POV-Ray : Newsgroups : povray.general : Strange rendering of small blobs Server Time
23 Dec 2025 01:03:42 EST (-0500)
  Strange rendering of small blobs (Message 1 to 6 of 6)
Subject: Strange rendering of small blobs
Date: 30 Jan 2008 05:18:54
Message: <47a04f0e$1@news.povray.org>
Here is a quite simple code:
#include "glass.inc"
#declare un=1/446;
          location <0, 0, -5*un>
          look_at  <0, 0, 0>
          angle 30
light_source { < 1*un,3*un,-4*un>, color White }
light_source { < 1*un,1*un,-4*un>, color White }
blob {
     threshold .5
     sphere {<0,0,0>,1*un,1}
     texture { pigment { color Green  } }
     sturm on
sphere {<0,0,0>,.1*un texture { pigment { color Red  } } }
A trivial blob enclose a red sphere that shouldn't be visible.
A variable, "un" modify the scale of the whole scene, so that any
reasonable value of un should return the same output.
For value of un>1/445 that seems to be the case.
For lower values, 1/446 and lower, the blob start rendering a bit odd,
and in fact we start to see the red sphere. Before un=1/1000 the blob is
completely gone, leaving just the red sphere.
1/1000 makes floating values around 10^-3 for the different objects that
should be very reasonable for any scene computation accuracy. So why
does my blob disappear?
Thanks for any help,
	Yannick
PS: I came on this while working on some spaceship rendering where large
different scales are at work. I defined:
   #declare km=   1;
   #declare  m=  km/1000;
   #declare cm=   m/100;
   #declare mm=   m/1000;
   #declare um=   mm/1000;
On a single scene, it may likely range from a slightly sub-millimeter
scale (details of everyday objects) to some hundreds of millions of km
(planets in solar system), that is around 10^-7 to 10^9 in povray units.
I'm afraid that it wont work for the larger scales, and so that I'll
have to cheat somehow (rescaling planets and putting them closer,
maybe). But I wasn't expecting problems around 10-3.
Subject: Re: Strange rendering of small blobs
Date: 30 Jan 2008 05:56:20
Message: <47a057d4@news.povray.org>
Blobs are known for rendering inaccuracies and these types of things are
to be expected.
Date: 30 Jan 2008 07:25:31
Message: <47a06cbb$1@news.povray.org>
> to be expected.
Thanks for your answer.
More generally, where can I found information about the working scale
range of scenes in povray?
Thanks.
	Yannick
Date: 30 Jan 2008 10:15:50
Message: <47a094a6$1@news.povray.org>
You can't mix km with mm in a single scene, at least not without
modifying POV-Ray to use arbitrary-precision floating-point numbers
(probably quite a rewrite, and would really slow things down).
Date: 30 Jan 2008 15:06:39
Message: <47a0d8cf$1@news.povray.org>
Thanks for this info. You mean that a scale range from 1 to 10^6 is too
much? Seems pretty narrow to me. I'll see!
Thanks,
	Yannick
Date: 30 Jan 2008 15:19:05
Message: <47a0dbb9$1@news.povray.org>
In many internal calculations of POV-Ray, numbers will get *squared*.
That's reason why there are inaccuracies even with ranges that don't
seem so high.
