![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Two separate feature requests:
1) Support SVG as an import file format.
2) Copy SVG's text formatting capabilities, namely text centering and
aligning text to paths.
SVG is a standard image format and, since it is a vector format, shares many
similarities with POV-Ray. I would like to see POV-Ray adapt some of the
format's capabilities, as well as support the format via import.
-Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
First time I've heard of it :0
But I don't use vector formats much. :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Two feature requests related to SVG
Date: 15 Jun 2007 00:43:42
Message: <467218fe@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> -Mike
If this were implemented, it would be nice if the user were able to call
on individual layers of the image.
SVG is an open-source format, isn't it? Being so, it would make a nice
addition to POV if it could be implemented without bloating the program.
~Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What exactly would povray do with the SVG?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, it'd certainly be nice to be able to use SVGs as image_maps - no
interpolation required! I know you can almost do this already with object
patterns but it's a bit fiddly. Would it also cut down on memory usage if
you had many simple image_maps?
Lathe and prism splines can already be exported to POV by Inkscape but I
guess it would be slightly easier if the SVG file could be read directly...
Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How would you determine that a given point is, for example, on a
polyline or inside a polygon?
The thing with vector graphics is that they are easy to draw as a whole:
Just draw a line for each line in the input, fill polygons for filled
polygons, and so on. However, if you have to determine for a random point
what is its color, it becomes a bit more complicated.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, you know the line thickness. Just represent lines as additional
polygons then process only polygons (for example; there's bound to be a
quicker way).
It might not be trivial but it's hardly insurmountable. You know the
stacking order, surely it's just a matter of working down that until your
point is inside a polygon or you run out of polygons to test? It can't be
much more complicated than interpolating bitmaps.
Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> whole:
Or just stack the polygons in the Z direction, then use an orthographic
camera and trace a ray along the Z direction, ... ermmm, hang on :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
SVG doesn't use layers like Photoshop, AFAIK.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Inkscape's "Plain SVG" export includes layer functionality, though, using
the <g id="LayerName"> tag. Surely that's something that could be parsed
on, and as plain SVG, I'd assume it's standards-compliant.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
