POV-Ray : Newsgroups : povray.general : issues with transmit parameter Server Time
29 Jul 2024 10:23:10 EDT (-0400)
  issues with transmit parameter (Message 1 to 4 of 4)
Subject: issues with transmit parameter
Date: 21 Apr 2012 13:55:00
Message: <web.4f92f364b28e974d19d56a5a0@news.povray.org>
Hello,
I have a problem with transparency while rendering. To make it simple I've made
an example to explain it. The scene consists of 3 cubes of different size,
placed one in another. The problem here is that if I put all the transmit
parameter to 1 with a white background; we should see only a completely white
picture. Here it's not the case, the last cube (the smallest and the one
surrounded by the 2 others) appears black. I don't know if a parameter is
missing in my code,... Here is the code:
#declare amb = 1;
#declare dif = 0;
#declare ref = 0.001;
    location <45,45,45>
    look_at 0
    angle 30
  background { color White}
box
      <10,10,10>, <-10,-10,-10>
        pigment{color White transmit 1}
        finish { ambient amb diffuse dif reflection ref }
box
      <6,6,6>, <-6,-6,-6>
box
      <2,2,2>, <-2,-2,-2>
The version I use is the 3.6.
So if someone can help me! :D
Thank you!
Subject: Re: issues with transmit parameter
Date: 21 Apr 2012 14:10:33
Message: <4f92f819$1@news.povray.org>
Le 21/04/2012 19:53, JolanYD nous fit lire :
> Hello,
Have a look at the text output: max trace level by default is 5 and I
guess you reach it.
global_settings{ max_trace_level 20 }
Date: 21 Apr 2012 15:12:15
Message: <4f93068f@news.povray.org>
> Hello,
3 nested objects means 6 surfaces to compute plus 1 for the background.
This makes 7 points.
max_trace_level default to 5, so you stop tracing at the 5th surface and
return black.
Outer box is 2 surfaces plus 1 or 3.
Second box add 2 surfaces for a total of 5, or the default value of
max_trace_level.
Third box adds 2 more abd gives black.
Solution:
Set max_trace_level to a value large enough to go through all surfaces,
in your case, that's 7 or larger.
As you have non-zero reflection, there is no other solution.
Date: 2 May 2012 04:30:01
Message: <web.4fa0efdaa6365eda9b527b2c0@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hello,
> return black.
> max_trace_level.
> Solution:
> Alain
Hello!
Thanks to both of you Alain and Le Forgeron, the solution is perfect!
Good bye!
