POV-Ray : Newsgroups : povray.general : Projecting a photograph on to a 3D model Server Time
18 Feb 2025 17:57:21 EST (-0500)
  Projecting a photograph on to a 3D model (Message 1 to 9 of 9)
Subject: Projecting a photograph on to a 3D model
Date: 5 Dec 2007 14:20:30
Message: <4756f9fe@news.povray.org>
I have a photograph of a city taken from a plane showing the sides of
buildings. I'd like to project the photo on to my 3D model of the city.
Can POVRAY do this?
Thanks,
Mark
Subject: Re: Projecting a photograph on to a 3D model
Date: 5 Dec 2007 14:34:35
Message: <4756fd4b$1@news.povray.org>
Mark Karaska escribió:
> Hi,
> Can POVRAY do this?
Any object can have an image_map. It's a bit tricky to get a different
image on each side of a box{}, I'm sure somebody else could help you
more on how to do that.
If you want to really "project" an image into a complex object (think on
how a real projector would work on a non-planar surface), try Rune's
illusion.inc.
http://runevision.com/show.asp?id=96
Date: 5 Dec 2007 16:55:01
Message: <web.47571dd1a7accdbbc150d4c10@news.povray.org>
"Mark Karaska" <mka### [at] mitreorg> wrote:
> Hi,
> Can POVRAY do this?
> Thanks,
> Mark
Yes, but it can be tricky.
1) You need the proportions of the building sizes of the model to match fairly
close to the actual buildings.  Even so, you can expect some pixel 'leak'
around hard edges of the model as the image map is just a bunch of square
pixels with a finite resolution, shouldn't be too much of a concern though.
2) You need to get the orientation of the image_map correct.
3) This one's a bit tougher maybe.  A standard image map is projected parallel,
all the pixels run continuously straight, however, the image will have been
taken from a camera, so will not have a parallel projection.  The larger the
viewing angle of the camera, the more distorted this can be.  If it's a fairly
tight angle (i.e. was taken with a zoom lens), then the differences may be
unnoticeable.  However if it is a larger angle projection, you may need to look
at distorting the image map.  The best way for this may be to turn it into a
function and apply it with spherical warping.  For example, lets assume your
image is square, and was taken with a 60deg field of view.  A full spherical
map will cover 360deg across and 180deg up/down, so you need to you need to
scale your image to suit this.  Spherical image map is 1unit x 1unit, your
image should be scaled so it is 60/360 units by 60/180 units in the center of
the 1x1 square to be mapped.  Then you need to get the spherical centre placed
properly (i.e, where the camera was in relation to the real buildings) and
oriented properly.
Hope this makes sense somewhat.
-tgq
Date: 5 Dec 2007 21:04:46
Message: <475758be@news.povray.org>
In general, no, there are issues involving perspective,
image location, and differences in apparent size versus actual size.
But you can perspective correct portions of an image and then use
those to map things like building faces, individually. It's just a lot of
work.
NASA uses some software that correlates depth info from stereographic
photos, and location info, and forms a mosaic 3D model for it's mars
rovers, but it's buggy and very clunky.
Date: 6 Dec 2007 06:08:58
Message: <4757d84a$1@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> wrote in message
news:475758be@news.povray.org...
> work.
Hi Mark,
There is a simple (albeit very crude) way to correct the proportions of the
image. You can set up a 'projector' using a light source and a filtered
image. As Trevor mentioned, you'd need the 3D model to fairly accurately
represent the building shapes and you'll probably still get leaching around
the edges, so I'm not claiming that this will be anywhere near perfect (just
fairly quick to do).
Blocks representing the buildings should be white.
A single light source should be located roughly where your camera was
relative to the city and the image should be placed a little way in front of
it, oriented so that it's perpendicular to the line between the light and
the centre of the image. Use 'filter all 1' to get the light to project the
image. The building surfaces visible in the image will be illuminated with
the appropriate image, surfaces hidden from your camera will remain white.
If you have more than one image you can have more than one projector, so, if
your plane flew around the city and you got 4 photos, you might get a fairly
complete coverage, although it may take a bit of fiddling around to align
them correctly.
Here's a very simple example that projects an image onto a box and a
cylinder.
camera {location <-0.74, 0.65, -3> look_at 0}
box {0,1 pigment {rgb 1}}
cylinder {0,y,0.4 pigment {rgb 1} translate -x}
light_source {<0,0,-400> color rgb 1}
plane {z,-300
    image_map {jpeg "Your_Image.jpg"
      filter all 1 once}
    translate <-0.5,-0.5,0>
Hope this helps,
Chris B.
Date: 6 Dec 2007 13:47:27
Message: <475843bf$1@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4757d84a$1@news.povray.org...
> plane {z,-300
>  pigment {
>      filter all 1 once}
AFAIK 'filter all' will only work with indexed images.
However, there's no need for such hacks, it's perfectly possible to
'perspective-transform' the image_map with functions.  As Nicolas Alvarez
mentioned, Rune's illusion.inc can be used for just that.
cu!
Date: 6 Dec 2007 15:20:27
Message: <4758598b$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote in message
news:475843bf$1@news.povray.org...
>> plane {z,-300
>>  pigment {
>>      filter all 1 once}
Hi Zeger,
In fact "filter all" works with the jpeg as posted. 'filter' followed by a
number seems to demand an indexed image.
Agreed that it's possible. I never said it wasn't possible to do it the
other ways, but it does get round a number of problems that you would run
into doing it other ways (unless Rune has foreseen them all - which he may
have done. He's a clever guy :-)), like getting your head round what sort of
projection you'd need for each building in the model and working out how to
suppress the backside of an image applied to an object.
Whichever way one approaches the problem the results would be pretty
imperfect because there are likely to be surfaces that were hidden from the
original view point of the camera and that therefore don't show up on the
original photo, so I figured it was worth suggesting an extremely low effort
alternative that may just happen to fit Mark's needs.
Chris B.
Date: 6 Dec 2007 15:27:00
Message: <47585b14$1@news.povray.org>
news:4758598b$1@news.povray.org...
> Hi Zeger,
really? wow, I wish I knew that sooner, would've saved me a lot of averaged
pigment_map's :p
thanks!
cu!
Date: 7 Dec 2007 16:05:00
Message: <web.4759b452a7accdbb78dcad930@news.povray.org>
> illusion.inc.
Thanks for this link; I hadn't yet seen these .inc files of Rune's.  Lots of
useful stuff there.
Ken W.
