POV-Ray : Newsgroups : povray.general : Shooting rays Server Time
20 Dec 2025 07:58:35 EST (-0500)
  Shooting rays (Message 1 to 4 of 4)
Subject: Shooting rays
Date: 9 Mar 2013 08:11:35
Message: <513b3507@news.povray.org>
I have a container A (not at the origin) and, inside this container, an
object B at a random location. Using trace() I want to determine what is
the closest distance between B and the boundary of A in the X-Z plane,
and use the normal of A at that (approximate) location to
Reorient_Trans() B.
My main problem is shooting rays around from B as I have trouble
rotating the ray direction vector around the local Y-axis. I experiment
with vaxis_rotate() but do not get consistent results as it seems that
the axis (always?) passes through the origin.
How should I write this code?
Thanks!
Subject: Re: Shooting rays
Date: 9 Mar 2013 10:20:53
Message: <513b5355$1@news.povray.org>
I may have found the solution. See sample file in p.b.s-f
Date: 11 Mar 2013 04:15:08
Message: <513d928c@news.povray.org>
Are there any limitations on the shape of A and B, or could they be
anything?
Do you mean from some centre point of B, or from the surface of B? What
I think you want is the shortest line connecting the surface of A and B
that is in a plane parallel to the XZ plane? Is that right? That doesn't
sound trivial to me.
I'm not sure exactly what you're trying (haven't analysed your code) but
you can always translate to the origin, rotate, then translate back
again to rotate around a specific axis.
Date: 11 Mar 2013 04:57:58
Message: <513d9c96@news.povray.org>
> anything?
They can be anything.
In fact, as the code in p.b.s-f shows, I solved the problem to my
satisfaction as further tests have shown me. Implementation is in a new
Urbanism scene. Thanks for you comments though :-)
