POV-Ray : Newsgroups : povray.general : Start with empty editor Server Time
30 Sep 2024 04:17:40 EDT (-0400)
  Start with empty editor (Message 1 to 5 of 5)
Subject: Start with empty editor
Date: 7 Dec 2012 23:10:06
Message: <50c2bd9e@news.povray.org>
On startup, the editor of the Windows version (both 3.6 and 3.7)
automatically reloads all files that were open in the previous session.
Is there a setting to prevent this?
It's mostly a problem with keep single instance when opening files
from explorer, this ends up with a lot of files being open in two
instances and me always editing the unintended version ;)
I think the reloading should normally not occur when an explicit
file name is passed as command line parameter. Actually I'm not sure
if 3.6 did this, couldn't get Windows to restore the file association
to the old binary (I think it got confused because the name of the
exe is identical).
Subject: Re: Start with empty editor
Date: 7 Dec 2012 23:17:55
Message: <50c2bf73@news.povray.org>
You can supply /norestore on the command-line if you wish.
-- Chris
Date: 8 Dec 2012 16:17:40
Message: <50c3ae74@news.povray.org>
ah, perfect and vaguely familiar too ;) I think I changed
the shell commands for 3.6 years ago, so I first thought the
behavior was changed with 3.7, when in fact it was just the
file association that got updated by the 3.7 installer.
BTW I encountered a strange effect:
   /NORESTORE /EDIT xyz.pov
worked, but
   /EDIT /NORESTORE xyz.pov
appeared to be interpreted as /RENDER instead.
Date: 9 Dec 2012 05:15:00
Message: <50c464a4$1@news.povray.org>
> worked, but
Wild guess: would /EDIT xyz.pov /NORESTORE work better?
-Aero
Date: 9 Dec 2012 21:08:52
Message: <50c54434$1@news.povray.org>
I see what you're getting at ;) yes that works too.
