POV-Ray : Newsgroups : povray.general : +am2 performance question Server Time
20 Nov 2025 17:21:59 EST (-0500)
  +am2 performance question (Message 1 to 6 of 6)
Subject: +am2 performance question
Date: 26 May 2008 03:00:45
Message: <483a601d$1@news.povray.org>
Hello,
when using +am2 (recursive antialiasing), are the corner samples shared
between their respective pixels, that is, is +am2 as fast as +am1 or is
it four times slower if no antialiasing takes place? Are the edge
samples reused?
You know you've been raytracing too long when...
you start thinking up your own "You know you've been raytracing too long
when..." sigs (I did).
		-Johnny D
Johnny D
Subject: Re: +am2 performance question
Date: 26 May 2008 04:17:36
Message: <483a7220@news.povray.org>
Jan Dvorak <jan### [at] centrumcz> wrote:
> Hello,
> samples reused?
  I actually don't know the exact details of the antialiasing algorithm
used, but I have the impression that no samples are shared between pixels
in either method. This is because antialiasing can be jittered, and if
that's the case, most samples wouldn't be at pixel edges and thus difficult
to share. (I have to admit, though, that I can think of variations where
samples can be jittered *and* shared between pixels. However, I don't know
exactly what POV-Ray is doing.)
Date: 26 May 2008 07:16:31
Message: <483a9c0f@news.povray.org>
>> Hello,
>> samples reused?
I don't see a problem with jittering a shared sample.  Samples can be
assigned to a particular place in the pixel, and this assignment used to
determine any sharing between pixels (or sub-pixels, since this is
adaptive); when the sample is actually traced, it can be jittered at
that time.
John
Date: 26 May 2008 08:15:02
Message: <483aa9c6@news.povray.org>
> that time.
  Which is what I said. :)
  Maybe if POV-Ray doesn't currently share antialiasing samples between
pixel someone could take a look how difficult it would be to make a patch
to do exactly that.
Date: 26 May 2008 12:37:48
Message: <483ae75c@news.povray.org>
Warp nous illumina en ce 2008-05-26 04:17 -->
>> Hello,
>> samples reused?
Acording to the documentation, there is a saving and reuse between adjacent
pixels and subpixels:
"The advantage of this method is the reduced number of rays that have to be
traced. Samples that are common among adjacent pixels and sub-pixels are stored
and reused to avoid re-tracing of rays. The recursive character of this method
makes the super-sampling concentrate on those parts of the pixel that are more
likely to need super-sampling."
According to this, the first pixel traced takes 4 times as long (the 4 corners
need to be evaluated). Those of the first line and column take twice as long
(two corners have already been evaluated and saved), but the rest only take the
same amount of time as non-antialiased if the differences are under the treshold
value (3 of the corners comes from the previous line and the preceding pixel of
the current line).
WARNING: The consumption of alcohol may make you think you are whispering when
you are not.
Date: 28 May 2008 07:26:27
Message: <483d4163@news.povray.org>
>> that time.
> to do exactly that.
 From the docs:  "Samples that are common among adjacent pixels and
sub-pixels are stored and reused to avoid re-tracing of rays."
John
