POV-Ray : Newsgroups : povray.general : csg drawing Server Time
29 Jul 2024 22:31:35 EDT (-0400)
  csg drawing (Message 1 to 8 of 8)
Subject: csg drawing
Date: 28 Jul 2010 05:50:01
Message: <web.4c4ffcd27abcb1ec6556a6ea0@news.povray.org>
I am sure this question has been asked many times before but I am really lost on
this. How can I draw cabinet countertops(marble) using povray csg functions?
Or is there somthing better suited for this task in povray, another command etc.
I am not sure if CSG drawing is the best method for free(by free I mean any
direction in 3d xyz) simple shape drawing in povray.
I will appreciate any help you would provide, thank you
Subject: Re: csg drawing
Date: 28 Jul 2010 06:51:39
Message: <4c500bbb$1@news.povray.org>
> Hi,
> lost on this. How can I draw cabinet countertops(marble) using povray csg
> functions? Or is there somthing better suited for this task in povray,
   A simple countertop can be done using CSG with just a union of a box, four
spheres on the corners and four cylinders along the edges. Or you can use
superellipsoids, or even isosurfaces with the f_rounded_box function.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 28 Jul 2010 07:15:01
Message: <web.4c5010c3cd9ee7f16556a6ea0@news.povray.org>
> > Hi,
Jaime, thanks for answering, actually I asked the question wrongly, a normal
cabinet countertop can be made from povray's own BOX or a box shape I exported
from 3d max.
How about corner cabinets, they are not rectangle shaped when you look at them
from top down but irregular shapes, not box shapes.
What function is best for this purpose? I appreciate your answers.
Date: 28 Jul 2010 07:23:12
Message: <4c501320@news.povray.org>
> from 3d max.
   Ah... then perhaps a prism will work.
Date: 28 Jul 2010 16:40:17
Message: <4c5095b1$1@news.povray.org>
> Jaime Vives Piqueres<jai### [at] ignoranciaorg>  wrote:
>>> Hi,
> from 3d max.
For that, I'd use a prism. It allows you to create many arbitrary
shapes. The only thing is that the corner from the top to the sides are
always sharp.
Date: 29 Jul 2010 02:50:35
Message: <4c5124bb$1@news.povray.org>
optima wrote:
> Hi,
Using CSG to 'draw' complex shapes from the palette of available
primitive shapes in POV-Ray requires design ingenuity and generally
appeals to artists who wish to rise to that challenge.  The gain, beyond
the satisfaction of exercising such ingenuity, is generally better
results from the lighting and texturing of the model.
Specifically, the alternative, some form of mesh model, can introduce
artifacts, which result from the illusionary 'smoothing' of the
underlying triangles of the mesh surface. The accuracy of the surface
will always be limited by the number of triangles used to describe it.
Meanwhile the POV-Ray shapes have surfaces which are described
mathematically to the ray-tracer, never resorting to mesh-surface
analogues to intermediate, and so these surfaces have virtually
unlimited resolution.
To gain facility using POV-Ray's CSG, especially working from the native
SDL script, is going to require some commitment of time and effort.
That said, counters, cabinets, and so on are usually appropriate
subjects for CSG modeling because generally they can be 'constructed'
from pieces that can be 'machined' in the virtual world of CSG in a way
that mimics how it would be done in the real world.
-Jim
Date: 29 Jul 2010 03:54:04
Message: <4c51339c$1@news.povray.org>
...and to visually help with CSG building, the use of either Moray
(http://www.stmuc.com/moray/index.html) or Bishop3D
(http://www.bishop3d.com/index.htm) is recommended. Both are free at this
moment. Note however that Moray is not supported for the time being and
renders directly only with POV-Ray 3.5, but its povray output can be very
easily imported in later versions.
Date: 29 Jul 2010 03:59:12
Message: <4c5134d0$1@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> schreef in bericht
news:4c51339c$1@news.povray.org...
> .... Both are free at this moment.
My mistake :-(    Only Moray is free at this moment.
