POV-Ray : Newsgroups : povray.general : trace question Server Time
18 May 2024 19:17:51 EDT (-0400)
  trace question (Message 11 to 15 of 15)
Subject: Re: trace question
Date: 11 Sep 2017 08:38:50
Message: <59b683da$1@news.povray.org>
On 09/10/2017 10:01 AM, Stephen wrote:
> On 10/09/2017 14:27, clipka wrote:
>> ... and hope that the pigment isn't UV-mapped,
> Hope is not involved because there is a good chance I would want to do
> that. Is it at all possible?
We do now have a user defined by functions camera. If you can work out
how to map each 'trace' to an equivalent user defined camera ray, it
should be you can create an image - sort of a new version of the uv
mapped texture as 'seen' mapped onto the object. This rendered image
could then be queried at the appropriate x,y positions for each trace to
give you the color values.
Likely want to create that image with a modified finish of ambient 1.0
or emission 1.0 - and diffuse 0.0 for the object's texture.
I've had the reverse of what you are attempting floating around in my
head for creating uv mapped images via texture baking environments for
all POV-Ray's uv mapped objects. We have the uv mapping for a
significant number of primitives, but for most, no easy way to create uv
image maps for them. In other words, as part of the uv mapping
capability for each primitive, might we be able to provide uv mapping
functions which could be use to create inward or outward facing user
defined functional cameras more or less in the 'shape' of the primitive
object. Kind of a mesh camera capability. Every uv mapped primitive
could also be a primitive shaped camera by using the uv appropriate
functions and matching shape parameters. ;-)
Using the mesh camera to get a rendered image for the traced colors is I
think another possibility. Create a triangle in the 'camera' mesh for
each traced ray.
Bill P.
Date: 11 Sep 2017 09:05:01
Message: <web.59b68980c9840c1a64d483f00@news.povray.org>
> each traced ray.
> Bill P.
More food for thought. I am going to die of glutony. ;-)
I've been meaning to look at the mesh camera for ages. I like the idea of using
it as a UV mapper.
But with my luck at the moment...
I'm having to post this from the web interface as TBird did not load the text.
Computers!
Date: 11 Sep 2017 09:28:51
Message: <59b68f93@news.povray.org>
Am 10.09.2017 um 23:50 schrieb Bald Eagle:
> clipka <ano### [at] anonymousorg> wrote:
>> And that's where the problem with UV-mapped textures arises: Since
>> `trace` knows nothing about textures, and `eval_pigment` knows nothing
>> about geometry, the two can only be combined for good effect if there is
>> a direct mapping between geometry and pigment via 3D XYZ space. But with
>> UV-mapping that's not the case, and hence the /combo/ of the two
>> functions breaks down there.
> So, the color of a surface on a uv-mapped object is not directly measurable by
> the eval_pigment() function? [ ! :O ]
> I would never have guessed that.
> It must then use a completely different algorithm than the ray-object
> intersection used to generate the final scene.
Actually no, the `trace` function is essentially the same as the one
used in the render. And the `eval_pigment` function is also essentially
the same as the one used in the render.
But the `trace`-like function used in the render not only computes the
3D XYZ location and surface normal, but also the UV coordinate as yet
another output value; and the render alghorithm then decides whether to
call the `eval_pigment`-like function with <X,Y,Z> as the location
parameter, or whether to use <U,V,0> instead.
> Can you:
> 1. use trace() to get the point and the normal
Yes, absolutely.
> 2. define a pigment constructed in the plane intersecting that point with the
> same normal
> ( I likely have no idea what I'm talking about here: I'm just confabulating the
> possibility that some slice of a function-object-pattern thing might be a
> workaround... )
You're right, that sounds a bit... confabulated. ;)
Whatever your brain is concocting there, it can't replace computing the
UV coordinate of the intersection.
> 3. then do an eval_pigment() on the plane?
You cannot do `eval_pigment` on shapes. You can only call it on pigments.
Date: 11 Sep 2017 09:38:38
Message: <59b691de$1@news.povray.org>
Am 11.09.2017 um 09:11 schrieb Stephen:
>> Am 10.09.2017 um 15:13 schrieb Stephen:
>>> If I trace an object. How can I get the colour of the intersection of
>>> the ray and object. As far as I can see trace() only returns the normal.
>> You'll need to know the pigment of the object, and invoke `eval_pigment`
>> on the intersection point you get...
> Follow up question.
> How would you use eval_pigment if you were tracing a CSG?
> Is it possible?
Presuming the CSG elements have different textures... no.
So with that in mind, probably the easiest (from a user perspective) way
to solve this whole group of issues would be to provide a function that
not only computes a ray-object intersection, but also does a proper
pigment lookup.
Which has its own issues though; most notably, texture patterns and
layered textures would be a b*tch to deal with, as in the actual render
algorithm they're not handled at the pigment level, but at the "what
does that texture actually look like as seen from this angle" level
(finish level if you will, with highlights and reflections and all).
Date: 11 Sep 2017 10:11:19
Message: <59b69987$1@news.povray.org>
>> Follow up question.
>> Is it possible?
> pigment lookup.
So that means it will be ready after PovRay Ver 4.0 and Moray's
re-write. ;-)
Thanks for looking into it Clipka.
Regards
