POV-Ray : Newsgroups : povray.general : Questions about radiosity Server Time
20 Nov 2025 23:41:38 EST (-0500)
  Questions about radiosity (Message 1 to 5 of 5)
Subject: Questions about radiosity
Date: 31 Aug 2007 12:49:39
Message: <46d846a3@news.povray.org>
I am finishing a set of scenes that make intensive use of radiosity as the
light comes from outside of the space that I am designing. To allow more
light to enter through the windows, I am applying radiosity in 2 steps:
1. Render without windows storing the radiosity info (save_file)
2. Render with windows and reading the radiosity info from the file
(load_file).
I have some doubts about how storing radiosity info works. I would
appreciate some lighting (in my mind):
1. What radiosity parameters have influence on the info that is stored in
the file (all of them?)
2. What radiosity parameters have influence on the image if I am using
load_file?
3. Does the info in the file overwrite the radiosity parameters in the SDL
code?
4. Can I make the first step at a lower size than the second step?
5. Does it matter where I put the parameters load_file and save_file in the
code (after the actual radiosity parameters, after them, ...?
6. If I get some artifacts in the first step, may I remove them in the
second one?
Thanks for your help,
Zoly
Subject: Re: Questions about radiosity
Date: 31 Aug 2007 15:44:57
Message: <46d86fb9@news.povray.org>
Zoly nous apporta ses lumieres en ce 2007/08/31 12:49:
> Hi,
Windows without the "glass" pane.
> (load_file).
All of them.
> load_file?
Any can have an effect, when there is a need to gather some extra samples.
> code?
NO.
Absolutely. You can also remove any AA.
load_file
save_file
or
load_file
save_file
If you save_file before load_file, you may reload the data you just saved.
> second one?
The second step will gather additional samples if needed. They may, or not,
remove or reduce those artefacts.
Use high quality parameters in the first pass, and more relaxed ones on the
second pass.
In the first pass, remove any flat transparent, colorless, objects. Reflective
objects should have the texture replaced by a plain white one IF they are far
from bright surfaces: high ambient ones.
Keep shaped with ior or colored transparent objects as they actively change the
radiosity samples. Also, keep non-flat reflective
> Zoly
If you also use photons, you must keep any object that is a target for the photons.
You know you've been raytracing too long when you have ever brought your
computer to its knees by mistakenly launching 64 simultaneous frames to be
traced, while trying to maximizing the benefits of parallelizing them.
Carsten Whimster
Date: 31 Aug 2007 16:06:03
Message: <46d874ab@news.povray.org>
Thank you for tips.
One clarification: may I remove AA from the first step as it will not affect
the values stored in the radiosity file?
I also just realized with more tests that if I use the same radiosity
parameters at both steps, the second one runs much faster. If I change
'count', 'error_bound', 'recursion_limit' even to more relaxed values, it
takes more than double of the time to render.
Rgds,
Zoly
"Alain" <ele### [at] netscapenet> wrote in message
news:46d86fb9@news.povray.org...
>> Hi,
>> the light comes from outside of the space that I am designing. To allow
>> more light to enter through the windows, I am applying radiosity in 2
>> steps:
>> (load_file).
> All of them.
>> load_file?
>> SDL code?
> NO.
>> the code (after the actual radiosity parameters, after them, ...?
> load_file
> save_file
> or
> load_file
> save_file
>> second one?
> not, remove or reduce those artefacts.
> the second pass.
> Reflective objects should have the texture replaced by a plain white one
> IF they are far from bright surfaces: high ambient ones.
> change the radiosity samples. Also, keep non-flat reflective
>> Zoly
> photons.
> Alain
> Carsten Whimster
Date: 1 Sep 2007 04:58:13
Message: <46d929a5$1@news.povray.org>
  Of course! ...and don't forget to do the same with focal blur and area lights!
   Yes, that's my observation also... I suppose it's because if the params
are the same, it just has to load the rad data file (provided you have
always_sample off).
Jaime
Date: 1 Sep 2007 08:51:24
Message: <46d9604c@news.povray.org>
Zoly nous apporta ses lumieres en ce 2007/08/31 16:05:
> Thank you for tips.
AA and focal blur can be removed as they don't affect the radiosity data.
area_light can also be replaced by normal lights, even if they alter radiosity
samples from the penumbrae regions.
> Rgds,
> Zoly
If you change the settings, exept for pretrace_start/pretrace_end and
always_sample off, you force new sampling with the new parameters. Those samples
will be added to the loaded ones.
>>> Hi,
>>> steps:
>>> (load_file).
>> All of them.
>>> load_file?
>>> SDL code?
>> NO.
>> load_file
>> save_file
>> or
>> load_file
>> save_file
>>> second one?
>> the second pass.
>>> Zoly
>> photons.
>> Alain
>> Carsten Whimster
WARNING: The consumption of alcohol may make you think you can logically
converse with members of the opposite sex without spitting.
