POV-Ray : Newsgroups : povray.general : Half-baked distributed rendering question Server Time
12 Apr 2026 15:09:47 EDT (-0400)
  Half-baked distributed rendering question (Message 1 to 3 of 3)
Subject: Half-baked distributed rendering question
Date: 14 Jun 2007 20:53:58
Message: <4671e326@news.povray.org>
First, pardon me if the idea presented below has already been done to death.
 From what I've seen, current methods for distributing a render involve
dicing up the scene and having the separate processors render different
parts of the scene, but with each processor using the same render database.
I had the half-baked idea of dividing up the render task a different
way, and that is to split up the rendered scene among the separate
processors.  One processor decides which rays get traced, and it sends a
ray-intersection request to each of the processsors.  Each one does the
tests against a smaller set of the data, and reports the results to the
controlling processor.  This controller then interprets the results as
need be.
Pros:
   * Scenes can now be larger without stressing memory limits.
   * Ray-intersection tests take less time.
Cons:
   * Communication time between processors may present an unacceptable
bottleneck.
John
Subject: Re: Half-baked distributed rendering question
Date: 15 Jun 2007 02:18:02
Message: <46722f1a$1@news.povray.org>
I may well be wrong but I think the overhead for that would be immense - and
there's no guarantee the workload would be close to even so you might end up
with one processor idling, waiting for the other one - at least at the
moment it can "just get on with it".
I know getting radiosity to work on SMP was a pain - not sure what impact
(if any) your processing method would have on radiosity but I suspect it
would pretty much put you back in the same boat - for that one pixel, it
would need to know where (possibly) any object is. (Please take this as
speculation not fact)
That said, there may well be a better way - I just don't think this is it.
(But keep thinking!)
Simon
"John VanSickle" <evi### [at] hotmailcom> wrote in message
news:4671e326@news.povray.org...
> death.
> database.
> I had the half-baked idea of dividing up the render task a different way,
> and that is to split up the rendered scene among the separate processors.
> need be.
> Pros:
> Cons:
> bottleneck.
> Regards,
> John
Date: 15 Jun 2007 04:59:26
Message: <467254ed@news.povray.org>
  How so? A large scene will take more memory, there's no way around that.
(POV-Ray 3.7 keeps the scene only once in memory regardless of how many
threads are being used, so that's not a problem.)
  Actually I bet they will take in total more time than in the current
method. Communication of ray data between the threads could become an
issue. Cache flushings may become an issue.
