POV-Ray : Newsgroups : povray.general : Large distance solution? Server Time
29 Sep 2024 21:22:28 EDT (-0400)
  Large distance solution? (Message 1 to 2 of 2)
Subject: Large distance solution?
Date: 9 Mar 2007 04:10:05
Message: <45f1246d@news.povray.org>
I've been thinking about FexFX's post because I've had the same problem
before. Maybe this is the solution:
I vaguely rember something about someone posting a camera texture where you
can use a seprate camera as a texture in the same scene in one render. This
would be ideal for use with this kind of scene.
You have your planet at a very large scale. Inside the planet you have the
solar system and a camera that is scaled and syncronized with the main
camera. This camera's texture is then mapped to the sky-sphere.
In the main planet's moon you have a model of your galaxy with another
scaled syncronized camera that gets mapped to a sphere that fit's aound the
solar system model.
Could this work?
-Nekar Xenos
"The truth is out there"
I am using the free version of SPAMfighter for private users.
It has removed 462 spam emails to date.
Paying users do not have this message in their emails.
Try SPAMfighter for free now!
Subject: Re: Large distance solution?
Date: 10 Mar 2007 06:20:00
Message: <web.45f293b01ed7dd9d983ef7b0@news.povray.org>
> where you  can use a seprate camera as a texture in the same scene
> in one render. This  would be ideal for use with this kind of scene.
> Could this work?
Hi Nekar,
I think it should work, BUT the construct
pigment { camera_view{ [CAMERA_ITEMS...] ... } }
is not part of the official POV-Ray, You'll need MegaPOV :-)
I've used a similar construction to get multiple views of the same object in
one render without needing multiple instances of that object (which would
cast shadows on each others ...):
The main camera looks at a bunch of blocks that have the front, top, left
and isometric views of said object as pigments.
Greetings
Karl
