POV-Ray : Newsgroups : povray.general : Not a bug, I must have incorrect expectations Server Time
29 Jul 2024 16:19:25 EDT (-0400)
  Not a bug, I must have incorrect expectations (Message 1 to 6 of 6)
Subject: Not a bug, I must have incorrect expectations
Date: 23 Feb 2011 17:25:00
Message: <web.4d658891666c9b25f9c9f2a80@news.povray.org>
Hello,
I am pretty sure this is not a bug and I just have some incorrect expectations
of the materials but I would like to have someone kindly explain this
phenomenon.
I started making an object and have a cube and wanted to position glass boxes
around it's sides.  But I get that static like distortion inside the glass you
normally see when two planes overlap.  I've included the very short code below.
There is a line to rotate the object 1 degree about the y axis.  If you take
that one line out and run again, the distortion is gone.
As a bonus, the distortion only appears in the glassSide object that is rotated
270 degrees.
Am I doing/thinking about something wrong and this is the correct behavior?
Thanks,
BBB
#include "stones.inc"
#include "glass.inc"
#include "math.inc"
#include "textures.inc"
camera{ location <-2, 2, -3> look_at <0, 0, 0>}
light_source { <0, 20, -20> color White }
#declare glassSide = box { <-1.5, -.5, -1>
        <-1, .5, 1>
#declare glassBorder =
union
        object { glassSide }
        object { glassSide rotate <0, 270, 0> }
union
        box { <-1, -1, -1>
                <1, 1, 1>
                pigment { color rgb<0, 0, 1> }
        object
                glassBorder
                pigment { color rgbf<1, 1, 1, 1> } interior {I_Glass} finish{
phong 0.9 phong_size 40 reflection 0.1 }
        scale 1.3
        rotate <0,1,0> /* comment out this line */
Subject: Re: Not a bug, I must have incorrect expectations
Date: 23 Feb 2011 18:06:12
Message: <4d6592e4$1@news.povray.org>
> Hello,
> phenomenon.
> 270 degrees.
> Thanks,
> BBB
> #include "math.inc"
> camera{ location<-2, 2, -3>  look_at<0, 0, 0>}
> light_source {<0, 20, -20>  color White }
> #declare glassSide = box {<-1.5, -.5, -1>
>          <-1, .5, 1>
> union
>          object { glassSide rotate<0, 270, 0>  }
> union
>          box {<-1, -1, -1>
>                  <1, 1, 1>
>          object
>                  glassBorder
>          scale 1.3
>          rotate<0,1,0>  /* comment out this line */
You DO have coincident surfaces between the blue box and the transparent
ones.
Just add "scale 1.0001" to the blue box and the problem disapears.
Also, you should use a merge of the two transparent boxes.
Date: 23 Feb 2011 19:34:51
Message: <4d65a7ab@news.povray.org>
> ones.
That ones been asked several times lately, and it's a VFAQ topic on the
Wiki. I had a look and it didn't mention the scale solution so I updated
it to include that as another possible fix ... so next time it's asked
you can refer them if you'd like:
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_20
Date: 23 Feb 2011 20:45:00
Message: <web.4d65b80a691ad14e7d0afb200@news.povray.org>
> ones.
> Alain
Hey, thanks.  I knew about my surfaces.  It just seemed weird that at certain
angles it seemed to be ok.  Which then got me doubting that I knew what I was
doing.  Which I didn't.  But now I do.
Thanks again
Date: 23 Feb 2011 20:50:00
Message: <web.4d65b91b691ad14e7d0afb200@news.povray.org>
> Alain
Oh, I forgot to ask.  Why a merge?  The two transparent boxes do not have any
shared area.  Which is what I thought a merge helped with.  Is this not the
case?
Date: 24 Feb 2011 13:26:52
Message: <4d66a2ec@news.povray.org>
>> Alain
> case?
Looking at your code again, and effectively, a merge is not needed in
this case.
I had the impression that the transparent boxes did overlap. Adding some
colour to them helped showing that there is no overlap.
As to why artefacts appeared or not after a small rotation: You may get
lucky sometimes and when viewed from a precise direction, you may always
detect the surfaces in the same order. The ior may, or not, have an effect.
