POV-Ray : Newsgroups : povray.general : Spiral tube? Server Time
17 May 2026 03:21:52 EDT (-0400)
  Spiral tube? (Message 1 to 10 of 20)
Subject: Spiral tube?
Date: 6 Jan 2016 00:48:09
Message: <568caa99$1@news.povray.org>
How do I create a spiral tube, like a spring? Like this:
http://www.f-lohmueller.de/pov_tut/animate/anim16e.htm
but a single object, not a union of spheres?
Thanks!
Mike
Subject: Re: Spiral tube?
Date: 6 Jan 2016 03:11:21
Message: <568ccc29$1@news.povray.org>
> Thanks!
In a modeller, this is pretty easy, for instance building a spiral line
segment (aka a spline) and an appropriate surface to follow it. However,
that may not be what you want.
Date: 6 Jan 2016 03:55:58
Message: <568cd69e$1@news.povray.org>
>> Thanks!
generating a spline along an helix is rather easy. Then if sphere_sweep
is acceptable, the problem is solved.
Now, do you considere sphere_sweep a single object ?
Date: 6 Jan 2016 05:17:47
Message: <568ce9cb@news.povray.org>
> Thanks!
Many years ago I asked a similar question and was given a macro to
create spiral tubes consisting of torus-segments. It is not a single
object but it is contiguous. The annotations are mostly by Frank
(Sputnik) and it is just pulled out of an old scene of mine. It is a
long spring with the helix tightening at the ends.
#declare Y_Adjust = 0 ;                                // <- Mine
// Spring_with_Ends
// Spring_Sputnik
// Spiral  by Sputnik
#declare RotSpeed =  -9720*(frame_number/599 );        // <- Mine
#declare HeightOffset = 6.5 ; //11.750;
#declare SpringHeight =  13  ;
#declare SpringMajorRadius = .4;          //2;
#declare SpringMinorRadius = .060;
#declare SpringRevolutions = 24;
#declare SpringSegments = 5*SpringRevolutions ; // 5*SpringRevolutions is
                               // enough for #macro Spiral
#declare SpringHeight2 = 0.5;
#declare SpringRevolutions2 = 2;
#declare SpringSegments2 = 5*SpringRevolutions2; // 5*SpringRevolutions is
#declare SpringHeight3  = 0.5;
#declare SpringRevolutions3 = 2;
#declare SpringSegments3 = 5*SpringRevolutions3; // 5*SpringRevolutions is
// SPIRAL
#macro Spiral ( Radius1, Radius0, Rise, Turns, Segments )
   // Radius1 : major radius
   // Radius1 : minor radius
   // Rise    : height of a single turn
   // Turns   : number of turns (may be non-integer)
   // Segments: number of tori in spiral
   //           (>= 2*Turns; usually 5*Turns ... 10*Turns is enough)
   // some calculations ...
   #local Ang= Turns*360/Segments;
   #local Ri = Rise/2 * Turns/Segments;
   #local Sin= sin(radians(Ang/2));
   #local A  = Radius1*Sin;
   #local B  = sqrt(Radius1*Radius1-A*A);
   #local C  = A*A/B;
   #local DD = Ri*Ri+A*A;
   #local E  = DD/C;
   #local W  = degrees(atan2(C,sqrt(DD)));
   #local R  = sqrt(E*(E+C));
   // single torus-segment
   #declare T =
     intersection {
       torus { R, Radius0 }
       plane { -x, 0 rotate  W*y }
       plane {  x, 0 rotate -W*y }
       bounded_by { box {
         1.001*<-(R+Radius0)*Sin, -Radius0, -(R+Radius0)>,
         1.001*< (R+Radius0)*Sin,  Radius0, -(R-Radius0)*(1-Sin*Sin)>
       rotate -degrees(atan2(Ri,A))*z
       translate <0, Ri, E-B>
       rotate Ang/2*y
   // stack the segments
   union {
     #local N = 0;
     #while (N<Segments)
       object { T rotate N*Ang*y translate N*2*Ri*y }
       #local N = N+1;
       #end//while
     // no "}" to allow modifiers
   #end//macro Spiral
   // spring consisting of torus-segments
   #declare Spring =
     Spiral (
       SpringMajorRadius,
       SpringMinorRadius,
       SpringHeight/SpringRevolutions,
       SpringRevolutions,
       SpringSegments // 5*SpringRevolutions usually is enough
       ) /* { */ rotate -90*y /* same orientation as Warp's spring */ }
   #declare Spring2 =
     Spiral (
       SpringMajorRadius,
       SpringMinorRadius,
       SpringHeight2/SpringRevolutions2,
       SpringRevolutions2,
       SpringSegments2 // 5*SpringRevolutions usually is enough
   #declare Spring3 =
     Spiral (
       SpringMajorRadius ,
       SpringMinorRadius,
       SpringHeight3 /SpringRevolutions3,
       SpringRevolutions3,
       SpringSegments3 // 5*SpringRevolutions usually is enough
#declare Springs = union {
                         object { Spring}
                         object { Spring2
                         translate SpringHeight *y
                         object { Spring3
                         translate -SpringHeight3 *y
                 object { Springs
	rotate 90*x
//                scale 0.02
//scale -1*z
scale <1,1,-1>
	translate  HeightOffset *z
rotate x*90
translate y* Y_Adjust                                                //
<- Mine
rotate y*RotSpeed
<- Mine
                          pigment
                                 { color rgb <1.0, 1.0, 1.0>  }
                          finish
                                     ambient 0.194233
                                     diffuse 0.424433
                                     brilliance 16.992
                                     phong 0.482
                                     phong_size 66.886667
                                     specular 0.129467
                                     roughness 0.1203
                                     reflection
                                        0.13 , 0.34
                                        fresnel  off
                                        falloff  1.0
                                        exponent 1.0
                                        metallic 0.5
Regards
Date: 6 Jan 2016 15:46:29
Message: <568d7d25$1@news.povray.org>
> Thanks!
> Mike
It can be done as an isosurface. In fact, there are two builtin
functions that does just that.
In function.inc, those are: f_helix1() and f_helix2()
The various parameters controll the shape of the spiral, it's spacing
and some other aspects. Those are some of the functions using the
largest number of parameters.
The extent of the shapes generated are dependent on the contained_by
object. Use a box just whide enough to contain the spiral and as long as
needed.
Take some time to experiment.
If you want to use that shape in an animation similar to the linked one,
you need to adjust the length of the box at the same time that you
adjust the pitch of the helix.
If the amplitude of the sooilationsis relatively small, and the spring
far/small enough, it may be possible to use some scalling, but the
profile of the "whire" will also change.
Date: 7 Jan 2016 17:22:20
Message: <568ee51c$1@news.povray.org>
> needed.
> Alain
How would I create a density function to fill the shape with gas?
Mike
Date: 7 Jan 2016 18:30:00
Message: <web.568ef4e1bcf3aeb42b16ebf70@news.povray.org>
> Mike
Hmm, look for an idea at
http://news.povray.org/povray.text.scene-files/message/%3C3e3c2c14%40news.povray.org%3E/#%3C3e3c2c14%40news.povray.org%
3E
Norbert
Date: 7 Jan 2016 18:48:39
Message: <568ef957$1@news.povray.org>
>> Mike
> 3E
> Norbert
Unfortunately, that message never got a reply.
Mike
Date: 7 Jan 2016 21:17:25
Message: <568f1c35$1@news.povray.org>
>> needed.
>> Alain
> Mike
You could use the same function to controll the media's density. It's
just that, for the isosurface, the value need to be low inside and
higher outside, while, for the media, you probably want it to be at is't
maximum in the center and drop to zero at the surface.
My take would be to use a threshold of zero and negate the function.
In this case, the function evaluate to a negative value inside the
isosurface and positive outside.
If the threshold is larger, you substract the threshold value, then
Next, you can multiply the function by whatever value you want,
or
use a colour_map with values as large as you want them to controll the
pattern of your media.
Date: 8 Jan 2016 00:03:06
Message: <568f430a$1@news.povray.org>
> or
> Alain
For example code which does pretty much what Alain outlined above see
povray.text.scene-files post "Example constraining media inside an
isosurface shape."
http://news.povray.org/povray.text.scene-files/message/%3C568f4074%241%40news.povray.org%3E/#%3C568f4074%241%40news.povray.org%3E
The tricky part when using the built in functions is not easily being
sure of the range of values returned. In this example I ended up with a
pretty large negative multiplier on the helix1 function for use with the
color map & it likely isn't the optimal multiplier.
Bill P.
