POV-Ray : Newsgroups : povray.general : fastprox02 error? Server Time
20 Nov 2025 21:23:07 EST (-0500)
  fastprox02 error? (Message 1 to 8 of 8)
Subject: fastprox02 error?
Date: 31 Aug 2009 04:36:01
Message: <4a9b8b71@news.povray.org>
This is for Sam:
Using the proximity macro fastProx3() I get a parse error: ".... line 344:
Parse Error: Cannot assign uninitialized identifier."
This corresponds to the code: #local pf=eval_pigment(fpt,<Xv,Yv,Zv>);  in
the resample() macro.
No errors using fastProx() or fastProx2().
I am sure you know what went wrong (or what I do wrong for that matter).
My code line for this reads:
fastProx3(FinalBuilding, min_extent(FinalBuilding),
max_extent(FinalBuilding), <10, 10, 10>, 2, 20, <2, 2, 2>)
All the best,
Subject: Re: fastprox02 error?
Date: 31 Aug 2009 11:35:00
Message: <web.4a9bec5f2c6eb31e4bd5cd8e0@news.povray.org>
> This is for Sam:
> All the best,
> Thomas
This probably won't help you much but I had the exact same error for fast sss2
in fastprox.inc, yet using Blend2Pov so your problem and workaround could be
totally different:
My problem was that I was referring to "Final Building" before it was really
defined regarding the order in which things are parsed.
So what I did was call the macro inside the object block (Povmat text file in
blend2Pov)Also I needed the lpos variable (light position) so I made sure its
definition was done before the call too.
Date: 31 Aug 2009 16:05:06
Message: <4a9c2cf2@news.povray.org>
Thomas de Groot wrote:
> This is for Sam:
Is that in line 344 of my code or yours?
No, I have no clue. I typed up this test and it parsed and rendered just
fine in both 3.6 and 3.7b:
#include"fast_prox02.inc"
#declare FinalBuilding=
union{
  box{-1,1 scale<4,2,2>}
  box{-1,1 scale<2,4,2>}
  box{-1,1 scale<2,2,4>}
object{
  FinalBuilding
  pigment{
   fastProx3(
    FinalBuilding,
    <2, 2, 2>, 4, 20, <1, 1, 1>*8
   color_map{[.25 rgb 0][1 rgb 1]}
Run that code to see if you still have problems. I'll try to keeping
helping until it works for you, if you wish.
Happy Povving :)
Sam
Date: 1 Sep 2009 05:26:44
Message: <4a9ce8d4$1@news.povray.org>
Sam, Thank you for your answer.
I got the clue when I saw that the error referred to eval_pigment, and the I
realized I had not included functions.inc!!!!
Aaaaarrrgh........ [hides deep below ground in full shame]
Date: 1 Sep 2009 15:11:11
Message: <4a9d71cf@news.povray.org>
It sounds like the fault is mine; I forgot to mention the functions.inc
requirement...
Date: 1 Sep 2009 18:43:46
Message: <4a9da3a2$1@news.povray.org>
> requirement...
#ifndef (Functions_Inc_Temp) #include "functions.inc" #end
That way you don't need to remember the dependencies.
Date: 1 Sep 2009 19:31:14
Message: <4a9daec2$1@news.povray.org>
>> functions.inc requirement...
Thanks!
Date: 2 Sep 2009 01:32:41
Message: <4a9e0379$1@news.povray.org>
Why not include it unconditionally?
You don't lose much parsing time, and the functions.inc code is
/designed/ to be robust against multiple inclusion.
