POV-Ray : Newsgroups : povray.general : out of memory Server Time
28 Aug 2025 23:30:48 EDT (-0400)
  out of memory (Message 1 to 9 of 9)
Subject: out of memory
Date: 31 Mar 2007 04:36:20
Message: <460e2b94$1@news.povray.org>
Hi all,
I have a scene with a fairly large number of objects (a.o. Poser figures).
When parsing the scene, I get the following message, referring to one of the
image_maps for a Poser figure:
Possible Parse Error: Insufficient memory to allocate intermediate image
storage.
Fatal error in parser: Out of memory.
I imagine that this means no more image _maps can be held temporarily in
memory, but can I do something about it (except decrease the number of
objects and/or image_maps)?
Thanks!!
Subject: Re: out of memory
Date: 31 Mar 2007 05:48:12
Message: <53fs035gvopa8ua9qbk5c14vhbcikp1cle@4ax.com>
On Sat, 31 Mar 2007 11:36:21 +0200, "Thomas de Groot" <t.d### [at] internlDOTnet>
You could reduce the resolution of the image_maps or install more memory.
Regards
Date: 31 Mar 2007 06:34:44
Message: <460e4754$1@news.povray.org>
"Stephen" <mcavoysATaolDOTcom@> schreef in bericht
news:53fs035gvopa8ua9qbk5c14vhbcikp1cle@4ax.com...
Hmm, yes.
I found another way by starting up again POV-Ray (3.7 by the way). This time
parsing and rendering works. There is a bit of swaping occurring though, but
that can be expected.
I assume that previously, I had some memory leaking away while rendering
several small test scenes. The result was a shortage of memory when I wanted
to render a big scene.
Date: 31 Mar 2007 06:34:48
Message: <460e4758@news.povray.org>
Hi
> image storage.
> in memory, but can I do something about it (except decrease the number
> of objects and/or image_maps)?
You could increase the size of your swap in order to have more memory
available. If you don't have a 64bit processor, the upper border for
this solution is 2GB or 4GB memory.
I don't know whether using swapping will slow down rendering, since I'm
not sure what povray means with 'intermediate' in the error message.
Date: 31 Mar 2007 08:12:19
Message: <460e5e33$1@news.povray.org>
"Urs Holzer" <urs### [at] andonyarcom> schreef in bericht
news:460e4758@news.povray.org...
Yes that is a solution which I have considered too. But then, the second
time, after restarting pov (and obviously clearing memory) the render went
quite fast without really much swapping. Swap memory stayed just below 2 GB.
Date: 31 Mar 2007 10:30:01
Message: <web.460e7e16e790f910cd668eff0@news.povray.org>
I am not going to tell you things you already know, but to complete the
collection of possible solutions: you can redirect a bunch of figures to a
visible in a scene with dozens of persons. I am doing this all the time.
S.
Date: 31 Mar 2007 13:48:07
Message: <460eace7$1@news.povray.org>
> storage.
This is a known issue with the beta, and is not always due to insufficient
physical memory (it can happen, for example, when there is insufficient
contiguous virtual address space available). We are working on a solution.
-- Chris
Date: 1 Apr 2007 03:28:14
Message: <460f5f0e@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> schreef in
bericht news:460eace7$1@news.povray.org...
Oh, thank you, Chris.
I was wondering indeed if this was similar to that other instance of out of
memory. It seemed different though, which explains my message.
Date: 1 Apr 2007 03:30:11
Message: <460f5f83$1@news.povray.org>
"Steely" <3d### [at] blackdepthde> schreef in bericht
news:web.460e7e16e790f910cd668eff0@news.povray.org...
Yes, thank you for reminding me. I had been thinking along those lines too.
You give me a good reason to implement that :-)
