POV-Ray : Newsgroups : povray.general : Coordinates baking in pov Server Time
31 Jul 2024 02:24:05 EDT (-0400)
  Coordinates baking in pov (Message 1 to 5 of 5)
Subject: Coordinates baking in pov
Date: 18 Feb 2008 08:35:01
Message: <web.47b9887c93fc6a8bf8a489ba0@news.povray.org>
Hi people, I have the problem, that I need to have the position and orientation
of an object in povray. But all objects are translated couple of times by using
several values! By using macros like this:
#macro rotation(ctr)
degrees(rot(ctr).y),
degrees(rot(ctr).z),
-degrees(rot(ctr).x)>
#macro position(ctr)
(<-pos(ctr).y,-pos(ctr).z,pos(ctr).x>)
#macro fluking(ctr)
(<degrees(flk(ctr).u),flk(ctr).v>)
rot(bla),pos and flk are splines, defined by thousands of entry's!
I need to write a file, with contains the absolute position and rotation of
these objects.
Any ideas?
Subject: Re: Coordinates baking in pov
Date: 18 Feb 2008 08:44:50
Message: <47b98bd2@news.povray.org>
> these objects.
  Define a vector (let's call it L for short) which contains the location
of the unmodified object, and another (O) which contains its orientation.
  Each time you translate the object, add the translation vector to L.
Each time you rotate the object, apply the same rotation to both L and O
using vrotate(). Each time you scale the object, multiply L with the
scaling factor (even if it's uneven scaling using a vector as factor).
Date: 18 Feb 2008 09:10:01
Message: <web.47b990ec6961e077f8a489ba0@news.povray.org>
> > these objects.
A question to vrotate:
When I'm rotate an object, I have to do this in a right order:
 rotate <rrx,0,0>/power
 rotate <0,0,rrz>/power
 rotate <0,rry,0>/power
This is absolute necessary!
Just by adding the values would give me the wrong result. vrotate gives the
right result?
-holger-
Date: 18 Feb 2008 09:37:23
Message: <47b99823$1@news.povray.org>
> right result?
Do three vrotate calls.
#declare A = vrotate(A, x*rrx/power);
#declare A = vrotate(A, z*rrz/power);
#declare A = vrotate(A, y*rry/power);
In fact, you could do this too:
#declare A = vrotate(A, <rrx, 0, rrz>/power);
#declare A = vrotate(A, < 0, rry, 0 >/power);
Date: 18 Feb 2008 09:55:01
Message: <web.47b99b646961e077f8a489ba0@news.povray.org>
Thanx people! This will help :)
-holger-
