POV-Ray : Newsgroups : povray.general : color_map is "dirty" on a plane that goes thru the origin Server Time
31 Jul 2024 14:26:41 EDT (-0400)
  color_map is "dirty" on a plane that goes thru the origin (Message 1 to 3 of 3)
Subject: color_map is "dirty" on a plane that goes thru the origin
Date: 11 Mar 2007 12:50:00
Message: <web.45f440c8f0c5f335e8e88bca0@news.povray.org>
If I try the following scene, the top of the cylinder will be a noisy
mixture of the two colors in the color_map.
#declare height = 0;
cylinder {
    <0,height,0> <0,-1.2,0> 2
    texture { pigment {
        gradient -y
        color_map {
            [0 color rgb <1,1,0>]
            [1 color rgb <0,0,1>]
        scale <1, 2, 1>
camera { look_at <0,0,0> location 3 }
light_source { 3 color rgb 1}
If however the height is changed to 0.001, the color is fine.  I am not
quite sure if it's a bug, or I just overlooked something, but I wouldn't
expect this behavior.
Subject: Re: color_map is "dirty" on a plane that goes thru the origin
Date: 11 Mar 2007 13:08:51
Message: <45f445b3@news.povray.org>
Same cause: <http://www.povray.org/documentation/view/3.6.1/154/>
Date: 12 Mar 2007 00:56:58
Message: <45f4ebaa$1@news.povray.org>
> cylinder {
>     texture { pigment {
>         gradient -y
>         color_map {
>         scale <1, 2, 1>
The slope wave of the gradient is breaking just at the top of the
cylinder.  Your workaround it fine or you could also expand the scale of
the pigment slightly and translate it.
