POV-Ray : Newsgroups : povray.general : Photon Map: Created at Lower Res than Scene? Server Time
12 Apr 2026 07:22:50 EDT (-0400)
  Photon Map: Created at Lower Res than Scene? (Message 1 to 10 of 54)
Subject: Photon Map: Created at Lower Res than Scene?
Date: 26 Jan 2008 19:10:37
Message: <479bcbfd@news.povray.org>
Hi.
I have a scene, which already takes around 6 days to create the photon map
for, if it is done in the same resolution like the remaining scene.
I would like to know, if it is possible to use a lower resolution (let's
say: 400x300) for the photon map (with the "save_file" option enabled), and
then to stop and continue the scene in a high resolution (now with the
"load_file" option enabled).
Sven
Subject: Re: Photon Map: Created at Lower Res than Scene?
Date: 26 Jan 2008 19:41:16
Message: <479bd32c@news.povray.org>
It's possible. The photon map is independent from the image resolution.
Which also means that calculating the photon map when rendering at
400x300 will take exactly the same time as any other higher resolution.
Date: 26 Jan 2008 20:32:32
Message: <479bdf30$1@news.povray.org>
Sven Littkowski wrote:
> Hi.
Sure, I do it myself.  However, since the photon map is independent from
the scene resolution, you can set the image size absurdly low (like +w1
+h1) and still get a full-quality photon map.
...Ben Chambers
www.pacificwebguy.com
Date: 26 Jan 2008 23:52:51
Message: <479c0e23@news.povray.org>
Hi Ben,
but even so, based on what I heard already, meanwhile, the photon map would
still take 6 days, right?
Sven
"Chambers" <ben### [at] pacificwebguycom> schrieb im Newsbeitrag
news:479bdf30$1@news.povray.org...
>> Hi.
>> map for, if it is done in the same resolution like the remaining scene.
>> and then to stop and continue the scene in a high resolution (now with
>> the "load_file" option enabled).
> ...Ben Chambers
Date: 27 Jan 2008 02:24:36
Message: <479c31b4$1@news.povray.org>
try using image_width to choose the photon count/spacing
Sven Littkowski napsal(a):
> Hi Ben,
> Sven
>>> Hi.
>> ...Ben Chambers
Date: 27 Jan 2008 10:57:37
Message: <479ca9f1$1@news.povray.org>
Hmm... THAT sounds interesting and promising, Jan. I looked into the POV
help file, and see the keywords "image_width" and "image_height". And also
some examples, how to use them. I really think, this could shorten the
calculation time, if I can find out, how to use them properly in connection
with my photon map creation.
Jan, can you give me some more advice in this? If you like, I could post the
scene file to you. Please let me know. Thanks,
Sven
"Jan Dvorak" <jan### [at] centrumcz> schrieb im Newsbeitrag
news:479c31b4$1@news.povray.org...
>> Hi Ben,
>> would still take 6 days, right?
>> Sven
>>>> Hi.
>>>> (let's say: 400x300) for the photon map (with the "save_file" option
>>>> enabled), and then to stop and continue the scene in a high resolution
>>>> (now with the "load_file" option enabled).
>>> ...Ben Chambers
Date: 27 Jan 2008 17:02:39
Message: <479cff7f@news.povray.org>
You might decide to shoot image_width*image_height*some_constant
photons. Some_constant==1 might work well but feel free to increase for
high quality or decrease for faster render. Use the count keyword and
watch POV-ray do its best.
> Sven
>>> Hi Ben,
>>> Sven
>>>>> Hi.
>>>> ...Ben Chambers
Date: 27 Jan 2008 18:15:49
Message: <479d10a5$1@news.povray.org>
Shooting the image with those keywords... Hmm, do you mean that I need to
put these two keywords inside the camera directive? To be honest, due the
lack of experience and knowledge with these two keywords, i would just like
to ask you to give an example where and how to use these two keywords in a
scene. I think, that should help me.
Thanks, Jan.
Sven
news:479cff7f@news.povray.org...
> You might decide to shoot image_width*image_height*some_constant photons.
> Some_constant==1 might work well but feel free to increase for high
> quality or decrease for faster render. Use the count keyword and watch
>> also some examples, how to use them. I really think, this could shorten
>> the calculation time, if I can find out, how to use them properly in
>> connection with my photon map creation.
>> the scene file to you. Please let me know. Thanks,
>> Sven
>>>> Hi Ben,
>>>> Sven
>>>>>> Hi.
>>>>>> photon map for, if it is done in the same resolution like the
>>>>>> remaining scene.
>>>>>> resolution (now with the "load_file" option enabled).
>>>>> from the scene resolution, you can set the image size absurdly low
>>>>> (like +w1 +h1) and still get a full-quality photon map.
>>>>> ...Ben Chambers
Date: 27 Jan 2008 21:38:17
Message: <479d4019@news.povray.org>
global_settings{
   photons{
     count image_width*image_height
untested
> Thanks, Jan.
> Sven
>>> Sven
>>>>> Hi Ben,
>>>>> Sven
>>>>>>> Hi.
>>>>>>> remaining scene.
>>>>>> ...Ben Chambers
Date: 27 Jan 2008 21:50:18
Message: <479d42ea$1@news.povray.org>
[Posting to newsgroup since other people may be interested]
Now that you sent me the files... The scene is quite slow to render
(55pps) even without radiosity or photons. I tried with photons, and
there were very long periods where the "photons shot" counter didn't
change, which could mean POV-Ray is shooting lots of photons but
"missing the object".
What I'm suspecting is that POV-Ray is creating sub-optimal bounding
boxes. I see a lot of difference objects on your scene. POV-Ray
sometimes does a bad job bounding difference/intersection CSG.
I'm now rendering a 160x120 image to see the raytrace statistics at the
end, and see if there were a lot of misses or not. Stay tuned...
