POV-Ray : Newsgroups : povray.general : string problem Server Time
18 Mar 2026 19:52:23 EDT (-0400)
  string problem (Message 1 to 8 of 8)
Subject: string problem
Date: 1 Mar 2008 12:33:05
Message: <47c99351$1@news.povray.org>
I am trying to load a long sequence of TGA files into this image map:
image_map { tga concat("D:\\sketches\\follow", str(clock*600,-4,0), ".tga")
in the folder Sketches folder on my D drive there are 1800 files starting
with
follow0000.tga
to
follow1800.tga
Can someone see a problem with the string here? I want to read in only the
first 600 while the clock moves from 0.1 to 1.
The whole code segment is:
#local D=
  pigment{
".tga")   //group.tga is excellent   1352
  map_type 2 interpolate 2 once } translate <0, 0,0> scale 1 + clock*2 }
and I am getting a Parse Error that says: Cannot open TGA image.
thanks much for any help.
d
dhm### [at] comcastnet
http://www.dennismiller.neu.edu
Subject: Re: string problem
Date: 1 Mar 2008 12:40:06
Message: <47c994f6@news.povray.org>
> with
> follow0000.tga
> to
> follow1800.tga
This won't solve the problem, but will help you find out why it's not
working:
#declare ImageName = concat("D:\\sketches\\follow", str(clock*600,-4,0),
".tga");
#debug concat("Attempting to load ", ImageName, "\n")
image_map {
    tga ImageName
Date: 1 Mar 2008 12:44:58
Message: <47c9961a@news.povray.org>
> with
> follow0000.tga
> to
> follow1800.tga
> #local D=
>   pigment{
> d
I haven't checked it, but if you send your "concat" statement to #debug,
you can verify whether you're actually getting the correct string.
However, since you're only wanting integers, I'd suggest using
"frame_number" rather than "clock."  (Just the first thing that occurs
to me; hope this helps.)
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 1 Mar 2008 12:46:22
Message: <47c9966e@news.povray.org>
>> ".tga")
>> starting with
>> follow0000.tga
>> to
>> follow1800.tga
>> the first 600 while the clock moves from 0.1 to 1.
> working:
> ".tga");
> image_map {
>    tga ImageName
Ah, great minds work alike, I see!  ;)
--Sherry Shaw
Date: 1 Mar 2008 12:53:47
Message: <47c9982b$1@news.povray.org>
I thought it was "fools seldom differ"? :)
Date: 1 Mar 2008 13:01:17
Message: <47c999ed@news.povray.org>
--Sherry Shaw
Date: 1 Mar 2008 14:26:19
Message: <47c9addb$1@news.povray.org>
Dennis Miller nous apporta ses lumieres en ce 2008/03/01 12:33:
> with
> follow0000.tga
> to
> follow1800.tga
> #local D=
>   pigment{
> d
I'd use frame_number instead of clock like this:
  image_map { tga concat("D:\\sketches\\follow",str(frame_number,-4,0),".tga")
Do you have read permission for that folder? If you don't have read permission,
you can't access the files if the I/O restrictions are active.
You may need to add a line like this to the "pvengine.ini" file from the \ini
folder:
in the section [Permitted Input Paths]
3=D:\sketches
The number is to follow the last number in that section.
I drive way too fast to worry about cholesterol.
Date: 1 Mar 2008 19:34:03
Message: <47c9f5fb$1@news.povray.org>
"Dennis Miller" <dhm### [at] comcastnet> wrote in message
news:47c99351$1@news.povray.org...
> ".tga")
You didn't say what version or platform you are using there so this could be
unrelated.
Giving it a try here POV for Windows 3.6.1c crashed, no error message. I
have the current 3.7 beta "installed", not simply added to the 3.6 bin
folder. I can run this (similar script) from the 3.7 beta, no errors. Using
Vista here.
It has been a very long time since I did any animations using version 3.6 so
I couldn't say if anything has changed.
I was just wondering about your 0.1 to 1 clock if you want the first half of
images from 1800 total. Start image number would then be 60 not 0.
/*bob hughes*/
