POV-Ray : Newsgroups : povray.general : Survey: Compilers Used Server Time
15 Dec 2025 16:56:38 EST (-0500)
  Survey: Compilers Used (Message 1 to 8 of 8)
Subject: Survey: Compilers Used
Date: 20 Jun 2017 10:27:42
Message: <594930de$1@news.povray.org>
Hi folks,
I'd like to get some feedback on what compilers you are using to build
your own POV-Ray binaries (if applicable).
More specifically, I'd like to know whether anyone is using something
*OTHER* than one of the following:
- Microsoft Visual Studio 2015 or later.
- Gnu Compiler Collection 4.8.1 or later.
- Clang 3.3 or later.
So if you are using an older version of the above compilers, or an
entirely different compiler, please let us know.
The ultimate purpose of this survey is to determine which C++11 features
might be safe to use in the POV-Ray source code.
Subject: Re: Survey: Compilers Used
Date: 20 Jun 2017 16:39:44
Message: <59498810@news.povray.org>
Le 20/06/2017 à 16:27, clipka a écrit :
> Hi folks,
3 Compilers in use here (64 bits, intel processor):
* Intel icpc 17.0.4 (from intel parallel studio XE 2017 update 4, for Linux)
* Gnu g++ 6.3.0 (from ubuntu 17.04)
* Clang 4.0.0 (from ubuntu) 17.04)
Did you known there is C++14 and ...
Winter is coming... no, C++17 is coming!
Date: 21 Jun 2017 13:42:29
Message: <594ab005@news.povray.org>
Am 20.06.2017 um 22:39 schrieb Le_Forgeron:
Intel claims full C++11 support as of version 15.0, so that should be ok.
They should certainly be fine.
I am well aware of that. But C++14 is currently a no-go -- even if we
could rely on all of our users (those that want to run their own builds
at any rate) having access to a C++14-capable compiler, we're still
stuck with MSVC 2015, GCC 4.8.4 and clang 4.2 on the machines we run our
automated build tests on; of those, only clang will do a reasonable
subset of C++14. You do want us to run automated build tests, don't you? ;)
As a matter of fact, one of our automated build services (the one we
also happen to need to run our automated static code analysis) is still
running Ubuntu 12.04 by default, with GCC still at 4.6 and thus not even
C++11-complete. It was only recently that I learned that they do provide
14.04 images, but they still seem to flag them as beta.
Date: 21 Jun 2017 18:55:00
Message: <web.594af8af182b495194284cc0@news.povray.org>
Povray compiles just fine on for me:
* FreeBSD 11 with Clang 3.8
* Ubuntu 16.04 with gcc 5.4.0
* Ubuntu running under Windows Subsystem for Linux
Date: 22 Jun 2017 04:01:13
Message: <594b7949$1@news.povray.org>
Am 22.06.2017 um 00:52 schrieb jhu:
The latter, too, would be GCC 5.4.0.
Date: 24 Jun 2017 08:08:26
Message: <594e563a$1@news.povray.org>
Jérôme,
I was just playing around with libpng16 on Ubuntu 16.04 (normally uses
libpng12) and I found moving to png16 removed my libsdl1.2 for some reason.
I see Ubuntu 17.04 is using libpng16 by default. Have you had any
trouble with the sdl1.2 preview display on 17.04?
libsdl1.2 was updated too for 17.04 so I'm thinking things OK if
releases aligned, but I couldn't see any updated directly related to
libpng, so not sure.
Thanks for your time.
Bill P.
Date: 24 Jun 2017 14:16:14
Message: <594eac6e$1@news.povray.org>
>> Linux)
> Jérôme,
So far, I have installed on my system:
libpng-dev (1.6.28-1)
libpng++-dev (0.2.9-1)
libsdl1.2-dev (1.2.15+dsfg1-4)
libsdl2-2.0-0 (2.0.5+dfsg1-2ubuntu3)
I do not see any direct conflict on the listed dependencies of
libsdl1.2-dev to libpng.
Interestingly, there is a libsdl2-dev which can be installed in parallel
to libsdl1.2-dev
I also have the libpng12-0 (as runtime), along with libpng16-16.
But I remember that upgrade of release usually try to remove a lot of
"unnecessary" packages, aka packages it does not see the need for... and
it is not good at it when you have locally compiled applications.
> Bill P.
Date: 24 Jun 2017 18:00:25
Message: <594ee0f9$1@news.povray.org>
>> Jérôme,
Good to know you have no issues having libsdl1.2-dev installed with
png16. Your sdl1.2 version is the newer one. The one that got removed
for me was 1.2.15+dsfg1-3.
> to libsdl1.2-dev
Yes, I have this dual set up on my main Ubuntu 16.04 machine. SDL2 is a
non-compatible alternative to the much older SDL1.2, so we cannot just
switch to it. See: http://wiki.libsdl.org/MigrationGuide
I've have on my to-play-with list to try and update our code and build
system to work with SDL2 - in addition to 1.2 initially. I've only
managed to compile small sdl2 example programs thus far as I'm still
learning c++ so we'll see.
With SDL2 it looks like we can probably do our 2D window display scaling
with built in functions making use of the graphics hardware / gpu
functionality instead of the custom c++ scaling code we have today.
SDL2: "Simple 2D rendering API that can use Direct3D, OpenGL, OpenGL ES,
or software rendering behind the scenes"
