somewhere in the code, i pass a bad vector.
Sorry.
Kurtz le pirate
