POV-Ray : Newsgroups : povray.general : focal_point Server Time
17 Apr 2026 04:16:26 EDT (-0400)
  focal_point (Message 1 to 10 of 17)
Subject: focal_point
Date: 8 Nov 2016 18:18:57
Message: <58225d61$1@news.povray.org>
I am trying to add focal_point to this scene (scroll down):
https://commons.wikimedia.org/wiki/File:Camera_focal_length_distance_house_animation.gif
I've replaced the camera with this:
camera
	#if (clock = 0)
		orthographic
	location		CameraLocation
	direction		CameraDirection
	up			CameraUp
	right			CameraRight
	#if (clock != 0)
		focal_point		<0,0,0>
		aperture		0.25 // 0.05 ~ 1.5; // more = more blurring
		blur_samples		25 // 4 ~ 100, more = higher quality; fewer = faster
//		confidence		0.9 // how close to the correct color, 0 ~ 1, default 0.9
//		variance		1/128 //(default) smallest displayable color difference
	transform {CameraTransform}
However, the text on the image disappears. Any idea why?
Mike
Subject: Re: focal_point
Date: 8 Nov 2016 18:22:08
Message: <58225e20$1@news.povray.org>
Should I apply the camera transforms before or after I specify focal_point?
Mike
Date: 8 Nov 2016 18:40:06
Message: <58226256$1@news.povray.org>
> Mike
If you apply your transformation before you set focal_point, it will
affect the location and direction of the camera only. If you apply it
after, then, focal_point will be transformes along with everything else.
So, if you want to move/rotate your camera and keep your focal_point
stationary, set it after the transformation.
If you want the focal_point to remain stationary relative to the camera,
set it before the transformation.
Date: 8 Nov 2016 19:23:52
Message: <58226c98$1@news.povray.org>
If I comment out the focal blur stuff, the text returns. I also tried
lowering the aperture size, but it does not help.
Mike
camera
     #if (clock = 0)
         orthographic
     up            CameraUp
     right            CameraRight
     #if (clock != 0)
         focal_point        <0,0,0>
= faster
1, default 0.9
difference
Subject: Re: Focal Blur
Date: 8 Nov 2016 23:28:48
Message: <5822a600$1@news.povray.org>
http://wiki.povray.org/content/Reference:Camera#Focal_Blur
The docs say, "The center of the zone of sharpness is specified by the
focal_point vector. The zone of sharpness is a plane through the
focal_point and is parallel to the camera. Objects close to this plane
of focus are in focus and those farther from that plane are more
blurred. The default value is focal_point<0,0,0>."
How can a plane be parallel to the camera? Can't a plane only be
perpendicular to a vector?
Also, I don't understand why a plane is used at all. All points
equidistant from focal_point should form a sphere, don't they?
Mike
Date: 9 Nov 2016 00:30:00
Message: <web.5822b4063d3f48e79c5d6c810@news.povray.org>
Probably parallel in the view sense, every plane forward of the camera view
would be considered parallel.
Someone else would need to answer that second part, but I think the way it works
is to simply use a flat plane like orthographic projection does. Maybe... maybe
not.
I looked at your SDL and the new screen.inc (I renamed mine here screen2.inc to
not mix it up with the old one).
Found that by using aperture 0.01 to focus the blurring while testing, and using
the camera location instead of <0,0,0> I could get a look at the text again by
adding a little z to it.
Of course, it blurs away immediately after clock increases away from 0.
     focal_point     CameraLocation+z*0.4
If 0.3 or 0.5 is used the text blurs out, so obviously there's a very narrow
focus area.
I don't know if you will be able to discover a method to keep the text at the
focal plane but seems like it shouldn't be impossible either.
Date: 9 Nov 2016 00:41:51
Message: <5822b71f$1@news.povray.org>
Am 09.11.2016 um 05:28 schrieb Mike Horvath:
Interpret it as "parallel to the image plane" -- or, in other words,
"perpendicular to the camera axis".
Uh, yes, technically, all points equidistant from _any_ given point form
a sphere, but how would a sphere centered around focal_point (= an
arbitrary point by which the location of the zone of sharpness is
defined) be of any relevance?
Presuming that you mean "all points equidistant from the camera
location", the answer is: Yes, that would also be a sphere -- but the
zone of sharpness in a normal camera is _not_ the set of points
equidistant to the camera lens; rather, in a real-life camera it is the
set of points equidistant to the image plane, and that's also the case
for POV-Ray's camera.
Date: 9 Nov 2016 00:43:24
Message: <5822b77c$1@news.povray.org>
Am 09.11.2016 um 01:23 schrieb Mike Horvath:
My guess would be that the text is far too close to the camera, and
therefore hopelessly out of focus.
Date: 9 Nov 2016 16:23:23
Message: <582393cb$1@news.povray.org>
Okay, thanks.
Mike
Date: 9 Nov 2016 16:23:41
Message: <582393dd$1@news.povray.org>
You are correct.
Mike
