POV-Ray : Newsgroups : povray.general : Student project Server Time
31 Jul 2024 12:18:25 EDT (-0400)
  Student project (Message 1 to 5 of 5)
Subject: Student project
Date: 9 Jun 2007 15:25:01
Message: <web.466afe043f30d8b441e91ba50@news.povray.org>
Hello!
I've some student project and i don't know  how to start...
I've head model in Rhino and i would like to export it to some txt file
(igs?), and change some points in Java. I will get list of NURBS, which i
must render in Povray. Can anybody help me?
Subject: Re: Student project
Date: 10 Jun 2007 00:03:10
Message: <466b77fe$1@news.povray.org>
In general POV works with triangle meshes instead of NURBS...
Probably the easiest way to get your image would be to
open it in Rhino, create a mesh from your NURBS surface, then
export the mesh as OBJ format, then convert that to POV
files with PoseRay.
Rhino Tutorial --
http://mediaservers.vtc.com/player/movieplayer.php?cipher=0d|0o87||||3h49339||3n9sr|5i37b&size=Large&movieName=Meshes
PoseRay -- http://mysite.verizon.net/sfg0000/
If you must have full NURBS from inside POV you may need
to use Bezier patches, but you might need to do lots of hand
coding, conversion, math, and the renders would be slower.
(POV manual) 3.4.2.1  Bicubic Patch
J.W. Stolk's NURBS macros --
http://news.povray.org/povray.text.scene-files/attachment/%3Cweb.43f88f0c20eff568a8399d8d0@news.povray.org%3E/nurbs.pov.txt
Date: 10 Jun 2007 11:45:01
Message: <web.466c1b4e7c565fb9d689bab0@news.povray.org>
Thanks for your answer :-)
Finally I get list of points from rhino... but it is a NURBS surface... is
there any easy way to see it in POV ??
Part of my surface:
"XYZ(0,0) = 0.0245344, 4.64370, 6.87517
XYZ(1,0) = 0.0245344, 4.64370, 6.87517
XYZ(2,0) = 0.0245344, 4.64370, 6.87517
XYZ(3,0) = 0.0245344, 4.64370, 6.87517
XYZ(4,0) = 0.0245344, 4.64370, 6.87517
XYZ(5,0) = 0.0245344, 4.64370, 6.87517
XYZ(6,0) = 0.0245344, 4.64370, 6.87517
XYZ(7,0) = 0.0245344, 4.64370, 6.87517
XYZ(0,1) = -0.610784, 5.67258, 6.87517
XYZ(1,1) = 0.0245344, 6.05324, 6.87517
XYZ(2,1) = 0.659853, 5.67258, 6.87517
XYZ(3,1) = 0.797528, 4.68607, 6.87517
XYZ(13,16)      =       0.0245344,      2.92825,        -3.32444
XYZ(14,16)      =       0.0245344,      2.92825,        -3.32444
XYZ(15,16)      =       0.0245344,      2.92825,        -3.32444
XYZ(16,16)      =       0.0245344,      2.92825,        -3.32444
All weights are 1.0.
Date: 11 Jun 2007 04:54:25
Message: <466d0dc1$1@news.povray.org>
I don't recognize the format... what is the file
extension? You might need to export from
rhino instead of saving?
There seems to be quite a bit of repeated vectors.
Don't forget PoseRay (new and improved!)
Date: 6 Sep 2007 13:32:53
Message: <46e039c4@news.povray.org>
I'm behind on checking all the messages, but...
Rhino exports directly to POV. You can export all the objects into one file
or each object into it's own .inc file with a .pov file that calls in all
of them. Either way, it's a polygon mesh that each object is exported in.
You can specify the polygon count and even preview it before exporting. Be
patient when you do the export as it may appear that nothing is happening
for awhile.
