POV-Ray : Newsgroups : povray.general : Specular vs Phong Server Time
29 Aug 2025 07:05:36 EDT (-0400)
  Specular vs Phong (Message 1 to 4 of 4)
Subject: Specular vs Phong
Date: 28 Feb 2007 00:41:40
Message: <45e51614$1@news.povray.org>
(See my image in p.b.i for a comparison of the two).
So, my question is, does someone need both?
I've been in the habit of using specular for my finishes, and I've only
seen phong used a couple of times.  I know that they use slightly
different formulas but, for artistic usage, is there any reason that I
should choose one over the other?
Or, more interestingly, is there any reason I might want to mix them in
the same scene (some objects using specular, and some using phong)?
Personally, I can't see there being an artistic difference between the
two, and I really wouldn't miss the phong feature if it weren't in POV.
...Chambers
BTW, I don't know the specifics of the internal functions in POV, but I
remember Phong being a really cool way of shading polygons in a scan
line rasterizer.  Back in the '90s, the big thing for a while was
Gouraud shading, which was used to interpolate color values between two
points (and, later, interpolate the light values, and apply those to a
texture map).  However, "Phong shading" was used to describe the process
of interpolating the normals, and performing the lighting on a per-pixel
basis.  Of course, since POV-Ray has always done full lighting
calculations on a per-pixel basis, I think it must refer to a different
algorithm :)
Subject: Re: Specular vs Phong
Date: 28 Feb 2007 03:34:54
Message: <45e53ead@news.povray.org>
  As you can see from the image you posted, they use slightly different
algorithms for computing the highlights. The phong highlights tend to
look sharper while the specular highlights tend to look smoother. Which
one you prefer for a certain object depends on your artistic eye, I suppose,
although I'd say you might also make the choice depending on whether you
want to make the material look more mirror-like or more glossy.
  Materials are different and have different reflectivity properties.
Some produce sharper hightlights while others produce smoother ones.
It depends on what you want to make them look like.
> basis.
  Regardless of the name, "Phong shading" and "Phong reflection model"
(which is the 'phong' finish property in POV-Ray) are two completely
different and unrelated things. (This is so in rendering in general;
it's not something exclusive to POV-Ray or raytracing.)
  Phong shading is a concept of rendering polygons and means that normal
vectors are interpolated from vertex normals to the rest of the polygon.
  Phong reflection model (which produce the so-called phong highlights)
is a formula for calculating the illumination of a surface given certain
parameters (viewer direction, light source direction, normal vector,
phong factor and exponent).
  Although they share the name, they are independent things, not really
related to each other. (In other words, eg. Phong shading can be used
even if Phong highlights aren't.)
  In fact, POV-Ray basically uses "Phong shading" with triangle meshes
because it interpolates vertex vectors for the rest of the triangle
surface. This is, of course, done even if you don't use Phong highlights,
which is something different. :)
Date: 28 Feb 2007 04:21:14
Message: <45e5498a$1@news.povray.org>
I had not seen this thread here before the image in p.b.i., so my opinion is
there  :-)
Date: 28 Feb 2007 11:09:12
Message: <45e5a928$1@news.povray.org>
"Ben Chambers" <ben### [at] pacificwebguycom> wrote in message
news:45e51614$1@news.povray.org...
Something I picked up from either Tek or Lightbeam in these groups is to use
both on glassy kind of textures. One, phong say, for larger softer
highlights, and specular for tight and bright highlights (don't forget the
roughness). I don't know if it's physically realistic, but it's eye
appealing to me.
