POV-Ray : Newsgroups : povray.general : Trying to create a border line using gradient Server Time
28 Sep 2024 04:24:00 EDT (-0400)
  Trying to create a border line using gradient (Message 1 to 2 of 2)
Subject: Trying to create a border line using gradient
Date: 3 Mar 2015 22:05:01
Message: <web.54f6756c28f40dba8762ec0@news.povray.org>
Hi everyone,
I'm trying the apply a border line look like in both vertical and horizontal
border of a square:
#declare black = texture {
     pigment {color rgb <0,0,0> }
#declare Cor1_1 = texture {
   uv_mapping pigment { image_map { jpeg
"C:\ARQUIV~2\VBFILE~1\PR6DB9~1\Comum\Maps\BRANCO10.JPG" }}
   finish {phong 0 brilliance .3
#declare Cor1x = texture {
     gradient x
     texture_map {
         [0.00 black]
         [3.003003E-02 Cor1_1]
     scale 333
#declare Cor1 = texture {
     gradient y
     texture_map {
         [0.00 black]
         [3.003003E-02 Cor1x]
     scale 333
Then I apply the Cor1 texture to my mesh, but it turns completely black.
But when I apply the Cor1x instead, it works, but of course, it only shows the
horizontal line.
My goal is to draw a line on the four borders, over a image_map.
Is it possible? My approach is right?
Thanks!
Subject: Re: Trying to create a border line using gradient
Date: 4 Mar 2015 02:28:59
Message: <54f6b43b$1@news.povray.org>
Le 04/03/2015 04:01, Fernando Souza a écrit :
> Hi everyone,
> border of a square:
>      gradient x
>      texture_map {
>          [0.00 black]
>      scale 333
>      gradient y
>      texture_map {
>          [0.00 black]
>      scale 333
> horizontal line.
Possible: I would use the boxed pattern instead of gradient.
For image_map, it would need to be scaled and translated, as image_map
is <0,0>-<1,1> and boxed is <-1,-1,-1> - <1,1,1> for the interesting
part (with <0,0,0> being at value 1 )
   scale 2
   translate -1
#declare Boxing = texture {
     boxed
     texture_map {
         [0.00 black] // 5% bevel
         [0.05 Cor1_1]
     translate 1
     scale 1/2
Right: as long as it works, it must be right. The above code is not tested.
If you want a hard black line, you need to move 0.00 Black to 0.05 Black
(or add 0.05 Black between the two entries).
So far, it's black at 0 and a mixed of the picture with black as the
line get away from the border.
Notice that I removed the uv_mapping statement, as it would make sense
for the top level texture when applied on mesh, but probably not deep in
the tree of texture.
Just because nobody complains does not mean all parachutes are perfect.
