POV-Ray : Newsgroups : povray.general : how to call multiple instances of a macro? Server Time
18 May 2026 13:13:09 EDT (-0400)
  how to call multiple instances of a macro? (Message 1 to 10 of 13)
Subject: how to call multiple instances of a macro?
Date: 15 Feb 2009 08:51:52
Message: <49981df8$1@news.povray.org>
I have the following macro, but I can't call multiple instances of it
without overriding the previous values...how can I rewrite this macro to fix
this?
I think the #declare is to blame, but it is also what makes it work...catch
22?
It is terribly annoying.
#declare Sp = 60;
#macro randVector(ctr,Min,Max,Method)
 #local i=0;
 #while (i<ctr)
  #switch (Method)
   #case (0)
    #declare randVectArray[i] = <RRand(RsA, Min, Max),RRand(RsA, Min,
Max),RRand(RsA, Min, Max)>;
   #break
   #case (1)
    #declare randVectArray[i] = <sin(RRand(RsA, Min, Max)),RRand(RsA, Min,
Max),tan(RRand(RsA, Min, Max))>;
   #break
   #case (2)
    #declare randVectArray[i] = <sin(RRand(RsA, Min, Max)),atanh(RRand(RsA,
Min, Max)),tan(RRand(RsA, Min, Max))>;
   #break
   #case (3)
    #declare randVectArray[i] = <asin(RRand(RsA, Min, Max)),atanh(RRand(RsA,
   #break
   #case (4)
    #declare randVectArray[i] = <acosh(RRand(RsA, Min,
Max)),asinh(RRand(RsA, Min, Max)),tan(RRand(RsA, Min, Max))>;
   #break
   #case (5)
    #declare randVectArray[i] = <cos(i),i,sin(i)>;
   #break
 #set i=i+1;
#declare randVectArray = array [Sp];
thanks!
ian
Subject: Re: how to call multiple instances of a macro?
Date: 15 Feb 2009 11:19:33
Message: <49984095@news.povray.org>
> this?
Try something like this:
#macro Fill(A,N)
   #local i = 0;
   #while (i < N)
     #declare A[i] = i;
     #local i = i + 1;
#declare Sp = 60;
#declare randVectArray = array[Sp];
Fill(randVectArray, Sp)
#declare Sp2 = 50;
#declare randVectArray2 = array[Sp2];
Fill(randVectArray2, Sp2)
Date: 15 Feb 2009 12:06:25
Message: <49984b91$1@news.povray.org>
Ahhh...
That makes sense, now that I see it.
Would one be able to pass signs (+ - / *), isosurface function names and
things like atan and sin in some manner as that as well?
I've been trying to do something like this: (pardon the crapcode)
#macro isoFunction(operator, funcName, xVal, yVal, zVal, P0, P1, P2, P3, P4,
P5, P6)
 #local isoFunc = function {operator((funcName(xVal*x, xVal*y, zVal*z))};
 isoFunc(x,y,z)
#declare foo = isoFunction(x+,f_noise3d,5,5,0.1,0,0,0,0,0,0);
No joy obviously.
You wouldn't happen to know if it is possible to concat strings as variable
names, would you? #local myObj = concat(obj + i); would be great... :-D
Thanks!
ian
"Christian Froeschlin" <chr### [at] chrfrde> wrote in message
news:49984095@news.povray.org...
>> fix this?
> #macro Fill(A,N)
>   #local i = 0;
>   #while (i < N)
>     #declare A[i] = i;
>     #local i = i + 1;
>   #end
> #end
> #declare Sp = 60;
> #declare Sp2 = 50;
Date: 15 Feb 2009 13:26:30
Message: <49985e56@news.povray.org>
no
yes (well, the function itself, not the name as string)
#macro DoubleFunc(F)
   function {2*F(x,y)}
#declare f            = function(x,y){x*y}
#declare f_double     = DoubleFunc(f)
sort of - SDL seems to handle the built-in functions
differently from user-defined functions:
#declare atan2_double = DoubleFunc(atan2) // error
#declare atan2_double = DoubleFunc(function(x,y){atan2(x,y)}) // works
Yuck ;) Actually I wasn't even sure if you intended
this to return a function or a value.
No. "POV-Ray macros are a strange mix of macros and functions",
and yes I'm quoting the documentation ;) But that's beside the
point, you should use an array whenever you even think about
appending an index to a variable name in code.
Date: 15 Feb 2009 13:40:27
Message: <4998619b$1@news.povray.org>
> no
Of course, no one prevents you from passing a function
which performs the operation, whatever your reasons:
   #declare op_add  = function(x,y){x+y}
   #declare op_sub  = function(x,y){x-y}
   #declare op_mult = function(x,y){x*y}
   #declare op_div  = function(x,y){x/y}
   #declare op_avg  = function(x,y){0.5*op_add(x,y)}
   #macro ConcatFunc(OP,F1,F2)
     function {OP(F1(x,y,z),F2(x,y,z))}
   #declare f_combined = ConcatFunc(op_avg, f_bozo, f_agate)
Just think clearly about what you wish to achieve before doing it ;)
Date: 15 Feb 2009 14:29:05
Message: <49986d01$1@news.povray.org>
Hmm..well it seems that due to those limitations what I wish to do would
actually be counterproductive.
The main reason that I wished to pass signs and iso func names was to create
what would essentially be an overloaded an isosurface function builder macro
(well..as close as pov can come to overloaded functions) that could be
linked to various loops and PRNGs, mainly to decrease the code needed to
accomplish certain things and compress all possible incarnations of
isosurface into a single line macro call.
I wanted to do something similar with the build-in functions too.
It is times like these that I wish pov was more like c# and less like SDL..
Yeah the crapcode came about from the fact that while I was writing it, I
thought: "hells..this isn't going to work..damned SDL" and I just stopped
writing at that point. :-)
Ah, well..off to divine the depths of the Trace() function.
Thanks!
ian
news:49985e56@news.povray.org...
> no
>   function {2*F(x,y)}
> #end
>> variable names, would you? #local myObj = concat(obj + i); would be
>> great... :-D
Date: 11 Mar 2009 16:30:46
Message: <49b81f76@news.povray.org>
>> no
>   #end
I have a related question - is it possible to pass the name of a macro
as a parameter in another macro? I notice in the documentation that it
doesn't say that RVALUE can be a function, though apparently it can
based on your example, so can it be other things as well?
cshake
example:
#macro lamp1(location,pointat,brightness)
   light_source{...}
#macro lamp24(location,pointat,brightness)
   light_source{...}
#macro stringOfLights(Lamp,Center,Brightness)
   #local i=1;
   #while(i<10)
     Lamp(Center+i*x,Center+i*x+<point_vector>,Brightness)
     #local i=i+1;
stringOfLights("lamp1",<1,2,3>,10)
Date: 11 Mar 2009 18:15:52
Message: <49b83818$1@news.povray.org>
I don't think that's possible.
Well it does say RVALUE can be a USER_FUNCTION in 3.8.4.2.
I you want to have multiple macros building on your lamp1
to lamp24 you might write a wrapper macro as follows
#macro lamp(lamp_type,location,pointat,brightness)
#switch (lamp_type)
#case(1) lamp1(location,pointat,brightness) #break
#case(2) lamp2(location,pointat,brightness) #break
Date: 11 Mar 2009 22:05:00
Message: <web.49b86bb4dc08335801985dd0@news.povray.org>
  light_source{...}
#macro lamp2(location,pointat,brightness)
  light_source{...}
#macro ParseLiteral(s)
  #local FileName = "ParseLiteral_$$$.inc";
  #fopen ParseLiteral_FD FileName write
  #write (ParseLiteral_FD, s)
  #fclose ParseLiteral_FD
  #include FileName
  #local i=1;
  #while(i<10)
    ParseLiteral(Lamp) (Center+i*x,Center+i*x+<point_vector>,Brightness)
    #local i=i+1;
#local i=rand(R)*10;
stringOfLights(concat("lamp", str(i,0,0)),<4,5,6>,10)
POV SDL may be cumbersome at times, but let nobody say it wasn't flexible...
Date: 12 Mar 2009 02:15:38
Message: <49b8a88a$1@news.povray.org>
>   #include FileName
> #end
>   #local i=1;
>   #while(i<10)
>     #local i=i+1;
>   #end
> #end
Most helpful. Very much looks like a hack that wasn't exactly intended,
but works perfectly.
I decided to use a slightly more segmented version to reduce a little
bit of disk writing during parse:
   #declare ParsedLiteralFile = "ParseLiteral_$$$.inc";
   #fopen ParseLiteral_FD ParsedLiteralFile write
   #write (ParseLiteral_FD,s)
#macro ParsedLiteral()
   #include ParsedLiteralFile
ParseLiteral(macroName)
#local i=1;
#while(i<20)
   ParsedLiteral()(macro parameters)
   #local i=i+1;
I wonder how much overhead this really causes, I figure that Christian
Froeschlin's method of just using a selection macro and assigning
numerical values to each macro name would be slightly more efficient
when parsing, but involves more work for the user and is not very flexible.
