POV-Ray : Newsgroups : povray.general : Area light size to simulate sun Server Time
29 Jul 2024 08:17:28 EDT (-0400)
  Area light size to simulate sun (Message 1 to 7 of 7)
Subject: Area light size to simulate sun
Date: 23 Aug 2012 15:27:46
Message: <op.wjidodicufxv4h@xena>
I was trying to figure out how big an area light should be to simulate the
sun when the light is a lot closer than the sun actually is. Looking at a
wall about 3m high I noticed the shadow on the ground blurred about 3cm. I
came to the conclusion that the diameter of my light should be about 1% of
the distance from the object. To test my theory I looked up the diameter
of the sun and the distance from the sun to the earth. Close enough! The
diameter of the sun is 1 391 000 km and the distance from the earth to the
sun is 149,669,180 km. That's 0.929% :)
-Nekar Xenos-
Subject: Re: Area light size to simulate sun
Date: 23 Aug 2012 20:37:55
Message: <5036cce3$1@news.povray.org>
> the sun when the light is a lot closer than the sun actually is. Looking
> at a wall about 3m high I noticed the shadow on the ground blurred about
> 3cm. I came to the conclusion that the diameter of my light should be
> about 1% of the distance from the object. To test my theory I looked up
> the diameter of the sun and the distance from the sun to the earth.
> Close enough! The diameter of the sun is 1 391 000 km and the distance
> from the earth to the sun is 149,669,180 km. That's 0.929% :)
It's interesting to note that the Moon have the same apparant size as
the sun.
So, you can use the same settings for both the Sun and the Moon, with
the only difference been the actual brightness.
Date: 24 Aug 2012 03:22:26
Message: <50372bb2$1@news.povray.org>
I use the following, originally proposed by Cousin Ricky iirc, which
seems fairly correct:
#declare SunDis = vlength(SunPosition)*2/215;
   light_source{
     SunPosition
     color SunColor
     area_light
     SunDis*x, SunDis*z,
     5, 5
     adaptive 2
     jitter
     circular
     orient
     parallel
     point_at <0, 0, 0>
Date: 24 Aug 2012 10:17:42
Message: <50378d06@news.povray.org>
> the sun.
Only during full moon.
Date: 24 Aug 2012 16:53:35
Message: <op.wjkcbft8ufxv4h@xena>
On Fri, 24 Aug 2012 09:22:17 +0200, Thomas de Groot <tho### [at] degrootorg>
>    light_source{
>      SunPosition
>      color SunColor
>      area_light
>      SunDis*x, SunDis*z,
>      5, 5
>      adaptive 2
>      jitter
>      circular
>      orient
>      parallel
>      point_at <0, 0, 0>
> Thomas
Yes, that works out to 0.93% closer than my 1% guesstimate :)
-Nekar Xenos-
Date: 24 Aug 2012 22:20:01
Message: <web.5038353b58ab29285de7b680@news.povray.org>
Which is factor of approximately half a million when the Moon is full.
Gotta love that non-linear perception.
Date: 25 Aug 2012 03:10:04
Message: <50387a4c$1@news.povray.org>
Perihelion / Aphelion difference ;-)
