POV-Ray : Newsgroups : povray.general : Returning the file name. Server Time
11 Oct 2025 18:23:51 EDT (-0400)
  Returning the file name. (Message 1 to 9 of 9)
Subject: Returning the file name.
Date: 13 Sep 2010 16:00:56
Message: <4c8e82f8$1@news.povray.org>
Is there a method of returning the file name to a variable, of the scene
I am rendering? I would also like to get the file path as well.
I want to do some recursive work with the output of the previous frame
in an animation.
Best Regards,
Subject: Re: Returning the file name.
Date: 13 Sep 2010 16:29:00
Message: <4c8e898c$1@news.povray.org>
Le 13/09/2010 22:01, Stephen nous fit lire :
> in an animation.
You can have the current frame number (frame_number), but we are weak on
the string functions. (converting the number in a string is fine, but I
do not know how to get the current scene filename, so you might have to
hardcode it)
For using the previously rendered image, add +L<path of the render
directory> in your option (especially with that settings which might be
set or not: to render all files in one directory) (if not rendering from
./ to ./ )
http://www.povray.org/documentation/view/3.6.1/228/
http://www.povray.org/documentation/view/3.6.1/232/
Date: 13 Sep 2010 17:18:26
Message: <4c8e9522$1@news.povray.org>
> hardcode it)
Thanks for your reply Le
I thought that be the case but I was hoping that there was some
undocumented function that everyone but me knew.
It is a slight pain to change the code manualy as I save my files
incrementally, a lot, as I make changes in the scene.
> ./ to ./ )
I’m doing this as a sample scene for Bishop3D so my audience may not
know too much about changing the Library_Path in povray.ini. I was
hoping to automate some of it.
  Maybe a feature for Pov 4.0 ;-)
Best Regards,
Date: 13 Sep 2010 17:53:17
Message: <4c8e9d4d@news.povray.org>
Stephen wrote:
> Thanks for your reply Le I thought that be the case but I was hoping
> that there was some undocumented function that everyone but me knew.
I don't think so. What you can do, though, is call POV-Ray from
the command line where you can control the file names and even pass
them to the scene via generated include file.
Maybe source control should be integrated into the Windows editor ;)
Date: 13 Sep 2010 20:15:01
Message: <web.4c8ebe4561d0e05a6a99b6f80@news.povray.org>
That actually crossed my mind a while ago - making a full IDE type environment
for POV-ray.  I like the idea of having a project file that tracks the scene
files, included files, images, etc.  Even better if it has the ability to jump
between identifier definitions and their references across files...
At one point I was looking into existing IDEs that have the ability to syntax
highlight or 'compile' for any language that you give it a definition file for.
The idea is that it has already been done very well, and this would simply be
the reuse of existing packages.
Anyway, is providing a way to read the file name something that could be done
easily?  Could it cause problems from a security standpoint?  I'm sure this has
come up before, but if it is going to be considered it would seem to require
several variables (to allow the user to determine the names of scene files and
output files, which may be different).  Would it be better to consider allowing
a scene file to read what options it was called with?  This would be the options
as specified in the povray.ini, scene.ini, and command line - for instance, a
scene could know whether or not anti-aliasing was used.
-Reactor
Date: 13 Sep 2010 22:20:00
Message: <web.4c8edb8861d0e05a13ee07b00@news.povray.org>
Do you increment the end of a base filename?
Loop useing the file_exists(S) function untill it fails, then use the one
before.
Stephen S
Date: 14 Sep 2010 03:36:30
Message: <4c8f25fe$1@news.povray.org>
Ever heard of povclipse ?
povclipse ran on eclipse.
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
Date: 14 Sep 2010 20:20:00
Message: <web.4c90102461d0e05a6a99b6f80@news.povray.org>
.... I have now!
I don't know why I missed it before, although it does sound vaguely familiar.
I'll probably give it a shot later this evening.
-Reactor
Date: 16 Sep 2010 03:16:29
Message: <4c91c44d$1@news.povray.org>
> before.
That is a smart idea, Stephen.
The scene is for Miri as it is here birthday later this month. The code
might encourage her to delve into SDL. ;-)
Best Regards,
