POV-Ray : Newsgroups : povray.general : Sphere with longitudes and latitudes? Server Time
18 Mar 2026 23:20:55 EDT (-0400)
  Sphere with longitudes and latitudes? (Message 1 to 10 of 28)
Subject: Sphere with longitudes and latitudes?
Date: 11 Nov 2007 13:37:31
Message: <47374beb$1@news.povray.org>
I'd like to create a sphere with lines for longitudes and latitudes,
which basically is just a white sphere with thin black lines on horizon
and parallel to the horizon, and lines from north to south.
How would I do this?
I tried to apply a texture with a color map onto the surface of the
sphere, but the gradient is just a linear vector of x,y,z and not
a term (e.g. the angle phi cannot be used).
Another approach would be to mix the sphere with very flat and black
cylinders which are just a little big bigger than the sphere, but then
the sphere is not perfect anymore.
How could I get a sphere with those lines?
regards
Hadmut
Subject: Re: Sphere with longitudes and latitudes?
Date: 11 Nov 2007 14:29:15
Message: <4737580b$1@news.povray.org>
Hadmut Danisch napsal(a):
> Hi,
> regards
> Hadmut
use UV_mapping or warp{spherical}. Both map the <0,0>,<1,1> square onto
the sphere. They do the same in the sphere case.
For the grid, you may use the quilted pattern.
Date: 11 Nov 2007 14:41:06
Message: <oS4JbDAqp1NHFw72@econym.demon.co.uk>
Wasn't it Hadmut Danisch who wrote:
>Hi,
One way to do it is with layered textures.
sphere {0,1
 texture{
  pigment {gradient y
    colour_map{[0 rgb 1][0.1 rgb 0]}
    scale 0.15
  pigment {radial frequency 30
    colour_map{[0 rgb 1][0.1 rgbt <0,0,0,1>]}
The bottom layer is a gradient pigment with a small scale.
The upper layer is a radial pigment with a high frequency which is
mostly transparent so you can see the underlying gradient texture.
Mike Williams
Gentleman of Leisure
Date: 11 Nov 2007 14:52:43
Message: <vSDIrFAGv1NHFw6x@econym.demon.co.uk>
>Hi,
Another way to do it is to use the phi function "f_ph()". That makes the
lines more even. You could also use the theta function "f_th()" for the
lines of longitude, but there'd be no difference from using the radial
pattern.
#include "functions.inc"
sphere {0,1
 texture{
  pigment {function {f_ph(x,y,z)*6}
    colour_map{[0.1 rgb 1][0.1 rgb 0]}
    scale 0.15
    colour_map{[0.1 rgb 1][0.1 rgbt <0,0,0,1>]}
Mike Williams
Date: 11 Nov 2007 15:20:14
Message: <473763fe@news.povray.org>
"Hadmut Danisch" <had### [at] danischde> wrote in message
news:47374beb$1@news.povray.org...
> Hi,
> regards
> Hadmut
Hi Hadmut,
There's one on http://lib.povray.org/searchcollection/index.php if you
search for 'GridLines'. The lines are green, and the background is
transparent, but you can readily change that.
It uses rotated copies of the gradient pattern to give a constant line
thickness.
Chris B
Date: 11 Nov 2007 16:23:54
Message: <473772ea@news.povray.org>
> pattern.
> sphere {0,1
>  texture{
>     scale 0.15
>  texture {
These are exactly the two hints I was looking for.
Thanks, also to the others.
regards
Hadmut
Date: 11 Nov 2007 16:40:26
Message: <473776ca@news.povray.org>
>  texture {
Just a little detail problem:
while this does what I am looking for in principle, there's one
problem: The line is not of constant width. The closer it gets to the
poles, the smaller it gets, like a slice of cake. Becomes highly visible
when the frequence gets lower, e.g. frequency 4
regards
Hadmut
Date: 11 Nov 2007 16:55:30
Message: <47377a52$1@news.povray.org>
>>  texture {
> regards
> Hadmut
in that case you need to invent a pigment to account for this. It might
not be that simple.
Date: 11 Nov 2007 17:03:57
Message: <47377c4d@news.povray.org>
> Hi,
> regards
> Hadmut
Why not build your lines with some tori and make an object_pattern with
them?
You could keep constant width lines that way.
Marc
Date: 11 Nov 2007 17:09:00
Message: <47377d7c@news.povray.org>
news:473776ca@news.povray.org...
>>  texture {
> regards
> Hadmut
That's the problem that the one on
http://lib.povray.org/searchcollection/index.php is designed to avoid
(search for 'GridLines').
Chris B.
