POV-Ray : Newsgroups : povray.general : A question of Style Server Time
13 Oct 2025 04:25:12 EDT (-0400)
  A question of Style (Message 1 to 9 of 9)
Subject: A question of Style
Date: 4 Jul 2008 12:57:46
Message: <486E7385.8010309@joplin.com>
I've made several models and other things(macro,functions...) with POV.
Awhile back I got tired of having a test program for each of these. So
now I use #ifndef(Get)in all my Pov models and include files to bracket
a camera and lights and the object and what ever else I need to test the
file. Before you include the file you have to #declare Get=1;.
  I was wondering do many use this trick?
  And if you do what type do you save the file as?
  I save objects like a boat,rock as a '.pov' and macros as an '.inc'.
Subject: Re: A question of Style
Date: 4 Jul 2008 13:45:56
Message: <486e61d4@news.povray.org>
"Leroy Whetstone" <lrw### [at] joplincom> wrote in message
news:486### [at] joplincom...
> Awhile back I got tired of having a test program for each of these. So now
> I use #ifndef(Get)in all my Pov models and include files to bracket a
I think quite a lot of people use a fairly wide range of different but
similar techniques to enable an include file to be rendered directly (for
testing etc.). There was quite a long discussion a while ago about
incorporating something into POV-Ray to enable the #include file chain to be
interrogated when the file is parsed, so that a generic technique could be
used to implement this. The discussion arose because having to declare
variables in all of the scene files that use a particular include file is a
bit of a pain.
I don't recall whether any concensus was ever reached or whether anything
made it into the development stream. My vote would go for a read-only array
listing the files in the #include chain. If the array is length 0 you know
that the user has asked to render the current file and can add a camera,
lights etc. It would also enable more sophisticated decisions to be made by
examining the actual contents of the array.
I store anything designed to be able to be included into scene files with an
extension of '.inc'. Files designed as top-level files (scene files,
examples, document image generators etc) as '.pov'.
Chris B.
Date: 4 Jul 2008 18:03:34
Message: <486e9e36@news.povray.org>
> bit of a pain.
> Regards,
> Chris B.
The only related change I know about so far is that POV-Ray for Windows
now supports an 'alternate render file'.  Then again, I've been away for
a while.  I've still been dreaming of having a main_scene_file keyword,
but I do like your array (array of strings I hope) even better.   It can
fill the same purpose, but also provide more information.
Charles
Date: 4 Jul 2008 18:56:02
Message: <486eaa82@news.povray.org>
> bit of a pain.
For some variables in some models, I have an #ifndef-#end block to
#local declare a default value.  I don't do this with everything because
   I don't want to fall into the habit of using default values for
everything.
John
Date: 4 Jul 2008 19:22:15
Message: <486eb0a7@news.povray.org>
"Charles C" <"nospam a nospam.com"> wrote in message
news:486e9e36@news.povray.org...
> Chris B wrote:
>> My vote would go for a read-only array listing the files in the #include
>> chain. If the array is length 0 you know that the user has asked to
>> render the current file and can add a camera, lights etc. It would also
>> enable more sophisticated decisions to be made by examining the actual
I'd missed that. I see it's described in the thread on 3.7 Beta 20b at:
http://news.povray.org/povray.beta-test/thread/%3C461a2c3e@news.povray.org%3E/?ttop=277440&toff=50
 That certainly would address this particular issue for Windows users.
> I've still been dreaming of having a main_scene_file keyword, but I do
Yes. A read-only array of strings containing the file names was what I was
thinking/dreaming of. I think this would solve this problem in a tidy little
cross-platform way.
Chris B.
Date: 4 Jul 2008 19:48:25
Message: <486eb6c9@news.povray.org>
See also:
http://news.povray.org/povray.general/message/%3C45601108%241%40news.povray.org%3E/#%3C45601108%241%40news.povray.org%3E
> cross-platform way.
Sounds perfect to me :)
Charles
Date: 4 Jul 2008 20:11:45
Message: <486ebc41@news.povray.org>
I name scene files .pov and just about everything else .inc.
I do something like #ifndef(Main_Scene_File)  ... Then check for other
common variables like colors to be a little bit safe.... Then later in
the include file, I give it it's own camera and lighting, maybe a floor
etc all of which are ignored unless Main_Scene_File matches a string
which happens to be the same as the file name of the include file.   I'm
really into making object includes self-demonstrating.
For large include files which are themselves only part of something
bigger and can't easily self-demonstrate, I do something like:
#ifndef(Main_Scene_File) #include "myscene.pov"
#else
...(else parse this file)....
#end //end "#ifndef(Main_Scene_File)" from beginning of file
Charles
Date: 5 Jul 2008 12:05:37
Message: <486f9bd1$1@news.povray.org>
No I don't do that.
I keep everything related to a particular project (image | scene) on its
own directory.  Each directory has separate copies of four 'standard'
files: scene.ini, scene.pov, lightscamera.inc, and scene_setup.inc which
contain roughly the same, but evolving, set of tools in the form of
macros. I keep this discipline religously.  For the most flegling of
projects I start a new directory and copy in these four files.  I always
render from the .ini file, (nearly always.)  All includes are called in
the scene.pov.
If I want a quick test I copy something from insert->scene templates
menu and save it as 'test.pov' on a subdirectory. If the testfile takes
on a life of its own I can either include the lightscamera from the main
scene for better testing, or finally rename and refile it and include it
in the main scene.
Not sure why this works for me but it seems to and I have kept it up
with consistancy for years now. It sort of gives me the ability to start
with the same basic template of elements and take them in slightly
divergent directions without worrying about the impact on other things.
  Psychicly and creatively this is very important to me.  As long as I
maintain this basic working method it seems I am otherwise free of
remembering the details of some detailed super-standard.
It does set up the arcane situation that work I do on new techniques is
invariably catalogued under a particular project and I have to remember
where it is accordingly.  But mysteriously, that seems to work best.
Date: 7 Jul 2008 02:44:39
Message: <4871bb57$1@news.povray.org>
I do the reverse: I store camera, lights, and common variables in a
central location, also using #ifndef statements wherever possible. Then,
in the scene I want to render, I include this file. I can always
override the default variable states by declaring them before I do the
inclusion.
See the "Game Sprites" item in the Object Collection for an example.
-Mike
