POV-Ray : Newsgroups : povray.general : Problem with normals and stretched uv maps Server Time
12 Apr 2026 13:27:06 EDT (-0400)
  Problem with normals and stretched uv maps (Message 1 to 2 of 2)
Subject: Problem with normals and stretched uv maps
Date: 28 Jul 2007 07:26:06
Message: <46ab27ce@news.povray.org>
I have discovered a problem that occurs when using normals in combination
with UV maps.
The problem arises when a UV map covering the area of <0,0> to <1,1> must
cover a surface which is longer in one direction than in the other. To
counter the stretched UV map, the texture can be scaled to stretch inversely
with this. However, this counter-scaling is all that POV-Ray sees. It
doesn't see that the UV map was stretched in the first place. As a result,
the normals are calculated in a way that doesn't make sense - they have far
more depth in one direction than in the other, because POV-Ray *thinks* that
the normal has been squished together in one direction, which isn't however
the case on the actual surface.
The minimal scene below clearly demonstrates the problem. (See image in
povray.binaries.images) Any ideas for workarounds? I need it for a scene I'm
working on...
camera {location -3*z}
light_source {<-1,2,-2>*100 color 1}
#default {pigment {rgb 1}}
background {rgb 0.3}
#declare Normal = normal {
   leopard 4 scale 0.05
mesh {
   triangle {0,   x, y uv_vectors 0,   u, v}
   triangle {x+y, x, y uv_vectors u+v, u, v}
   uv_mapping normal {Normal}
mesh {
   triangle {0,     5*x, y uv_vectors 0,   u, v}
   triangle {5*x+y, 5*x, y uv_vectors u+v, u, v}
   uv_mapping normal {Normal scale <1/5,1,1>}
   translate -1.1*y
mesh {
   triangle {0,     x, 5*y uv_vectors 0,   u, v}
   triangle {x+5*y, x, 5*y uv_vectors u+v, u, v}
   uv_mapping normal {Normal scale <1,1/5,1>}
   translate -1.1*x
Rune
http://runevision.com
Subject: Re: Problem with normals and stretched uv maps
Date: 28 Jul 2007 07:45:14
Message: <46ab2c4a@news.povray.org>
Some additional notes:
The counter-stretching is not the source of the problem. While it is used
here to make the problem more obvious, the normals will be evaluated
incorrectly when a UV map is stretched, no matter how the normal is scaled.
I would say that the problem manifests itself in almost all uses of UV maps
with normals. At least on curved surfaces, mapping a planar texture onto it
will *always* result in some amount of stretching.
I don't know if the behavior is a bug or a limitation. In any case, as long
as it is there, artists should be very cautious about using normals in
combination with UV mapping.
Rune
