POV-Ray : Newsgroups : povray.general : Extruding a function... Server Time
12 Apr 2026 15:06:54 EDT (-0400)
  Extruding a function... (Message 1 to 6 of 6)
Subject: Extruding a function...
Date: 19 Jun 2007 06:57:02
Message: <4677b67e@news.povray.org>
I believe this is possible to do with isosurfaces - I'm just not very good
at them :s
I need something like a sine wave extruded in the +z direction
If I have:
f(x) = sin(2*pi*x)
how do I get that into something like corrugated roof? I've read the
excellent tutorial on isosurfaces <http://www.econym.demon.co.uk/isotut/>
and can copy/paste as well as the next man but  am obviously missing
something as I don't seem to be able to do what I need
As always, any input is greatly appreciated!
Subject: Re: Extruding a function...
Date: 19 Jun 2007 10:23:49
Message: <4677e6f5$1@news.povray.org>
Simon wrote:
> If I have:
> f(x) = sin(2*pi*x)
Simon,
The cross section of a corrugated roof will be 2D, so you will need data
for at least two axes when making your roof. Here is an example:
function{
  y               // Makes a y-facing surface.
  +cos(2*pi*x)/4  // Distorts surface by adding one x-oriented wave
                  // per unit, scaled by 0.25.
~Sam
Date: 19 Jun 2007 11:40:58
Message: <4677f90a$1@news.povray.org>
Thanks very much for that :) That actually makes sense :)
I'd gone off on a tangent and actually came up witha  macro to make a mesh
froma  given function - I'll compare the 2 to match parse times/render
times. Also, I expect the isosurface will have a higher quality...
Again, thank you!
~S
"Samuel Benge" <stb### [at] THIShotmailcom> wrote in message
news:4677e60d$1@news.povray.org...
> Simon wrote:
>> If I have:
>> f(x) = sin(2*pi*x)
> Simon,
> function{
>  y  // makes a y-facing surface
>  +cos(x*pi*2)/4  // distorts surface by adding one x-oriented wave
> // per unit, scaled by 0.125
> ~Sam
Date: 19 Jun 2007 16:14:13
Message: <VbjWpBAGU8dGFwIM@econym.demon.co.uk>
>at them :s
>If I have:
>f(x) = sin(2*pi*x)
Mathematically, what you want to plot is y=f(x)
I.e     y = sin(2*pi*x)
But isosurfaces evaluate expressions of the format
        <function> = <threshold>
where threshold is a constant, so we rewrite the expression as
        y - sin(2*pi*x) = 0
isosurface {
  function { y - sin(2*pi*x) }
        max_gradient 4
        contained_by{sphere{0,5}}
        pigment {rgb 1}
We dont need to bother saying "threshold 0" because that's the default.
Mike Williams
Gentleman of Leisure
Date: 19 Jun 2007 16:39:32
Message: <46783f04$1@news.povray.org>
That is very clear! Thanks Mike - If you don't mind some further
questions...
Say we wanted to do something like an infinitely long crinkle-cut chip
(excuse the awful description)
Dealing with 1 dimension at a time...
y<1+sin(x*2*pi)
y>-1+sin(x*2*pi + pi/2)
how can I combine the 2? - to be more precise, how do I define the "solid"
bit as the area between the two?
If you'd rather point me at a tutorial and leave me to it, I understand but
if you're willing to walk me through this, I'd greatly appreciate it
Thanks in advance!
NB I've used the sine wave isosurface for the curtains in an animation I'm
posting in p.b-a if you're interested.
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:Vbj### [at] econymdemoncouk...
>>at them :s
>>If I have:
>>f(x) = sin(2*pi*x)
> I.e     y = sin(2*pi*x)
>        y - sin(2*pi*x) = 0
> isosurface {
>        max_gradient 4
>        pigment {rgb 1}
> Mike Williams
Date: 19 Jun 2007 23:01:50
Message: <e+dEACAzfJeGFwiV@econym.demon.co.uk>
>questions...
>y<1+sin(x*2*pi)
>Thanks in advance!
You can use this trick to do two dimensions at once
http://www.econym.demon.co.uk/isotut/substitute.htm#thick
Like this:
     function { abs(sin(2*pi*x)-y)-0.25 }
To do four directions, you can use max() to perform the intersection of
the simpler functions.
#declare  F = function(x,y) {0.1*sin(2*pi*x)+y}
isosurface {
  function { max( F(x,y-1), F(x-0.5,-y-1), F(x,z-1), F(x-0.5,-z-1)) }
        max_gradient 1.2
        contained_by{box{<-5,-2,-2><5,2,2>}}
        pigment {rgb <0.9,0.8,0.7>}
Mike Williams
