POV-Ray : Newsgroups : povray.general : State of the black_hole warp's type option? Server Time
17 May 2026 00:30:03 EDT (-0400)
  State of the black_hole warp's type option? (Message 1 to 3 of 3)
Subject: State of the black_hole warp's type option?
Date: 8 Jul 2016 18:46:23
Message: <57802d3f$1@news.povray.org>
I was recently using the black_hole warp and noticed a 'type' option I'd
never used. I could find no documentation on it other than the option
being mentioned.
The code looks like it tests for and works only for type 0. My own
testing confirms other than 0 effectively turns the black_hole warp off.
I found this from 2002:
http://news.povray.org/povray.beta-test/thread/%3C3c44167a@news.povray.org%3E/
which looks like there was intent to remove the option from 3.5.
Have I missed something? Is there some current purpose for other than
type 0?
I can imagine other black hole types - perhaps a whirlpool or oblong
effect for example - but given the current state, should we remove the
option and code for now as Ingo apparently planned?
If 0 is the only valid option for type at present, but others are
planned, should we warn in the parser when it is set to something other
than 0? Perhaps also comment the conditional in the code on type to save
a few cyles until other options exist ?
No matter the answer(s) supposing the documentation should be updated to
match.
Thanks for your time,
Bill P.
Subject: Re: State of the black_hole warp's type option?
Date: 9 Jul 2016 06:53:25
Message: <5780d7a5$1@news.povray.org>
Am 09.07.2016 um 00:46 schrieb William F Pokorny:
For the sake of backward compatibility, removing the option is not an
option (no pun intended).
A warning might be in order, depending on whether we label the setting
as obsolete (in which case we should warn) or intended for future
extensions (in which case we probably shouldn't warn, except maybe if
the user specifies a value other than the supported value of 0).
As for the conditional, if we go for the "future extension"
interpretation I suggest replacing it with a switch() and making it the
default branch. This way we keep the logic there, but make it easy for
the compiler to optimize it away. (If we do that, we should add a
warning to the parser if a value other than 0 is specified, as the
behaviour will change.)
> match.
True.
Date: 10 Jul 2016 08:00:05
Message: <578238c5@news.povray.org>
:-) Ah yes, think you are right.
OK. I'll work toward the "compatibility and future extension" switch()
change and warn on non-zero setting.
>> match.
> True.
I'll first create a branch for the change and submit a pull request for
review. After refinement/adoption, I'll work up the documentation change
to match.
Thanks,
Bill P.
