POV-Ray : Newsgroups : povray.general : remove array element after N uses? Server Time
22 Dec 2025 08:51:15 EST (-0500)
  remove array element after N uses? (Message 1 to 10 of 15)
Subject: remove array element after N uses?
Date: 25 Mar 2009 10:18:54
Message: <49ca3d4e$1@news.povray.org>
Lets say that I have an array of vectors, and that I wish to use its
elements a variable number of times (which might be different for each
element) and then remove the used element from the array.
The only thing that I can come up with would be to use a 3D array like this:
//      randVectorMMR Macro by [GDS|Entropy]
//      For element reuse capability
#macro randVectorMMR(Array,ctr,Min,Max,rMin,rMax)
 #local i=0;
 #while (i<ctr)
  #declare Array[i][0][0] = <RRand(RsA, Min, Max),RRand(RsA, Min,
Max),RRand(RsA, Min, Max)>;
  #declare Array[i][1][0] = <0,0,0>;
  #declare Array[i][1][1] = <0,RRand(RsA, rMin, rMax),0>;
 #set i=i+1;
//      RRand Macro by Chris Huff
#macro RRand(RS, Min, Max)
 (rand(RS)*(Max-Min) + Min)
//      Round macro by [GDS|Entropy]
//      Adapted from Trevor G Quayle function
#macro Round(Number,RoundTo)
 #if (Number >= 0)
  1*int(abs(Number)*pow(10,RoundTo)+0.5)/pow(10,RoundTo)
 #else
  -1*int(abs(Number)*pow(10,RoundTo)+0.5)/pow(10,RoundTo)
//      VRound macro by [GDS|Entropy]
#macro VRound(Vector,RoundTo)
 <Round(Vector.x,RoundTo),Round(Vector.y,RoundTo),Round(Vector.z,RoundTo)>
#declare ctr = 10;
#local maxReuse = 10;
#local minReuse = 1;
#declare myArray = array[ctr][2][2];
randVectorMMR(myArray,ctr,1,5,minReuse,maxReuse)
#local i = 0;
#while (i < dimension_size(myArray,1))
 #local pos = myArray[i][0][0];
 #local use = myArray[i][1][0];
 #local ass = VRound(myArray[i][1][1],0);
 #debug concat("Array Value: ", vstr(3,pos,",",3,3)," ")
 #debug concat("Assigned Reuse : ", vstr(3,ass,",",3,3)," ")
 #debug concat("Used: ", vstr(3,use,",",3,3)," times \n")
 #if (use.y < maxReuse & use.y < ass.y)
  object {
   foo
   translate pos
  #declare myArray[i][1][0] = myArray[i][1][0] + 1;
  #local i = i;
 #else
  #local i = i + 1;
#undef myArray
That way sucks, and it doesn't remove the element from the array.
Whats a better way of doing this?
ian
Subject: Re: remove array element after N uses?
Date: 25 Mar 2009 11:40:00
Message: <web.49ca4fd59fb46029c1f399840@news.povray.org>
Oh, those pesky OOP-spoilt greenhorns! ;)
When I was still young and handsome, such information would be stored in a
separate array, like this:
    10 DIM x(100),y(100),z,used%(100)
    20 FOR loop% = 1 TO 4711
    30   LET i% = RND(100) + 1
    40   LET used%(i%) = used%(i%) + 1
    50   PRINT "<";STR$(x(%i));",";STR$(y(%i));","STR$(z(%i));">"
    60 NEXT loop%
    70 END
    5 RANDOMIE TIME
    12 GOSUB 1000 : REM fill data
    50   PRINT "<";STR$(x(%i));",";STR$(y(%i));","STR$(z(%i));">";
    55   PRINT " used ";STR$(used%(i));" times"
    LIST -100
    5 RANDOMIE TIME
    60 NEXT loop%
    70 END
    READY
    RUN
    SYNTAX ERROR IN LINE 5
    READY
    LIST 5
    5 RANDOMIE TIME
    READY
    5 RANDOMIZE TIME
    RUN
    LINE DOES NOT EXIST IN LINE 12
    READY
(Yeah, those were the days! You just flipped the power switch, and your
programming IDE would be up and running in 5 seconds... ah, modern
technological advancement has deprived us of all that joy...)
.... then someone invented structs (oh, well, "records" for me back then, because
I went for Turbo Pascal)...
But I'm getting a bit off topic... so back to your problem:
First thing to know: No, POV SDL unfortunately doesn't have something like
structs. Nor does it have dynamic lists. Be happy and content that you don't
have to mess around with line numbers ;)
Why use a 3-dimensional array when a 2-dimensional one will do the job?
#declare Array[i][0] = <...>;
#declare Array[i][1] = <0,0,0>;
#declare Array[i][2] = <0,RRand(RsA, rMin, rMax),0>;
Then, to get rid of an entry of such an array, you could use:
#undef Array[i][0]
#undef Array[i][1]
#undef Array[i][2]
and check for #ifdef(Array[i][0]) when you loop through the array.
I guess that's as close as you can get to what you want.
Date: 25 Mar 2009 11:55:00
Message: <web.49ca53b89fb460296dd25f0b0@news.povray.org>
[snip nostalgia]
Hmm, looks very much like Acorn BASIC. Although, 5 seconds? If that were a beeb
you'd be ready to go before your finger had even left the power button...
(GOSUB, eww. PROC was the only way forwards :-) )
Date: 25 Mar 2009 12:23:08
Message: <49ca5a6c@news.povray.org>
That included the time for the TV tube to warm up. ;-)
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 25 Mar 2009 12:50:00
Message: <web.49ca600c9fb46029c1f399840@news.povray.org>
Not on the Amstrad CPC 6128 I was toying around with ;)
Locomotive Basic 1.1 ((C) 1985 if I remember correctly...)
The Sinix Basic I had to work with about 20 years later was a bit more
sophisticated... still I was glad it was only a few months' assignment ;) (Much
of the stuff I had to deal with was old-school code, with lots of GOTO
<line_number> in it >_<)
It was quite fun though: As the old Sinix machine was scheduled for ultimate
powerdown, the task was to port those programs... to VBA of course :P
I ended up writing a parser for the old Sinix Basic code that would
auto-generate a VBA module, and a library of subroutines that would simulate
the Sinix Basic's formatted input, output and file access functions with all
their peculiarities...
Why do a brain-dead job when you can write a brain-dead piece of software to do
it for you? Usually it costs about the same time it actually saves, but it sure
as hell is a good deal more fun ;) (plus, it tends to impress people)
Date: 25 Mar 2009 14:02:14
Message: <49ca71a6$1@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.49ca4fd59fb46029c1f399840@news.povray.org...
<SNIP>
o_O'
Eew...BASIC...I'd rather learn just get it over with and Assembly (its on
the TODO list)..
Ubuntu will boot on a very old machine I have from the liveCD in just over 6
times that...not that bad considering that includes GNOME.
> because
Structs rock.
> don't
Dynamic lists also rock.
I did mess around with BASIC back in elementary school (early/mid 80's).
That is when I decided that I didn't like it much, and chose to avoid any
language with Basic in the name.
Damn...maybe it would be seriously worth the effort of tracking down
whatever code handles structs and dynamic lists and etc.. in the language
that pov was written, and integrating that into povray with some nice SDL
implementation. I'm more than sick of needing and not having those kinds of
things.
http://www.haskell.org/haskellwiki/POV-Ray_SDL_project
Someone has the right idea.
They said this too: "Endless flamewars have raged over the subject of
whether the SDL should become object-oriented."
When did THAT happen?! O_o'
This newsgroup seems rife with thoughtful discourse and quite a high SNR,
not "endless flamewars"...
Beyond being just something that I threw together to do something like what
I wanted, I decided that I might want to add an absurd amount of
functionality later and that this would be the most logical way to leave my
options open. For example I might add other related things to each of the
dimensions, and it might be best to keep each category of data seperate.
> #undef Array[i][0]
> #undef Array[i][1]
> #undef Array[i][2]
I might be able to adapt such a thing to do what I wanted in the first
place. I guess if the following (untested) macro works, I could just call it
once the established number of "uses" has been reached to purge the elements
I need to.
#macro
undefElement(Array,dim1Element,dim2Element,dim3Element,dim4Element,dim5Element)
 #local numDimensions = dimensions(Array);
 #if (numDimensions = 1)
  #undef Array[dim1Element]
 #if (numDimensions = 2)
  #undef Array[dim1Element][dim2Element]
 #if (numDimensions = 3)
  #undef Array[dim1Element][dim2Element][dim3Element]
 #if (numDimensions = 4)
  #undef Array[dim1Element][dim2Element][dim3Element]][dim4Element]
 #if (numDimensions = 5)
  #undef
Array[dim1Element]][dim2Element][dim3Element]][dim4Element][dim5Element]
So I wasn't too far off from what I was looking for. That is a good sign.
I suppose I could just redefine the wiped element with interpolated
vectors...or something...should I need to, by using the above macros
functionally mirror image.
As a side note, why in the nine hells aren't there Round and VRound macros
in pov to start with??
They seem kind of useful to just have been left out...then again...so do
structs, enums, custom types, multi-datatype arrays, type casting, type
conversion and list<T>'s...
More of a side note....it would be cool to create a set of macros which
emulated basic circuit components, so that one could produce such an act of
irony as a properly functioning raytraced circuit...
Hmm....to make a macro which can produce accurate semiconductor curves....
Gah! I need to finish this damn macro suite...no new projects! :-p
ian
Date: 25 Mar 2009 14:50:01
Message: <web.49ca7cb69fb46029219167190@news.povray.org>
I suspected it probably wasn't Acorn BASIC. The interpreter didn't worry about
LETs, and didn't say Ready at every prompt. Definitely a contemporary though!
Good job.
Whoops, this is veering a little off-topic now... :)
Date: 25 Mar 2009 15:40:00
Message: <web.49ca88269fb46029c1f399840@news.povray.org>
> things.
If I wasn't working on various other pieces of POV code, that's what I'd
probably be doing right now...
(Note however that "in the language that pov was written" would mean C until
only very recently, so nowhere close to dynamic lists whatsoever; and structs,
although C does have them, would have to be represented internally using
"arrays of members" as it were, because C can't create new structs at runtime.)
Yargh! Vade! >_<
Again, too much OO thinking for POV SDL. You can't store separate things in the
multiple dimensions of such an array anyway; and if one of your "subsections"
would need more elements, you'd need to add more elements to the other
"subsections" as well... not too bright.
But what you might want to do is:
#declare POINT  = 0;
#declare COUNT  = 1;
#declare RANDOM = 2;
#declare Array[i][POINT]  = <...>;
#declare Array[i][COUNT]  = <0,0,0>;
#declare Array[i][RANDOM] = <0,RRand(RsA, rMin, rMax),0>;
(That's basically how struct support would have to be implemented in POV
internally - except that we'd need to be able to store different things in the
array elements)
or maybe
#macro GET_POINT(a,i)
  Array[i][0]
#macro GET_COUNT(a,i)
  Array[i][1].x
#macro GET_RANDOM(a,i)
  Array[i][2].y
You can round using "int(x+0.5)", so no problem writing your own macros...
Yes, maybe the standard include files could use an overhaul, too.
.... and a new SDL grammar, as we're on it.
For the job we're doing, octrees would come in handy, too.
I think one of the greatest current limitations is the inability of arrays to
store elements of different types. Otherwise, structs could easily be simulated
by using identifiers holding constants, e.g.
#declare FIELD_FOO = 0
#declare FIELD_BAR = 1
#declare MyArray[FIELD_FOO] = <0,0,0>;
#declare MyArray[FIELD_BAR] = pigment { ... };
which still wouldn't be ideal, but still quite an improvement.
Date: 25 Mar 2009 16:57:23
Message: <49ca9ab3$1@news.povray.org>
news:web.49ca88269fb46029c1f399840@news.povray.org...
> until
> structs,
> runtime.)
I had a feeling it was C still; long ago I looked at the source when
considering adding new media scattering methods...then quickly abandoned
that idea when I discovered how much work would actually be involved with
the implementation of a new (to pov) algo.. :-|
> Yargh! Vade! >_<
Hmm? Sounds like something a norseman might shout just after boarding your
vessel and just before doing something awful with a large blade. ;-)
OO is the crack of programming. :-)
> You can't store separate things in the multiple dimensions of such an
All of the dim1 elements will have the same attributes, so in this case it
isn't really an issue, as they are just flags really. I do wish I could
store multiple datatypes though, as using vectors when all you want is a
flag is somewhat like the programming equivalent of a nasty hacked up
hairball; ugly, gross and not something you like having to deal with.
> #declare POINT  = 0;
> #declare COUNT  = 1;
So using different placed in dim2 would be better than having related vector
flags grouped in their own dimension?
It seems to me that it could become confusing and require code rewrites (for
grouping of like flags/misc) if one uses only 2d when thy might have a set
of flags in d2 for say, branching, child nodes, etc.. and more for
interpolated vectors or the like. It also seems that using those additional
attributes could become messy if they are just all over the place.
> the
> array elements)
I'd say step one would be to implement vector and integer/double/long
support in the same array, see what that took to do, and then fan out from
there.
> or maybe
>  Array[i][0]
> #end
>  Array[i][1].x
> #end
>  Array[i][2].y
> #end
I like that better, seems easier to use and keep track of. I still like the
idea of using multiple dimensions for related flags for my specific purpose,
as I won't have many categories. It isn't so much that it really matters, so
long as whatever method used works and does so quickly. Even so, for general
extensibility, get/set macros for the win. I'll need to try both using
stupid amounts of elements, and then compare the stats.
True, but sometimes you just want to use a thing, without having to go find
math.h to write your own.
There are a lot of little things like that in pov.
Agreed. Especially the textures, a lot of them kinda suck...like the
metals...and glasses...
I'd like to see a nice influx of textures created by the community. Waters,
glasses, metals, stones....there are so very many great ones I've seen used
here.
A lot of the more esoteric macros in povray need example files too.
Maybe once I get my macro suite to a good place, I could get the snowball
rolling on this..assuming they would actually use any files I created.
Probably if they would, I'd not be alone in wanting to do this.
Yes. My vote is cast with using more common C-ish things, as those who
program will quickly adapt, and those who don't will spend the same amount
of time learning as before, but will also be familiar with java/c#/c++ ish
languages without even knowing it. Good for everyone.
And hash tables(with a good many hashing methods), and heaps(with a lot of
heap types), and a proof of the riemann hypothesis, and and and ;-D
> to
> simulated
Indeed. I'd take any improvement at this point.
Any idea why they never did that?
*sigh* I might just have to track down the file(s) where they coded those
things and have a look...maybe it won't be the massive PITA that I get the
feeling it is...
ian
Subject: [OT] Nostalgia / Was: Re: remove array element after N uses?
Date: 25 Mar 2009 17:33:41
Message: <49caa335$1@news.povray.org>
Hash: SHA1
>> were a beeb
	Guess what? Somebody did a benchmark of an old 1986 Mac against a
dual core AMD64. And the winner is..... the 1986 Mac! By 9 tests to
8 (including a whopping six times faster boot sequence):
http://hubpages.com/hub/_86_Mac_Plus_Vs_07_AMD_DualCore_You_Wont_Believe_Who_Wins
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAknKozQACgkQd0kWM4JG3k8TCQCfQHSlH7oHl0sxvs/mLynEImeQ
dXUAnjCt3GBfJpePz2ACWYQUoTTHNuQJ
=79sN
-----END PGP SIGNATURE-----
